Old 07-18-2010, 02:52 PM   #106
dcstrom
Oddometer: 1,557
Originally Posted by Gadget Boy
Greg,
The S10 has a dry sump, how's the oil change procedure done?
From the manual. Couldn't be much simpler. The only cowling to be removed is whatever it is that covers the oil filter.
1.Place the vehicle on a level surface.
2.Start the engine, warm it up for several minutes, and then turn it off.
3.Place an oil pan under the oil tank to collect the used oil.
4.Remove the engine oil filler cap, the drain bolt and its gasket to drain the oil from the oil tank.
5.Place an oil pan under the engine to collect the used oil.
6.Remove the engine oil drain bolt and its gasket to drain the oil from
the crankcase.
I'm not clear from the manual how the oil tank is set up, but from the pics it looks like it's under the engine. Can someone confirm?
Trevor
Super Tenere news and reviews
http://supertenere1200.com
dcstrom is offline   Reply With Quote
Old 07-18-2010, 02:53 PM   #107
dcstrom
Oddometer: 1,557
Thanks RB3, answered my question before I asked it!
Old 07-18-2010, 03:29 PM   #108
Olirider
Olirider's Avatar
Oddometer: 470
Gopro HD and S10
Hi Wasp !
>The GoPro was mounted on the R/H side engine protection bar
Thanks for the great video clip. I 've also a Gopro Hd and would like to know which mount you used to attach it to the protection bar.
The Roll bar mount or the handlebar seat mount ?
http://www.goprocamera.com/index.php...2&productid=14
or
http://www.goprocamera.com/index.php...2&productid=15
With your answer I would be sure to know which one I should order.
Thanks !
Olirider
Olirider is offline   Reply With Quote
Old 07-18-2010, 04:48 PM   #109
warnabrother
.. if you see the Rozzers
warnabrother's Avatar
Oddometer: 2,022
not sure if you guys have seen this... but this is how to turn off the ABS
http://www.motorcyclenews.com/MCN/Ne...-tenere-trick/
bikeless...
warnabrother is offline   Reply With Quote
Old 07-18-2010, 04:50 PM   #110
Wasp OP
Supa10 pilot
Oddometer: 1,062
Here is the savage fall that was suffered on Saturdays ride.
Dont watch if you are squeamish,, there's limbs and body (motorcycle) panels flying everywhere.
Well, you couldn't really can it a fall, more like the ground wasn't where I thought it was when I went to dab my foot in the middle of the rain washout.
The bike went down very soft and was surprisingly easy to stand back upright... Apart from the fact that it had to roll a bit backwards before it could right its self.
There was no damage to the bike as it seamed to have laid on the engine protection bars and handlebars, even though the bike looks like it was sort of rocking on the radiator cover panel in the vid???
Sorry but these vids have reduced down to 720x480 or something like that.
Greg.
Wasp is offline   Reply With Quote
Old 07-18-2010, 05:10 PM   #111
Wasp OP
Supa10 pilot
Oddometer: 1,062
Greg,
The S10 has a dry sump, how's the oil change procedure done? Is there a separate oil tank that needs to be drained and if so, how accessible is it? On a previous bike with a dry sump. you had to empty the tank by attaching a rubber hose and then open a nipple, empty the tank, then empty what's left in the engine.. and access to the tank required removing body panels.. I'm hoping the S10's oil change is simpler..
any ideas?
A picture to confirm R3B and dcstrom's version of events.
Greg.
Wasp screwed with this post 07-18-2010 at 05:16 PM
Old 07-18-2010, 05:28 PM   #112
Wasp OP
Supa10 pilot
Oddometer: 1,062
Originally Posted by Olirider
Hi Wasp !
or
Thanks !
Olirider
Cam was mounted on the R/H engine crash bar using one of these clamps (top left corner) http://camzilla.com.au/
good value and a great kit.
Greg.
