Old 08-14-2010, 05:10 AM   #76
Andreenduro
LUMI
Andreenduro's Avatar
Oddometer: 107
diesel
By pure chance at a garage sale today got a Lombardini 325 cc Diesel today. Starts first pull !! So there ya go. Part one I've got the heart. Anyone got a rolling frame of an old english bike? Or a workshop manual for a 520 Lombardini? If my project takes shape I'll keep ya posted.
Thanks for inspiring me again anyway.
Cheers, Andreenduro
Andreenduro is offline   Reply With Quote
Old 08-14-2010, 05:18 AM   #77
Sibbo
Oddometer: 355
The more the better !
Sibbo is offline   Reply With Quote
Old 08-16-2010, 03:13 PM   #78
icekube1
Middle aged git
icekube1's Avatar
Oddometer: 1,831
Cheers, Andreenduro
http://cgi.ebay.com.au/ROYAL-ENFIELD...AU_Motorcycles
Cheers
Mike
Why stand when you can sit down..
Why sit when you can lie down..
icekube1 is offline   Reply With Quote
Old 08-16-2010, 05:27 PM   #79
Andreenduro
LUMI
Oddometer: 107
diesel power
Thx for the link Mike. Too big a project. I know these things. At the end you spent as much money and a lot of time as buying something with a busted engine but the rest is in working order.
I'll keep my ears to the ground for a cheap 350 or 500. Also need to consider the freight to Tassie.
There hasn't been a morning so far without me going up in the shed to start the donk up. What an invention!!
Cheers, Andreenduro
Old 08-16-2010, 06:31 PM   #80
icekube1
Middle aged git
icekube1's Avatar
Oddometer: 1,831
Cheers, Andreenduro
Half your luck.
I wondered if there wouldn't be a market to re-sell the origibal engine out of the ebay bike, seeing as it's had so much dome to it and all.
Might be temptyed myself...giving back the company car in a couple of weeks, starting new job. The idea of a 100km/l commuter is very tempting...no freeways.
Cheers
Mike
Old 08-16-2010, 10:10 PM   #81
danielson OP
danielson's Avatar
Oddometer: 83
Andre top stuff hope you get that done in the near future when you get the donor Enfield.
Those diesels when stationary are great fun to play with
Mike
One 1951 RE like that in ratty nick but all complete on ebay in Melb went for 600 bucks. That was few months back. Nearly won that one.
danielson is offline   Reply With Quote
Old 08-17-2010, 02:24 AM   #82
Dirt_Boy
Dirt_Boy's Avatar
Location: Adelaide, Australia Home of Coopers Pale Ale MMMMM
Oddometer: 234
Just a little more on the Diesel Motorcycles
Hi Guys Spotted this link some time ago..very cool stuff
http://www.neander-motorcycles.com/s...u/main_en.html
Dirt_Boy is offline   Reply With Quote
Old 08-18-2010, 06:20 AM   #83
danielson OP
danielson's Avatar
Oddometer: 83
Hey DirtBoy
They are nice but very pricey at around 85,000 USD
Each piston has two rods that balance the motor
Old 08-19-2010, 12:31 PM   #84
snoopy
Oddometer: 265
I'm building mine starting this weekend, it'll be identical I've even got the same Yellow covered Yanmar clone. Fitting the original alternator is supposed to be a bit of a pain.
Ultimately you can stick an LED rear, LED indicators, LED sidelamps and a HID 35W in the front - that will take the consumption down to less than half when braking and indicating!
RTW on a Honda PCX Scooter soon.
http://www.andrewcharnley.com
snoopy is offline   Reply With Quote
Old 08-19-2010, 08:31 PM   #85
danielson OP
danielson's Avatar
Oddometer: 83
Hi Snoopy
Hope it goes well
Yeah that would be good to lower electricity consumption.
If you can try to get the Yanmar 15Amp alternator instead of the Chinese low output one.
They are dear but worth it from I have read.
Old 08-21-2010, 02:15 AM   #86
snoopy
Oddometer: 265
The petrol is very nearly out. It looks like four long bolts go through the gearbox into the engine, I've undone the nuts but extracting the engine looks impossible if its slid sideways as it bumps into the frame, thus not allowing the bolts to come out. I'll have to take another peak later on.
Old 08-21-2010, 04:02 AM   #87
danielson OP
danielson's Avatar
Oddometer: 83
Snoopy
If you have everything off the frame, its best to lift the frame off of the engine and GB. Its much easier.
Have you seen this?
in your neck of the woods
http://www.classicsuperbikes.co.uk/p...-Yanmar-Diesel
Wonder how much it costs?
Old 08-21-2010, 04:25 AM   #88
Sibbo
Oddometer: 355
Originally Posted by danielson
Very sweet !
Old 08-21-2010, 11:04 AM   #89
snoopy
Oddometer: 265
Engine and gearbox off!
Got to order the sprocket now and then I'll get welding.
Old 09-09-2010, 02:14 AM   #90
danielson OP
danielson's Avatar
Oddometer: 83
Hi Andrew
hope this helps
answer for
a) The cable coming out from the diesel alternator has two connectors. Just connect those two (from diesel alt) to the two petrol white and green cables. They lead to the original rectifier. This should power the lights off the diesel alt. So no lights when engine not running. Looks primitive but works
b) to get the height place the motor on blocks just like here. Get a spirit level to be sure. Move it where its supposed to sit under the frame.
Mark out the holes on the inner primary as per the engine ones. Takes a bit of measuring to get it square. I drilled three only but used two diagonally. Top right and bottom left.
Then get the inner primary. Place it on the gearbox shaft and bolt to the motor. Shaft distances will be the same as the petrol.
with the back plate, weld up the 90 deg angle first before drilling. If you want to bend the steel do it here to.
then you g clamp it to the gearbox. Get the right height and level it (with a spirit level) with the engine on the same blocks next to it. As the motor wont fit under the frame when the g clamp is on the gearbox.
Then you can drill holes on the back plate as in photo earlier.
c) damn i wish i took photos of the throttle set up.
heres a few hard to see though
from what i remember how it looked like
d) buy a y piece
the diesel excess hose from the injector and the fuel tank hose connect to it. bottom outlet connects to fuel filter then to fuel pump on motor.
e) dont use the decomp lever to kill the engine its not advised. i made another cable from the handlebars that pulls the govnr and turns fuel supply to engine off.
Times are GMT -7.   It's 12:35 PM.
