Old 07-29-2010, 03:28 PM   #61
FatBoyCrash
Buckle up SpankY!!
FatBoyCrash's Avatar
Oddometer: 1,138
Hey mate,
Is this the donk that you used??? I've got a XL500 in the shed that is screaming for a bit o' weirdness.... :-)
FBC
http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
Built In Shed
Because chrome don't get ya home.
FatBoyCrash is offline   Reply With Quote
Old 07-29-2010, 05:24 PM   #62
Sibbo
Oddometer: 358
gearbox ?
You're going to need a pre unit box to go with it and the one I posted earlier was a bit cheaper I reckon .
Sibbo is offline   Reply With Quote
Old 07-29-2010, 07:58 PM   #63
danielson OP
danielson's Avatar
Oddometer: 83
Originally Posted by overlandr
Are there any small Common rail engines in the size range of 10-20hp?
Hey overlander
Don't know about HP output but this Tiger has a Smart Car Diesel engine installed.
Gearbox is a 6 speed Ultima
Originally Posted by bumblebee1
Check this out.
It's made for 200cc to 1200cc engine.
http://www.ideaconnection.com/invent...-the-disp.html
I bet it's worth an arm and a leg.
Does anyone remember the car engine that GM converted to diesel?
They used the spark plug holes for the injector.
I wonder if it would be practical for a motorcycle?
Just a thought.
bumblebee that sounds pretty good the supercharger and its designed specifically for the engine that many are using as well as me, the 186FE. It looks like they are only the cad drawings.
That GM petrol converted to diesel (was a disaster deliberately) gave diesel fueled passenger cars a bad rap in the states. Because of that they don't import many of the Euro diesels that achieve hi MPGs.
I've posted this before but here's a little Italian Moto Perugina 175cc petrol converted to diesel
gets 90 km per liter
close to the magic 1l/100km
Originally Posted by MODNROD
Has anybody else noticed that those Comet belt variators look a lot like a really basic scooter set-up?
Is it only me who's just realised the Kohler420 is within 10% of the Vespa 250GTS engine output?
Just saying is all.........
Modnrod I think thats what some of the scooters use.
Originally Posted by FatBoyCrash
Hey mate,
FBC
Fatboy thats exactly the same one, there very good sellers.
But like Sibbo said your gonna need a separate gearbox
danielson is offline   Reply With Quote
Old 07-29-2010, 11:09 PM   #64
Sibbo
Oddometer: 358
Charging ?
Danielson , any joy on the charging system so far ? Do the alternator windings on your engine have sufficient output for your needs ?
Do you know if the original Yanmar had sufficient charging to run lights etc ?
I was just looking at my Enfield again and wondering .................
Old 07-30-2010, 03:36 PM   #65
FatBoyCrash
Buckle up SpankY!!
Oddometer: 1,138
Nah... This is what I'm thinking.... twist throttle, off ya go. Simpler too... Cheaper too!!
http://www.mfgsupply.com/GoMiniClutc...on_id=NLzmz5QW
Built In Shed
Old 07-30-2010, 04:23 PM   #66
Sibbo
Oddometer: 358
So a centrifical clutch and is that a variable pulley ? Have you ever used a system like that , it's a bit like the Rabbit scooter from once upon a time .
I'd still prefer a clutch and gearbox for the positive feel .
Danielson , what is a comfortable cruising speed ? Is 80 km OK ? 85?
Old 07-30-2010, 07:37 PM   #67
Andreenduro
LUMI
Andreenduro's Avatar
Oddometer: 107
Diesel Enfield
Ha, thanks for putting together what I had in mind for years after I was too late to buy one of the few Taurus which were brought in to OZ years ago.
You got me thinking again...
I wouldn't be worried with the rego for where I live in Tassie...hahaha
Shame though not knowing you are in Adelaide as I was down that way on my DR only a couple of weeks ago.
Let me know if you try and sell a bike or parts and the reliabilaty of the engine. Although at about $600 for an engine probably not such a big deal.
If I can legally register them in Tassie wouldn't it be possibel to get them registered in other States when bought from here? Just a thought.
A matter of paper work I guess.
Please keep me/us posted, Andreenduro
Andreenduro is offline   Reply With Quote
Old 07-31-2010, 05:41 AM   #68
bumblebee1
All bikes are dirt bikes
bumblebee1's Avatar
Oddometer: 1,431
hmmmm, what am I getting into now.
I am considering installing this motor in a dead gs400 that I have.
I think it would work with the torque converter.
Here is the motor
http://www.princessauto.com/engines/...-diesel-engine
Electric start with coil backup.
The whole thing for under a grand.
I wish I could afford a transmission instead.
And what are you planning to do with your one and only life?
bumblebee1 is offline   Reply With Quote
Old 07-31-2010, 07:25 AM   #69
danielson OP
danielson's Avatar
Oddometer: 83
Hey Sibbo
I tried the reg that came with the motor, but like I thought; nothing
According to other Diesel riders the alternators do the job providing the reg is decent. I'm still workin on it
Yanmar do make a 15Amp alt which can be bolted on to this engine.