Wasp screwed with this post 07-18-2010 at 05:41 PM
Old 07-18-2010, 05:29 PM   #113
GrahamD
GrahamD's Avatar
Oddometer: 5,403
Greg.
Did you turn the hazard flashers on OR is that another Obiwan freaky thing where the YAMAHA just knows what to do?
Doesn't look too hard to pick up that is for sure.
Cheers
Graham
GrahamD screwed with this post 07-18-2010 at 06:07 PM
GrahamD is offline   Reply With Quote
Old 07-18-2010, 05:38 PM   #114
AllOrds
AllOrds's Avatar
Oddometer: 1,351
Originally Posted by GrahamD
Doesn't look to hard to pick up tat is for sure.
Cheers
Graham
That's what amazed me.Generally with bikes of this heft i thought I'd be giving him a hand particularly when you see the front wheel above the bike and the rest of it in a trough.The reported weight does not seem to be a massive burden on this bike?
If anyone is in the market for a 1lt ADV bike, they would be doing themselves a disservice not to at least take one of these for a ride.
AllOrds is offline   Reply With Quote
Old 07-18-2010, 05:44 PM   #115
Wasp OP
Supa10 pilot
Oddometer: 1,062
Doesn't look to hard to pick up that is for sure.
Cheers
Graham
Nah, I must have just nudged the flasher hazard button when I was picking the bike up.
Greg.
Old 07-18-2010, 05:46 PM   #116
Wasp OP
Supa10 pilot
Oddometer: 1,062
pfft... I had to park my bike and go and help you back on yours... Rolling around laughing at me.
Greg.
Old 07-18-2010, 05:58 PM   #117
dcstrom
Oddometer: 1,557
I had a similar off on my 650 V-Strom a while back. Put my foot down, nothing there but a pile of leaves I thought was solid ground. Nope, there was a gutter there and over we went. Bike ended up laying on it's side, past horizontal. Man that was a bitch to pick up. I'm not a small guy but I really had to get strategic before I could get it up. For the record, the Wee is about ****100lbs lighter**** than the S10. It's obvious from the way you're able to pick it up, and from my short test ride in Paris, that the way it carries it's weight makes a huge difference, both in the ride and occasions when it has to be manhandled.
I like my Vee and Wee but after riding the S10 I realize just how top heavy they are.
That earlier vid Greg, bombing up the power line track... I'd never go close to that fast on either of the Stroms, due to the lack of ground clearance, crap suspension and, I now realise, the high C-of-G. Also not quite as gung-ho as you!
BTW, did you do your roadracing in Perth? I did some there, and in Adelaide, late 70' early 80's. I'd be surprised if we hadn't crossed paths at some point...
I'm getting more and more frustrated about not being able to get the S10 in the US - read my latest effort, at the bottom of the page http://www.advrider.com/forums/showt...=588052&page=8
Trevor
Old 07-18-2010, 06:07 PM   #118
GrahamD
GrahamD's Avatar
Oddometer: 5,403
They certainly seem a bit clueless over there regrads that segment.
Maybe you could provide a link to the S10 threads on this site, and baby sit them a bit until they get it. (and then hand them an invoice for services rendered )
Cheers
Graham
GrahamD screwed with this post 07-18-2010 at 06:19 PM
Old 07-18-2010, 06:25 PM   #119
AllOrds
AllOrds's Avatar
Oddometer: 1,351
Mate. I wasn't laughing. I had an OH Shit, that's the radiator side moment.
And its good to see that the Crash bars/Handle bars and pegs are the only things that touch down
Old 07-18-2010, 06:31 PM   #120
GrahamD
GrahamD's Avatar
Oddometer: 5,403
Just on the Radiator subject, What exactly is protecting it apart from the plastic piece?
I seem to remember R3B saying something about the protection and its ability to move, but since there were no pics and I'm a bit simple I didn't quite get it.
Cheers
Graham
Times are GMT -7.   It's 10:36 AM.
