03-09-2012, 05:02 PM
#16 |
Oddometer: 75
An obviously well loved machine, awesome to see it continue being traveled on. Kudos fellas
____Shiney_Side_Up_____ 1995 CB1000 |
03-09-2012, 05:10 PM
#17 |
One wheel wonder...
Oddometer: 6,318
![]() It also looks like he used a whole tube of ultra copper on that front valve cover. Not too good for the oiling system.
"Tough times don't last, but tough people do." Robert A. Schuler
03-11-2012, 12:23 PM
#18 |
Sleep, Wrench, Ride
Oddometer: 4,449
History of The Loser as I understand it.
chopperito (Dirty Dave) payed money for this machine.
It was then given to Geek to introduce him to adventure riding. It was then given to Spooph fix for Felix Delarge's Western United States tour. [Trip planning and original RR] And then passed on to Gummy who lived with Tha Rick at that time. And then passed on to NoSpark? Other recent updates: http://www.advrider.com/forums/showthread.php?t=706173
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
03-11-2012, 12:27 PM
#19 |
Sleep, Wrench, Ride
Oddometer: 4,449
I was at a poker game last night with some friends. One of them used to ride dirt bikes in Oregon. He has occasionally told me he wants a dual sport so he can get around the mountains cheaply/easily. The only problem is he has no money for a bike. I thought about it for a minute and realized I might have a lead on a bike in his price range. This morning I sent him an email with the history of The Loser and the responsibilities that handling such a machine entails; we'll see if he's up to the challenge.
03-22-2012, 04:35 PM
#20 |
Sleep, Wrench, Ride
Oddometer: 4,449
found this on Geek's Happy B-Day thread. Thought it should be posted here too
04-04-2012, 11:08 AM
#21 |
Sleep, Wrench, Ride
Oddometer: 4,449
oil in the airbox
How much oil is getting in the airbox? A couple tablespoons, or a cup or so? Was the bike dropped on it's side when this happened, or does it happen on every ride?
Also, is there smoke coming out of the exhaust?
04-05-2012, 07:35 AM
#22 |
Sleep, Wrench, Ride
Oddometer: 4,449
What about a manual
Does anyone have a shop manual for the bike?
04-05-2012, 12:31 PM
#23 |
Sleep, Wrench, Ride
Oddometer: 4,449
Nevermind, found it.
04-05-2012, 02:23 PM
#24 |
Oddometer: 1,480
[/QUOTE]![]() Fantastic |
04-18-2012, 07:14 PM
#25 |
Sleep, Wrench, Ride
Oddometer: 4,449
Plugs:
front cylinder: looks good rear: mixture is right, but it looks like it's been burning oil Compression test: front: 110 PSI rear: 115 PSI I added a tablespoon of oil to each cylinder and tried again: front: 130 PSI rear: 140 PSI
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 Pablo83 screwed with this post 04-18-2012 at 07:33 PM |
04-18-2012, 11:37 PM
#26 |
4,949
Oddometer: 5,998
It takes less time to do things the hard way than to be too nervous to even start at all. -Juanito on the Yahoo! |
04-19-2012, 09:15 PM
#27 |
Loser's Handler
Oddometer: 8
Got my hands dirty today
Went to Pablo83's today and we took off the heads. It was fun to get started and I hope we can get her up and running at some point.
I'm a loser baby, so why don't ya kill me --Beck |
04-25-2012, 02:33 PM
#28 |
Sleep, Wrench, Ride
Oddometer: 4,449
Per Honda manual:
Removing the valve cover Step one: remove engine from frame. ![]() We managed to remove the valve covers without removing the engine. We also removed the front cylinder head with the engine in place, but the rear was a different story. But we were able to just move the engine a little and get it off. Unfortunately the drive shaft became disconnected and I think the swingarm will need to be removed to get it back in place. ![]() ![]() We had a slight incident with an impact driver and now we will be looking for a new cam shaft. Anyone have any leads?
04-25-2012, 02:40 PM
#29 |
Sleep, Wrench, Ride
Oddometer: 4,449
04-25-2012, 04:41 PM
#30 |
Sleep, Wrench, Ride
Oddometer: 4,449
Results are in ...
... well some of them at least.
Front cylinder bore measurements range from 71.00mm to 71.03 Rear cylinder measures from 71.02 to 71.06. Spec is less that 71.17 with less than .05mm taper, so the jugs are good. ![]() Honda seems to so rarely understand their customers, but in our case they have managed to grasp the transient nature of The Loser and have graced it with steel sleeved jugs. So the bores will get a quick hone and a re-measure and we'll call it good. ![]() Ring end gap: Front 1st and 2nd ring = .559mm Rear 1st and 2nd ring > .813 (my feeler gauges only go to .813 and the gap was bigger than that) Spec = .50, so all the rings need to be replaced. The rear rings are worn quite badly and I'm guessing this was causing excess blow-by gasses which where pushing oil through the breather tube into the airbox. Another benefit of steel sleeves is that you can put oversized rings in them, AND Honda sells oversized rings for the bike. The problem is, I don't know how to determine what size to put in. Any suggestions?