Your Enfields a perfect candidate for conversion
Comfortable cruising speed atm is like you say 80, 85 indicated, speedo goes into wiper mode around those speeds though.
You can wack on a 17 or 18 front sprocket to get more
Andre thanks. Woah you nearly bought a Taurus How much were they back then?
Yeah I've heard Tassies good for rego with modded machines. It's similar here too.
Engine reliability has been tops for the past 1000km. If it can do that then hopefully 2K then 3k, 4k, 5, and so on
And yeah if it goes south then they are cheap as. Also just found a cheap parts supplier for these motors in WA. Pistons, rockers etc
I reckon your right with rego in Tas, and again the paperwork for eastern states.
Ssshhh that was my plan; make em and rego here then send interstate
Here is the motor
Hey Bumblebee
That would work, has been done before.
I think you may have to cut the frame work. Then weld up a new cradle into the frame to house the Diesel motor
That is damn cheap
130mpg machine for under a grand
You can cut the gearbox from the motor also, a bit of work involved. Make a separate case for it. Someones done it too
This dudes used a UJM and cut the box out.
The kicker has been slipping lately so after a bit of reading what to do I found out the pawl has to be replaced. This is a small part in the GB
I was happy when the part to be change was a bit mangled. New part on right.
Pawl sits in his chair all snug
The Albion cogs
Now just gotta put the front cover on and should be good
Old 07-31-2010, 07:43 AM   #70
bumblebee1
bumblebee1's Avatar
Oddometer: 1,431
I was just looking at the little diesel engine again and realized I can remove the coil crank and fit an alternetor there.
This is becoming simpler as we go along.
Old 07-31-2010, 03:19 PM   #71
Sibbo
Oddometer: 358
Gearbox
Danielson , if your gearbox suddenly freezes solid it may have done what mine did , drop a 15mm section out of the primary kickstart gear and jam up solid ! A bit of a surprise but not a huge job to repair ,a puller got it off and some heat got the new one on .Replaced the pawl at the same time , it was quite beat up too .
Old 08-03-2010, 01:32 AM   #72
Andreenduro
LUMI
Oddometer: 107
Price for Taurus diesel
Hey Danielson,
the price list is from the 1'st of November 2000
The diesel was by far the cheapest Enfield !!
The standard 324 diesel was $3850 incl. GST
The Taurus Cargo diesel was $3950 incl.GST
Cargo meant that it had a rack and a sari guard so yer missus would not be dragged into the rear wheel while riding along. Above the gearbox it had something which looked like a little chook pen...hahaha. And it came in yellow. That was the one I wanted!
When I finally made up my mind the first batch of ten or so was sold and new emission shit regulations stopped any further coming in...
And that was that.
The engine has 6.5bhp @ 3600 rpm and 1.48 kgm @ 2500 rpm with the 4 speed box. It claimed 70 km per litre... no more to say.
Interested to see how you go,
cheers, Andreenduro
Old 08-03-2010, 02:36 AM   #73
Sibbo
Oddometer: 358
Emissions
I talked to the NSW rego mob today and I see pain in getting an industrial diesel registered here !
I know it has been done and if anyone knows more about this , please tell !
Old 08-11-2010, 07:43 AM   #74
danielson OP
danielson's Avatar
Oddometer: 83
Update
Not much but got 1300+ kms on the Diesel E, all running well.
I last filled up 3 weeks ago
Done 627km and still a few more liters left in the tank.
Sibbo thanks I'll keep it in mind, it should be fine though. The box is working perfectly.
I mucked around with the charging circuit to learn a few things.
Connected two wires from the alternator to the two wires from the regulator and wiring harness, got the motor running.
Got the revs up and the ammeter needle moved to the right and started charging
Problem is it don't charge enough only 3 or so Amps so I reckon the dynamo is a 3A one.
I'm gonna have a go at the Altmann electrics. Its gonna be the cheaper way.
Contacted Yanmar about their dynamos, they tell me their 15A one costs 260AUD
Then there is another way, remove the current dynamo, strip the old wiring and rewind it with thicker copper wire more times around each post. Gotta take the flywheel off for that though.
It really is sad when this is one type of machine they should be encouraging to build. The effect on the surroundings is minimal. You gotta wonder sometimes
Theres always a way around things though
Hey Danielson,
And that was that.
cheers, Andreenduro
Not bad prices on those Diesel T's
They could be collectors items now here
70kmpl is awesome
The Vic Enfield importer still has one Taurus I think, asked him how much and he said something like 15K He's dreaming
That was a year or so back
Old 08-11-2010, 03:01 PM   #75
Sibbo
Oddometer: 358
I reckon I'd be talking to Yanmar ...15A of REAL electrical engineeering ! YEAH!!!
Times are GMT -7.   It's 08:38 PM.
