Old 07-10-2010, 05:06 PM   #1
V-Tour OP
V-Tour's Avatar
Oddometer: 44
Eh? Rear Tire Life Sucks
OK maybe not for everyone but I am a easy rider with a 2009 Burgman 650EX bought last fall. It is not my normal ride but a spare and one I hope to share with the wife when she is able. I haven't ridden it much but took it in for the oil change this week at 5600 miles and darned if they didn't tell me the rear tire needs replaced On my V-Strom I get a little over 8000 miles per change, on my BMW (sold last fall) I got about 12000 per rear.
I check pressure before rides and have been riding alone so do I have to go to the darkside to get decent tire wear?
ADvice?
V-Tour
V-Tour
2009 Burgman 650 Executive
2008 DL650 V-Strom
2008 R1200 RT BMW
2007 Honda Reflex
V-Tour is offline   Reply With Quote
Old 07-11-2010, 05:01 AM   #2
ronnath
ronnath's Avatar
Oddometer: 1,445
just a couple of thoughts, v-tour.
1) did the guy show you the problem or just tell you?
2) did you look over the tire yourself to check tread depth? a one year old bike shouldn't have any checking or splitting on the sidewalls, but i guess it could be possible.
3) i've read posts where owners of the big scoots have talked about getting only 8/9k out of the rear tires. but 5600? sounds way too early.
other than that, i got nothin'.
ronnath is offline   Reply With Quote
Old 07-11-2010, 05:27 AM   #3
hugemoth
hugemoth's Avatar
Oddometer: 2,894
While it would be nice to get more mileage out of a rear tire 5600 isn't unusual. My old Vespa 200s would get 6000 rear 18000 front with good Michelin tires. My Goldwing was about the same on the rear.
Old 07-11-2010, 06:10 AM   #4
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,890
It seems that the scooters that have a lot of rear weight bias do go thru rear tires pretty quickly. But, I do think 5600 is a little low. My Reflex (granted, not the same as your scoot) has over 13K miles on its OE Hoops and they're still going strong (but are cupping and will be replaced this winter).
What make/model tire is on there right now? Perhaps it's something to avoid, in the future.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 07-11-2010, 02:55 PM   #5
V-Tour OP
V-Tour's Avatar
Oddometer: 44
Tire was the one that came on it new and is worn down to the thread indicators. The idea that every oil change it needs a new tire scares me.
Thanks for the ideas, I think I get will go ahead and get a new bike tire and study darksiding. I usually don't do much work on the bike myself but can if needed.
V-Tour
V-Tour
2008 DL650 V-Strom
2008 R1200 RT BMW
2007 Honda Reflex
Old 07-12-2010, 07:36 AM   #6
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,084
Try 2000 out of a 10" rear wheel on a Vespa 150.
Small diameter wheels make circles more often.. not to mention most scooters
are a lot heavier at the rear end.
I've had no noticable wear EVER on my 50cc, but the Agility 125 shows wear
after 4000 miles on rock-hard Taiwanese made CST tires. I've done 15k on
my Ninja 650 on OEM bridgestones.
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 07-13-2010, 05:08 AM   #7
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,702
. . . at 5600 miles and darned if they didn't tell me the rear tire needs (to be) replaced
That's nothing compared to tyre life on the Honda VT500E of the eighties. The compound was the closest match to genuine racing tyres that I ever encountered on a road bike. The rear would last less than 5000km, and the front wouldn't last much longer!
Now, I'm riding a Burgman AN650A . . . . . . ah. but at least you can be informed about your fuel consumption.
'08 Suzuki AN650A Burgman (and trailer)
vortexau is offline   Reply With Quote
Old 07-19-2010, 12:54 AM   #8
Tromper
Tromper's Avatar
Oddometer: 128
This is a fairly common complaint with the 650; although 5600 is a bit low even for the OEM TH01 which your 09 almost certainly had.
The OEM has been changed to the TH01M which seems to be wearing a bit better.
Overally I got about 7kish out of my original, & a bit better from the replacement (same tire). The updated one I have now is doing a bit better.
Far as darkside goes those who do it like it & get phenomenal wear out of 'em.
Those who don't darkside question the cornering etc. There are entire threads dedicated to this one Burgmanusa.com that you may want to review.
Personally I popped for a new TH01M off the motorcycle superstore & am doing OK on it even with a fair bit of 2up. I expect 7500-8k unless I pull a nail or something.
Tromper is offline   Reply With Quote
Times are GMT -7.   It's 05:19 AM.
