Old 02-01-2011, 08:21 PM   #76
nella OP
nella's Avatar
Oddometer: 403
I never got around to finishing my dash. I wanted to have the warning lights and use my sigma speedo. Tonight I tried some ideas and came up with this using four different color LEDs and a fabricated mount for the speedo attached to the back of the triple clamp:
Scott
nella is offline   Reply With Quote
Old 03-20-2011, 04:01 PM   #77
nella OP
nella's Avatar
Oddometer: 403
So the next chapter opens in my never-ending project.
So with lots of help from Houseoffubar (Eric), I have my welded monoshock and bracket. It goes with out saying that his work is top-notch.
These parts and a 2009 Yamaha R1 rear shock will go on my R100. Now it's a matter of making time to get it together.
Scott
Old 03-20-2011, 08:32 PM   #78
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,782
Hey man, Sweet swing arm
I was just looking at your LED idiot lights, did you find 12v units, or did you have to wire resistors, and such?
Old 03-21-2011, 07:54 AM   #79
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
...very nice work fellas.
Rapid Dog is offline   Reply With Quote
Old 03-27-2011, 05:25 AM   #80
nella OP
nella's Avatar
Oddometer: 403
I found ones with resistors wired in. I'll have to dig around to come up with where I bout them.
Scott
Old 03-27-2011, 05:28 AM   #81
nella OP
nella's Avatar
Oddometer: 403
Slow progress. Painted my swingarm and started test fitting the shock and mount yesterday.
/a>
Scott
nella screwed with this post 03-27-2011 at 01:10 PM
Old 03-27-2011, 10:44 AM   #82
Houseoffubar
fine beer sampler
Oddometer: 1,782
Hey, That's coming along nicely, Keep it up!
Old 04-03-2011, 04:11 PM   #83
nella OP
nella's Avatar
Oddometer: 403
I'm finally satisfied with the way the R1 shock is working. Went out for a ride this afternoon and I'm very happy with the way the bike is handling. It was a bit of an adventure welding the upper shock mount to the frame but I think it's a solid weld and is not going any where. I do need to play around with the compression and rebound settings on the rear shock.
The battery is a small lightweight 12 cell (a123 cell) mounted under the seat in the stock tool box. I need to re-design the oil catch tank and will eventually end up replacing the rear subframe. I still have some other things planned, but I'm in no rush. A big shout out to Houseoffubar for helping with the swingarm and shock mount. His welding skills are awesome.
Photobucket
Scott
nella screwed with this post 04-03-2011 at 04:37 PM
Old 04-03-2011, 04:23 PM   #84
nella OP
nella's Avatar
Oddometer: 403
Another pic from my ride today:
Photobucket
Scott
Old 04-03-2011, 04:32 PM   #85
Houseoffubar
fine beer sampler
Oddometer: 1,782
Man, That's how you get things done, I don't even have MY swing arm on yet! I'm such a slacker!!!
Looks great!
Old 04-03-2011, 07:20 PM   #86
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
Thumb
...is that a Corbin double seat for a solo seat? Never seen that config.
Old 04-04-2011, 05:14 AM   #87
nella OP
nella's Avatar
Oddometer: 403
Yes, that's what it is. The previous owner had Corbin make it for him. I've never seen another like it either.
Scott
Old 01-12-2013, 01:15 PM   #88
BeachZack
Oddometer: 11
Sorry for the bump, but if you are reading this, do you have any pictures of your front axle and how you fit it?
Thanks.
BeachZack is offline   Reply With Quote
Old 10-15-2013, 10:05 AM   #89
Plaka
Brevis illi vita est
Oddometer: 4,609
Originally Posted by DiabloADV View Post
Didn't read the whole thread but...doesn't that hole need to be vented? I'm facing the same modification...
The vent is in the bolt. So long as the aluminum plug isn't too tight in the plastic bush below the bolt groove...
Old 10-15-2013, 10:09 AM   #90
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,498
the bolt is the vent. It's hollow.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Times are GMT -7.   It's 09:48 AM.
