Old 07-19-2010, 05:25 AM   #46
danielson OP
danielson's Avatar
Oddometer: 83
Originally Posted by Sibbo
Yep ,the standard 4 speed 500 ,a beaut little bike .I thought about doing your thing for a while and even contacted a bloke in NSW who had done it , but he had fun registering it , engineers certificate etc . He was an engineer so that kind of made his job easier but it would be harder for me ! I could register in Qld though , I've got relatives up there that would cooperate !
The Altmann mods with the longer shaft looked a bit of trouble , very impressed that you were able to do it so simply .I guess you don't know until it's all off and you can line up the holes .
Was there any way to include the electric start ? I see the downtube is in the way and the sacred compliance plate !!! but could a nice big steel plate with the correct opening have been welded on there to accept the starter ?
Altmann or someone else raised a question about the charging capacity of the alternator windings on these clones .I think the original Yamaha was better , have you had any problems running your lights ? I guess an external alternator could be rigged ,but a bit of a job !!!!!
And again , a sweet , sweet job !! I'm all inspired again .
Hey Sibbo
Thanks mate
Yeah I've heard about the holes you have to go through to get it rego'd in NSW. That sucks.
I was thinking how to make it work with e-start but like you said involves a frame chop and compliance plate movement. Though I reckon you could get away with it depends if the plate is closer to the down tube stud hole.
I have thought if the motor was lower might give enough room, but it looks like there is no chance without cutting the down tube.
I've still got to get charging stuff sorted. Running constant loss
On Altmanns site he says he made a four parts voltage regulator (using a rectifier, zenerdiode, resistor and a darlington transistor) in place of the supplied regulator with motor which was too weak. Here's a schematic
I'll probably give this a go. I'll see. It'll be interesting.
Originally Posted by raycam01_au
wow
is all i can say wat an awesome little bike, love it, gr8 work,
Thanks Ray mate
It is a great machine
danielson is offline   Reply With Quote
Old 07-19-2010, 02:11 PM   #47
Sibbo
Oddometer: 358
Electrics
I'd love to hear how you go with the charging system , I'll stay subscribed .
Good luck mate !
Sibbo is offline   Reply With Quote
Old 07-19-2010, 08:53 PM   #48
wiggywildwildwest
cranky bugger
wiggywildwildwest's Avatar
Oddometer: 760
it may be a lot less mucking around to use a motorbike reg from a wrecker. see which ones there's lots of. ( hopefully means they don't play up. ) the wiring of them is easy too. i can assist via the internerds if you require.
i used rgv250 rec/regs on a couple of bikes. worked well and were 30-ish bucks from memory.
Where you come from is gone. Where you thought you were going, Was never there. Where you are, Ain't no good unless you can get away from it.
wiggywildwildwest is offline   Reply With Quote
Old 07-19-2010, 10:16 PM   #49
desert dog
scrub basher
desert dog's Avatar
Oddometer: 1,131
WTF somebody knows whats going on, series regulator...
heaps better than 20 year old technolgy, motor cycle shunt regulator!!!
SCR are just sooooo yesterday.
good on you and ya brother .....
cheers matty
edit; try wacking in a couple of filter caps to smooth out voltage spikes.
Trailer tyres are cheaper than bike tyres
desert dog is offline   Reply With Quote
Old 07-23-2010, 05:57 PM   #50
danielson OP
danielson's Avatar
Oddometer: 83
wiggy cheers for that i'll see to it
cheers matty
DD thanks mate,
thats the smart Altmann chap who made that schematic
hmm now there's a few ways to do this
Update; not much riding but got 1000km on it now. Running well.
Old 07-23-2010, 08:36 PM   #51
PBee
_
PBee's Avatar
Oddometer: 9,410
DD thanks mate,
Go to the Guru, Steve Warnes
http://www.bettabikes.com/
He's down at Hackam.
Anything related to bike electrics.
QUORN SCHNITZEL CLUB Est 2011.
When in the FLINDERS RANGES SA stay at the
ANGORICHINA VILLAGE
PBee is online now   Reply With Quote
Old 07-24-2010, 12:35 AM   #52
dzl
adventurer wannabe
dzl's Avatar
Oddometer: 89
Cool bike....well done. Have always had an interest in diesel powered machinery and have always wanted to screw a diesel bike together. Hell...even my dog is called diesel! You've got me thinking about it again now as I have a '51 BSA B33 sitting down in the shed!
Regards the electrics, do they give a rating for the generator? It wont matter what sort of regulator you have if the generator isnt capable. A lot of those clones only have the capacity to charge the battery from what I had heard. The genuine yanmar engines have a 15A option if going to power auxillary equipment.
Would any of these regulators help? http://www.norbsa02.freeuk.com/goffyelectrex.htm
Although this would blow the budget a bit more and defeat the whole purpose of the project.....have you seen this engine made by kohler http://www.kohlerengines.com/onlinec...Number=KD425-2
Relatively new design 18.8 HP 850cc twin and is the same weight and outer dimensions as the yanmar 10HP and its clones! Would be enough power to take the bike out of the novelty category and turn it into a genuine cruiser. What you think?
dzl is offline   Reply With Quote
Old 07-24-2010, 12:52 AM   #53
FatBoyCrash
Buckle up SpankY!!
FatBoyCrash's Avatar
Oddometer: 1,138
You sly dog!!!
Holy crap your a suprise package!! What next next??? Wanna help design a self energising ignition for my airhead??
cheers matty
Built In Shed
Because chrome don't get ya home.
