Old 08-28-2010, 07:09 PM   #61
nella OP
nella's Avatar
Oddometer: 405
Originally Posted by Wirespokes
It looks like the choke lever isn't all the way down in the photo above. It also appears to be bent, which could account for not being all the way down. But it could also be just the magic of photography and everything's fine.
I checked that out and it's bent but seats fine and turns off completely when pressed down. It's the pilot circuit, I think I have adjusted it as much as I can with the air screw and may need smaller pilot jets. I'll know for sure tomorrow when I test it some more.
Scott
Scott
nella is offline   Reply With Quote
Old 09-01-2010, 06:14 PM   #62
nella OP
nella's Avatar
Oddometer: 405
So today I installed a block off plate and did some work on the catch tank.
This is an old Greddy tank that I took the center section out of. Found a small unifilter at a local shop and came up with this:
I have the crankcase and gearbox vented to the catch tank and a filter on the catch tank. It's overkill. I might take it off and do something else. I'm not sure what I think about the tank arrangement.
I've also neen messing around with the front fender, this is where I'm at now. The brackets were a PITA to design and make work. I have the fender that matches the tank and cowl but it's full length and I'm not inclined to chop it up or use it. The fender in the pic below is the original /7 fender that has been chopped.
Thoughts on the front fender?
Scott
nella screwed with this post 12-31-2010 at 03:50 PM
Old 09-01-2010, 06:32 PM   #63
nella OP
nella's Avatar
Oddometer: 405
Thought some folks might be interested in the headlight bracket ears.
The clamps are simple t-bolt clamps x 4. The ears I cut off a ~$16 set I bought for the bike when it had the 36mm stock forks. I then drilled the fork ears for the bolt part of the clamps to pass through. It's a very sturdy arrangement.
Scott
Old 10-13-2010, 05:38 PM   #64
edray
cascadian
Oddometer: 189
great build.
Fantastic!
really inspirational.
just what i had in mind for a couple of years, but was always intimidated about the bearings and whether it all would work..thanks a lot.
i did a GSXR front end on my 2001 SV650, and always felt that it would be cooler to do my airhead.so now selling my sweet 1995 Ducati 900SS/CR to fund my take on this project.Going w/wire spoke wheels,etc..plus its wild that you used Mikuni FCRs, as i got a 39 mm.set included when i bought the Duck,so I'll attempt that too..
Thanks again..
Ed
edray is offline   Reply With Quote
Old 10-13-2010, 05:40 PM   #65
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 8,300
Talking pickapunk
(post deleted for personal hygiene)
...how did your suspension mods effect the geometry of the bike?
Looks great, but how's she handle?...crandle.
'08 R1200R / '10 WR290X/R
'81 R100RS Rattlecandy Red
'06 950 ADV Orangeboom
'05 R12GS Wedding Bike '91 R100GSPD Derelict
Rapid Dog screwed with this post 10-14-2010 at 02:00 PM
Rapid Dog is offline   Reply With Quote
Old 10-13-2010, 07:24 PM   #66
nella OP
nella's Avatar
Oddometer: 405
I'm not telling. I don't want there to be a run on GSXR forks and ohlins rear shocks
Seriously though it's like a new bike, perfect for back roads and track days. I can't quantify it beyond that. I'm happy with it.
Scott
nella screwed with this post 10-16-2010 at 05:26 AM
Old 10-13-2010, 08:05 PM   #67
anonny
What could go wrong?
anonny's Avatar
Oddometer: 4,955
Nice bike but.....you have to get rid of those front fender brackets somehow, they are just way to long.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 10-13-2010, 08:14 PM   #68
P B G
Oddometer: 9,781
Problem is w/ the forks like that, a sport bike fender is plastic molded all the way down to mount in those same spots. Looks slightly less goofy because the whole bike is plastic.
Can't clamp under the uprights, cannot mount to the uprights.
Realistically I think the best cosmetic would be to use wider material, and mill out the inside area to look trick. The plastic fenders from sport bikes are quite bizarre when you stare at them.
Old 10-13-2010, 08:56 PM   #69
nella OP
nella's Avatar
Oddometer: 405
I'd appreciate any suggestions for alternative ways to mount a normal fender on inverted forks. what's pictured is the best I could come up with.
Scott
Old 10-13-2010, 09:51 PM   #70
Hawk Medicine
Coyote's Brother
Oddometer: 3,299
I wouldn't worry about it that much for the time being.
I had my doubts when you started this thread but it's obvious that, so far, your bike has shaped up pretty nicely. Yeah, the fender stay in the front looks a little wonky but it stops looking that way as soon as one realizes how difficult and expesive solving that problem might be.
Relax and ride your bike. The answer'll come at the right time and at the right price.
Oh... And did I say that I like what youre doing with your bike? I do!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 10-14-2010, 07:02 AM   #71
Rapid Dog
Rapid Dog's Avatar
Oddometer: 8,300
Question
The reason I ask about geomtry is that the bike looks dumped in the front compared to the long stock forks. Are the wheels both 18" ?
Old 10-14-2010, 08:53 AM   #72
nella OP
nella's Avatar
Oddometer: 405
No the rear is an 18 but it's a 140/80 tire and probably a little taller than stock. I did not take any before or after measurements so I don't have a baseline to compare the front end height with.
Scott
Old 10-14-2010, 10:21 AM   #73
Rapid Dog
Rapid Dog's Avatar
Oddometer: 8,300
...soooo, 18" rear, 19" front? That would be standard wheel size for a /7 beemer. Those are Lesters so I'll assume that's the size.
So geomtry shouldn't change except for the squattier forks.
Hmmm...
Lornce, Anton, chime in anytime here...
Old 10-14-2010, 10:48 AM   #74
Velvet Elvis
mild mannered adventurer
Velvet Elvis's Avatar
Oddometer: 158
Send a message via MSN to Velvet Elvis
Great looking bike!
Re the geometry, it could be a lot different than stock. Fork length, triple clamp offset, wheel offset at the axle are all different than a stocker. But hey, if it handles good that's the proof in the pudding. Any issues with the 19" wheel hitting any hard parts at full fork compression? Again, really nice build. Someday I'll do something similar with my R80/7.
Kevin
Zoinks
Velvet Elvis is offline   Reply With Quote
Old 10-14-2010, 10:55 AM   #75
edray
cascadian
Oddometer: 189
I've been pretty stoked about this swap,and have been searching for a different fender redo. Found this on another forum.
Here's the link, as I can't seem to figure out the image post thing yet.
Sorry, I'm noobish, bear w/me.
http://forums.sohc4.net/index.php?topic=63784.325
The image is a third of the way down the page.. Its a guy who did a Honda 954RR?, but its that same Showa fender mount system..He used aluminum tubing,and says he bent it around his sons basketball. He mounted the braces on top of the aluminum fender, a reworked by him Royal Enfield rear fender..
To my way of thinking,it brings a retro look to the modern front end.
Pretty cool. I'm gonna go this way..
Times are GMT -7.   It's 01:20 PM.
