Old 01-18-2013, 10:25 AM   #76
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,852
Originally Posted by dorkpunch View Post
Yeah... Been busy with everything else. You can read about it here: http://dorkpunch.com
Been practicing my TIG welding in hopes I might some day be able to build a tank for this beast.
Project A.D.D. !!
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 01-19-2013, 10:29 PM   #77
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,177
A.D.D. is about the best way possible to sum up the flow of my projects...
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 01-25-2013, 05:22 PM   #78
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,177
Still trying to figure out my edge former so I whipped this out. I think it turned out incredible... Usually things like this end up as scrap when I touch 'em.
Drew up a shape on a piece of paper real quick, traced it onto some aluminum and hacked it out.
Ran it through the slip roll to give it a bit of a curve and tried it on with some duct tape
Did a little creative measuring... Made some brackets to mount it to the headlight ears, and viola!
I intended to roll the edge with the edge former but I couldnt get it to work nicely on my scraps, so I just rolled a bead all the way around and filed the edges. Now maybe someday I'll start on the tank...
-Charles De Mar.
Old 01-25-2013, 07:33 PM   #79
Edmond Dantès
The Kanto Pain
Edmond Dantès's Avatar
Oddometer: 594
Got any video footage Dorkpunch? Would love to hear how that bike sounds.
I had a FS1-E 'Fizzy' back in the day. Great little bike.
Edmond Dantès is offline   Reply With Quote
Old 01-25-2013, 08:45 PM   #80
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,177
Hmmm... Not sure that I do! Might have a clip of it when I tested the pipe but I kinda doubt it. I'll check though.
-Charles De Mar.
Old 01-28-2013, 06:39 PM   #81
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,177
Playing around some more. Working on the seat bump. First attempt was more of a test, I didn't really expect it to work out. Tried to get all fancy, and it didn't turn out.
Second attempt turned out much better- less fancy, and less shape to it but I think it looks good.
-Charles De Mar.
Old 01-29-2013, 04:51 AM   #82
c.herman126
c.herman126's Avatar
Oddometer: 524
Nice work Dorkpunch.
These are great small projects for your students to see!
"Dream as if you'll live forever. Live as if you'll die today" James Dean
1993 XR650L
2008 530 EXC-R
c.herman126 is offline   Reply With Quote
Old 01-29-2013, 05:38 PM   #83
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,177
More on the seat... Hacked out a seat pan and marked out the hole I'm going to cut in in to get it to sit down over the frame.
Trimmed the cover up to accomodate the thickness of the wood.
And worked a bit more on the lip of the cover... getting closer but still have a ways to go.
-Charles De Mar.
Old 01-30-2013, 06:20 PM   #84
mhaas
intrpd travlrwanabe
mhaas's Avatar
Oddometer: 184
Cafe 75
That is a good looking project you have going.
I let my mom's 69 Trailmaster go @ VMD last year. It hadnt run in 10 years. The guy had it running after 2 days of working in his vender area. We still have a blue 75cc with the long tank and seat with low bars. I found it full of water under the eaves of an old house. The motor is solid (one rusted lump) the tank is full of rust.
mhaas is offline   Reply With Quote
Old 01-30-2013, 07:34 PM   #85
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,177
Cut the hole out of the seat pan so it would fit down over the frame, made a cover for it out of sheet metal, and temporarily mounted the bump. Also cut down the tank mock up a bit, I like it a lot more. The tank will have radiused bends (hopefully) so it will be a little curvy-er.
-Charles De Mar.
Old 01-30-2013, 08:12 PM   #86
Leo.G
Is still learning
Leo.G's Avatar
Oddometer: 382
It's slowly starting to have a really nice and different look..
Thanks for sharing the build with us.
I can't wait to see the tank finished!
Greetings!
2010 Honda XR 250 Tornado
Leo.G is offline   Reply With Quote
Old 02-01-2013, 07:54 PM   #87
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,177
Started on the tank today...
Even got the pieces tacked together with my crappy TIG welder without blowing any (major) holes. Turned out great I think, even though I got a little excited about finally starting and used my old measurements, which means the tank sticks down about an inch further than I wanted it too. Oh well... I can camouflage it with some paint if I don't like it.
-Charles De Mar.
Old 02-02-2013, 10:59 AM   #88
Valleyrider
I Survived The '60s
Oddometer: 1,852
I like it!! What TIG welder are you using? Thinkikng about getting one for my garage use...
Old 02-02-2013, 11:06 AM   #89
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,177
Its just an old beater Century DC/AC welder a friend gave me broken... I fixed the amp selector thingy and scrounged up a tig torch for it, bought a bottle of argon and a regulator and used it a bit. Couple months ago I finally decided I wanted to do something with aluminum so I figured out how to wire the high frequency stabilizer and set it up for AC...
I don't think its going to work for this thin stuff. I've been practicing a fair bit and I can get some decent beads but not having the foot control to vary the amps while welding means welding a teensy bit and then waiting for the metal to cool down... My welder only goes down to 30 amps. Seems like thats okay to start, but when I get going it needs to drop down to more like 15. I'll probably tack it all together for now and see if I can figure out how to get my hands on a newer ($$$) machine, or see if I can borrow one at the high school. Thinking I might try to sell this one and maybe a bike or two to fund the purchase of a nice one later this summer.
This plate started out at 1/8" thick.. It's well over an inch thick now.
-Charles De Mar.
Old 02-02-2013, 03:34 PM   #90
CDNbiker
Lost in Space
CDNbiker's Avatar
Oddometer: 499
Cool project. I've got a YL1 I'm giving a mild cafe treatment but the project has stalled with the crappy winter weather. Love these little Yamahas. Looking forward to seeing how yours turns out.
"The memories of a man in his old age are the deeds of a man in his prime" - Pink Floyd
CDNbiker is offline   Reply With Quote
Times are GMT -7.   It's 11:57 AM.