FatBoyCrash is offline   Reply With Quote
Old 07-24-2010, 03:30 PM   #54
FatBoyCrash
Buckle up SpankY!!
Oddometer: 1,138
Ooooohhh... nice link!
I'm tipping this one. Bit lighter and simpler. Wonder how it'd go on SVO 'though???
http://www.kohlerengines.com/onlinec...ctNumber=KD420
The diesel bike boffins use like a centrifugal/cvr style go kart clutch thing. Fairly easy to source. I'm stuffed if I can find it now!! Anyone??
Built In Shed
Old 07-24-2010, 04:22 PM   #55
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Thanks for all the info! I really like what you've done. I do suspect there's more power to be had if you can increase the upper limit of the fuel pump volume. Most mechanical diesel pumps have a screw somewhere that allows adjusting fuel flow (even if you can't adjust timing). It basically allows the "throttle" to open further. Get too carried away and you'll melt pistons and make a ton of black smoke, but usually there's a whole lot of room between oem settings and piston melting settings. You could fit a mechanical pyrometer if you really want to get fancy. I'm not sure what a max temp would be for that engine. For an old ford diesel truck engine its best to stay below 1200 deg F.
btw my experience comes from fiddling with old diesel trucks, I don't know anything specific about your motor. Principle should be the same though.
Turbos do work great on diesels, you'd still need to find a way to get more fuel into the motor to really take advantage of it. You might even pick up a tiny bit more efficiency too.
for production concerns and a gearbox, you might consider a salsbury (sp?) clutch like a snowmobile uses. I had an 8hp (stock rated power anyway) 360cc go-cart/buggy that used one. Worked great. Its basically two conical pullies with a big heavy belt and the cones slide in and out with rpm and load such that the gear ratio constantly changes - basically like a CVT. It could be a really cheap, simple way of getting power to the rear wheel. Don't know what the maximum gear range would be or how efficient they are.
I know my go-cart would top out at about 45mph (I think it was limited by gearing and max rpm governor), but it'd snap off the line really hard (overall gearing was quite low). Engine rpm (stock form at least) was governed to 3600.
it used something like this
http://www.northerntool.com/shop/too...2170_200322170
http://www.northerntool.com/shop/too...ct_35770_35770
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot screwed with this post 07-24-2010 at 04:28 PM
BikePilot is offline   Reply With Quote
Old 07-24-2010, 07:29 PM   #56
FatBoyCrash
Buckle up SpankY!!
Oddometer: 1,138
Oh!! Nice!!
I did a bit of looking and the dieselbike boys were asking if Comet had gone tits up......
http://www.suckindiesel.com/thingy/v...hp?f=23&t=1115
Hope not!!!
Built In Shed
Old 07-28-2010, 05:51 AM   #57
danielson OP
danielson's Avatar
Oddometer: 83
Thanks PBee
Thanks dzl. That B33 could be a good candidate. That's the OHV 500cc? If its got matching eng, frame numbers then I would keep it together
There's no rating for the genny, but I've asked the sellers to see if they know.
I've had a look at those regs on the Brit bike site, they have been recommended on the Dieselbike forum somewhere.
Those Kohler motors would be great, they are the same as a Ruggerini MD191, bore stroke all the same. Price is another concern new they are $4000 or so, but obviously second hand would be the go from a pump or something.
Someones inserted one in an Enfield too. Called the Ruggerfield
Builder Colin Clarke
Build photo
Looks like the down tube has to be cut.
Owner Stuart says it can hit 70-75mph and gets 90mpg Imp. 31.71 km/liter. 3.1 per 100km
Bikepilot thanks.
I've read some have tried to adjust the volume of fuel, but they ended up saying the factory settings were correct as there was too much black smoke.
Turbos have been installed on these single cyl Diesels with varying results, some say not worth it, best to have more cylinders like 3.
Sounds great that gokart you had
I did think about CVTs but then I can't live with out a clutch lever so had to stay with the stock gearbox
Originally Posted by FatBoyCrash
Oh!! Nice!!
Hope not!!!
FatBoy
I think comet is still in business. Their site is working
Old 07-28-2010, 06:57 AM   #58
overlandr
Dystopist
Oddometer: 5,926
Are there any small Common rail engines in the size range of 10-20hp?
overlandr is offline   Reply With Quote
Old 07-28-2010, 07:14 AM   #59
bumblebee1
All bikes are dirt bikes
bumblebee1's Avatar
Oddometer: 1,431
Supercherger kit.
Check this out.
It's made for 200cc to 1200cc engine.
http://www.ideaconnection.com/invent...-the-disp.html
I bet it's worth an arm and a leg.
Does anyone remember the car engine that GM converted to diesel?
They used the spark plug holes for the injector.
I wonder if it would be practical for a motorcycle?
Just a thought.
And what are you planning to do with your one and only life?
bumblebee1 is offline   Reply With Quote
Old 07-29-2010, 09:42 AM   #60
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,150
Has anybody else noticed that those Comet belt variators look a lot like a really basic scooter set-up?
Is it only me who's just realised the Kohler420 is within 10% of the Vespa 250GTS engine output?
Just saying is all.........
Who the hell would drag race a Ducati?!?!?!?!
http://www.dragtimes.com/Ducati-Mons...lip-10329.html
MODNROD is offline   Reply With Quote
Times are GMT -7.   It's 08:36 PM.
