Old 07-09-2010, 02:28 PM   #1
SCouch OP
SCouch's Avatar
Oddometer: 113
KLR 650 Airbox Mod
Finally getting exhaust, high flow filter and jet kit for the 2001 KLR 650. I've seen some suggestions about drilling holes in the airbox to create air flow, but I'm thinking this will let water in. Is there a way to increase air flow without causing water problems, or is it even needed?
SCouch is offline   Reply With Quote
Old 07-09-2010, 05:51 PM   #2
CA Stu
CA Stu's Avatar
Oddometer: 42,779
Yes and no.
Yes: the way around it is to cut an "L" in the top of the airbox. You can use a die grinder / Dremel tool to cut it with an abrasive wheel, go slow and you can do a very fine job.
From here: Link
No: It's not necessary in my opinion. Unless you do other mods like a 685 kit and a big valve head, and what kind of dummy would do that to a KLR.
CA Stu
CA Stu is offline   Reply With Quote
Old 07-09-2010, 06:16 PM   #3
SCouch OP
SCouch's Avatar
Oddometer: 113
Thanks!!
Old 07-09-2010, 06:48 PM   #4
WILL_S
110 POWER
WILL_S's Avatar
Oddometer: 1,691
I did mine by drilling 3 1" holes in the top and not cutting the L.You can plug the holes up with rubber grommets to reverse it.
Did it make a difference ....you bet.Although i have a aftermarket exhaust and different jets & needle height.The mods i did were with the instructions for the pipe to get the best results after fitting the pipe.
Yep i'm some kind of dummy
Take the green pill or the red pill- the choice is yours;This is your last chance. After this, there is no turning back. You take the blue pill - the story ends, you wake up in your bed and believe whatever you want to believe. You take the red pill - you stay in Wonderland and I show you how deep the rabbit-hole goes.
WILL_S is offline   Reply With Quote
Old 07-09-2010, 07:46 PM   #5
IdaTHUMP
Hunt'n fer sixth
IdaTHUMP's Avatar
Oddometer: 44
A 'stage 1' mod (air, jetting/FI adj., exhaust) will always make a difference in performance but fuel economy will suffer and you will probably be environmentally unfriendly at that point (if that matters to ya...). All in all I am getting away from running my bikes like this the older I get. If you need more power buy a bigger displacement machine!
Curt
'03 DR650
'09 HD FLTR
He is no fool
who gives what he cannot keep to gain what he cannot lose.
IdaTHUMP is offline   Reply With Quote
Old 07-10-2010, 06:25 AM   #6
Big_AL
Big_AL's Avatar
Oddometer: 126
I'd did the .22 cent carb mod and Low Buck Exhaust mods on all 4 KLR's I've owned and had great success with just removing the factory restricting grommet from the top of the air box. Got a stack of grommets, anyone need one? HTH....Al
Big_AL is offline   Reply With Quote
Old 07-10-2010, 10:52 AM   #7
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,342
I removed the snorkel (or grommet if you prefer) and it made a very nice difference in throttle response.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." -
Abraham Lincoln
Bigger Al is offline   Reply With Quote
Old 02-24-2013, 01:24 PM   #8
Dan Diego
Oddometer: 416
KLR650 Airbox Mod (with Uni vent filters)
Here's a pretty clean and easy mod I did today in about 6 minutes.
Having trouble adding photos; here's the link if the photos don't appear in this post.
https://plus.google.com/photos/10710...32080665280753
2011 Kawasaki KLR650
2009 Triumph Rocket III Touring
Iron Butt LDR guy
Dan Diego screwed with this post 02-24-2013 at 02:02 PM Reason: Photo sharing issues.
Dan Diego is offline   Reply With Quote
Old 02-24-2013, 02:42 PM   #9
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 902
I think it depends on what exhaust you bought and if you want to get the most out of it. If you have a full flow exhaust, go ahead and pull the snorkel. Then perform the L mod but buy some plugs the same size if you think you didn't need to. I say there is a noticeable difference. .. Air in, air out. Its not rocket science. The Lmod holes are under the seat and as high or higher than the snorkel, Were you planning on swimming with your KLR? ;-)
"Where ever you are, there you go..."
SkiBumBrian is online now   Reply With Quote
Old 02-24-2013, 02:56 PM   #10
JBradley500
Oddometer: 30
I did the same thing with (4) 1" holes like Dan Diego plus no snorkel. Even though I really liked those little uni-filters I didn't think they were worth the effort.
JBradley500 is online now   Reply With Quote
Old 02-25-2013, 06:14 AM   #11
Tsotsie
Semi-reformed Tsotsi
Oddometer: 839
Has anyone done any real before an after, documented testing, to see if this 'L mod', drilling holes actually works?
People remove the 'snorkle' which has rounded edges to smooth flow the air passing through to a hole with sharp edges and which is not aerodynamically efficient?
Another of the tribal knowledge gotta haves?
Tsotsie is offline   Reply With Quote
Times are GMT -7.   It's 07:33 PM.
