Old 07-16-2010, 04:06 PM   #31
davsato
Oddometer: 753
my beergut makes a good table, when im sat down in my camp chair i can easily balance a mug of tea or a bowl of grub on it. too hot for beer
davsato is offline   Reply With Quote
Old 07-29-2010, 06:43 AM   #32
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,645
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 12-18-2012, 12:01 AM   #33
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 256
I bought this sturdy, folding aluminum table at Walmart for about $23:
It's a good size, but the idea was to modify it to fit nicely on top of my Pelican 1550 top box:
Although after the mods it's low, the height will be good for use with a camp chair, and certainly better than placing the kitchen on the ground:
Mission accomplished:
Cheers, all!
ElMartillo screwed with this post 12-18-2012 at 12:06 AM
ElMartillo is offline   Reply With Quote
Old 12-18-2012, 04:25 AM   #34
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,342
I use my Vario top box. I'm already carrying it and the top is "flat enough" for most things.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 12-18-2012, 05:37 AM   #35
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,416
http://www.amazon.com/RIO-Adventure-...837629&sr=1-39
A currently available version of the 18" GCI and L.L. Bean Table we discussed earlier.
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 12-18-2012, 05:40 PM   #36
AlanCT
The Byronic Man
AlanCT's Avatar
Oddometer: 2,876
Cheers, all!
I have the same table, unmodded, which I take along sometimes in the Ural if I know I'm going to be camped in one spot for multiple nights.
How did you mod it? Just chop the legs?
"You wouldn't be riding a motorcycle if you weren't an optimist."
- Matthew Crawford
2005 Ural Tourist, 2003 Kawasaki Concours
IBA #23064
AlanCT is offline   Reply With Quote
Old 12-18-2012, 06:45 PM   #37
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 256
First I changed the pivot points of the table-top halves, took 5/8" off each one, which saved me 1.25". Then I removed the two outer slats from the table top, saving another 2.5" off the folded length. I then chopped the legs and brought the cross members (and feet) up as close as I could to the tops in the flat, folded position. Last I moved the pivot point of the legs.
Final dimensions are 18.5"w x 14.5"d x 12"h open, 18.5" x 16.25" x 2" folded.
It took a little time, but I got what I wanted. I don't much care for the cookie-cutter solution anyway.
I should mention I only included the Pelican case in the photos to show scale, not to indicate that I intend to use the table as a suitcase stand.
I like the table, and I'll probably get another and keep it original-size and in the Land Cruiser for 4-wheel desert runs.
If you want a more detailed description of my mods let me know.
Cheers!
ElMartillo screwed with this post 12-18-2012 at 09:37 PM
Old 12-19-2012, 12:30 PM   #38
Skizzo
Skizzo's Avatar
Oddometer: 8
Diy! :)
I've built this...
http://www.instructables.com/id/Make...s-in-the-park/
it's cheap, stable and small when folded.
But most of the times i use an aluminium plate placed between sidecases.
Like the one sell by touratech, but much cheaper
"No plan is a good plan"
Skizzo is offline   Reply With Quote
Old 12-19-2012, 07:52 PM   #39
ChadHahn
Oddometer: 178
I have a plastic table similar to this that I picked up at a thrift store. I should check to see if it is small enough as it is to fit on my bike.
I picked up a couple of the GSI/LL Bean type tables at Target last year when they were clearing them out. They worked well.
Chad
ChadHahn is offline   Reply With Quote
Old 01-13-2013, 01:44 PM   #40
bob393
bob393's Avatar
Oddometer: 369
Originally Posted by drecian View Post
I just use one of those cheap roll-up aluminum tables from K-Mart. Packs in a duffle along with my chair/sleeping mat/tent strapped across the pillion seat. Just under the width of the panniers and if it breaks, it was only $15 and I can find another pretty much at any store.
Thats what I use. Cheep and solid.
2007 R1200GS almost farkeled to perfection!
bob393 is offline   Reply With Quote
Old 01-14-2013, 10:09 AM   #41
OaklandStrom
Oddometer: 1,490
I have the REI rollup aluminum table (http://www.rei.com/product/765280/rei-camp-roll-table) that I take car camping. I guess I could take it bike camping, but I don't.
This, however, is one of the more useful camping items out there.
http://www.amazon.com/Tricam-WP-20-B...186808&sr=1-10
It's a low table, stool, bench, work bench, whatever. I have a different brand that wasn't $60. Actually, I have several. If I take the truck camping, I'll end up having more than one with me.
It would suck on a bike.
OaklandStrom is offline   Reply With Quote
Old 01-14-2013, 02:00 PM   #42
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,615
If you must have a table- camp time roll-a-table
one table to rule them all.
sturdy- rolls up - coated so you don't have stuff fall in between the slats so ez clean
http://www.rei.com/product/378009/ca...3-001b2166becc
rolls down to 6" x 32"
Very popular at Everest base camp
That'L do Pig,, That'L do
rboett is offline   Reply With Quote
Old 01-15-2013, 08:35 PM   #43
Montauk
Oddometer: 260
Can you show pictures of the side angle along with new pivot point at the sides. And another showing the bottom closed and fully extended.
Thanks. I liked way you did. I don't quite like the 18" REO Roll-Top Table, it's the packing I don't like. I want to make it even smaller and low eight to fit my Kermit Chair.
Montauk is offline   Reply With Quote
Old 01-16-2013, 09:24 PM   #44
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 256
Thanks, I'll take more photos and post within a coupla days.
Cheers!
Old 01-17-2013, 05:39 AM   #45
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,615
That's what we need, a Kermit Table!
Times are GMT -7.   It's 01:45 AM.
