Old 04-25-2012, 05:48 PM   #31
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Also...
There seems to be a lot of metal flakes in the coolant. This could be the result of someone using Stop Leak or similar products in the radiator OR... we could have a shredded water pump. I'll be pulling that apart next.
Pablo83 is offline   Reply With Quote
Old 04-29-2012, 10:04 AM   #32
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Originally Posted by Pablo83 View Post
Per Honda manual:
Removing the valve cover
Step one: remove engine from frame.
Per Honda manual:
Removing the water pump
Okay, okay, Honda, I get it.
Old 04-30-2012, 11:16 AM   #33
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Engine
I'll post more details later, but to summarize: The Loser could really use a new engine.
I've found one for cheap on eBay, but it's local pickup only in Jefferson City, Missouri. If anyone know someone who could pick this engine up and store it until I drive through in June, I would sure appreciate it.
Old 05-05-2012, 04:42 PM   #34
rcjhk
rcjhk's Avatar
Oddometer: 81
I can go pick it up tomorrow or Monday and keep it at my house in the garage until then. I'll PM you with contact info. I'm located in the Kansas City area.
Ride it like you stole it!!!
rcjhk is offline   Reply With Quote
Old 05-06-2012, 08:50 PM   #35
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Time for an update.
It's hard to tell exactly what the causes where for all the various repairs on this bike. My guess is the weep hole on the water pump started to leak. When this happens it means the internal gaskets on the pump are bad. I believe a previous handler thought the external seals where bad so they added RTV gasket to the seal. When this didn't fix the problem they added JB weld to the bottom of the pump where the fluid was dripping.
Anyway, the internal seals on the pump are bad. The pump in not rebuildable (dumb), it needs to be completely replaced. Honda has discontinued the pump. There are none available on eBay.
While disassembling the engine we managed to break a cam (that's another story). There are loose pieces of RTV gasket all through the engine. All of these things led me to look for a new engine, and I've bought on in Missouri for only $26!!! (http://www.ebay.com/itm/150803817497)
I'm going on a trip to Georgia later this month so I'll be driving through the area and I can pick it up. The engine is out of an '86 Shadow (still 500cc) and I believe it is identical to the '84 Ascot, but that's going to be a bit of a gamble.
Thanks to Redburn for picking up the engine and rcjhk for volunteering as well.
If this works out it will reduce the repair costs of The Loser by about $450, and frankly, without a cheap engine like this, The Loser would be in great danger of becoming a parts bike. I'm keeping my fingers crossed that this will all work out.
Old 05-08-2012, 06:19 PM   #36
Uncle Goo
Loser's Handler
Uncle Goo's Avatar
Oddometer: 22
awesome Pablo!
I'm glad you were able to get the engine. I've been busy with work this week but if you let me know when you want me to come over and help I'll do my best to stay away from the cams.
I'm a loser baby, so why don't ya kill me --Beck
Uncle Goo is offline   Reply With Quote
Old 08-27-2012, 09:14 PM   #37
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Summer's really been busy and I haven't been able to work on The Loser, but I've finally been able to pull it into the shop. The frame and engine on the right is the donor engine I got on eBay.
Old 08-27-2012, 09:19 PM   #38
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 8,987
I don't know if I should or . But way to go bringing the Loser back to life. BTW: remember to use plenty of red wire and that is what binds it all together.
Marc
84 R100RS LE, 14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax is offline   Reply With Quote
Old 09-05-2012, 09:46 PM   #39
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Well I was told that this new engine was a "runner", but after pulling the valve cover I can see it was not a good runner. One of the valve adjuster jam nuts came loose and this is what the clearance looks like:
Damage report: one of the valve keepers has partially popped out and is cracked. The top of the valve is destroyed. The rocker arm face is also destroyed.
hopefully there are enough good parts from both engines to build one good one.
Old 09-06-2012, 02:15 PM   #40
RLK
4,949
RLK's Avatar
Oddometer: 6,414
Well that's disappointing. Donor bike has some stories too. Hope, and luck to you as you go. Thanks for sharing your progress.
It takes less time to do things the hard way than to be too nervous to even start at all.
-Juanito on the Yahoo!
RLK is offline   Reply With Quote
Old 09-06-2012, 04:34 PM   #41
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,949
Gotta give you credit for stickin' with it though...
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 09-06-2012, 04:45 PM   #42
Navin
Navin's Avatar
Oddometer: 7,829
Did you file a complaint to recoup the $26???
Navin is offline   Reply With Quote
Old 10-01-2012, 03:24 PM   #43
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Well, after a stupid-long wait for a head gasket, the heads are back on the Loser...
While reassebling it I noticed the tower that supports the RPM gauge drive was cracked (what did you people do to this bike?)
I could weld this side of the crack, but it would be near impossible to weld the inside so it would probably end up breaking again. The RMP needle on the Loser is broken anyway so it's not much use trying to fix this. I used Shadow 500 donor engine parts (the Shadow did not have an RPM drive) to fix the issue. I've got a plan to replace the RPM gauge...
Old 10-01-2012, 05:43 PM   #44
Lomax
Lomax's Avatar
Oddometer: 8,987
If you only knew.
Marc
Old 10-07-2012, 12:54 PM   #45
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,301
What a story.There has never been a more well documented bike's ownership stories and horrors.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Times are GMT -7.   It's 10:38 PM.
