01-17-2013, 10:17 AM
#46 |
Archvillain
Oddometer: 30,420
![]() Here's ADVMax choking his chicken in my Kermit chair and 18" roll-top table. 8" seems like it'd be a little low.
Every saint has a past and every sinner has a future. If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl. Xeraux screwed with this post 01-17-2013 at 10:25 AM |
01-17-2013, 09:29 PM
#47 |
Oddometer: 260
01-17-2013, 09:58 PM
#48 |
I See Faces...
Oddometer: 256
To clarify, the table I modified ended up 12" high.
It is a bit low, but useful for most camp chairs. |
01-17-2013, 10:32 PM
#49 |
Oddometer: 9,698
I've used one of these for years for car camping....
but carrying any table on a motorcycle seems to me to be over that admittedly gray line between carrying stuff you really need and carrying crap that mostly overloads the bike. - Mark |
01-18-2013, 05:18 AM
#50 | ||
Archvillain
Oddometer: 30,420
Every saint has a past and every sinner has a future. If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl. |
01-18-2013, 05:58 AM
#51 |
Tundra Thumper
Oddometer: 2,226
DONATE TO ADVRider sidestandup.com ridedualsport.com motoboss-terlingua-bound.blogspot.com MSF Rider Coach-Rider's Edge Instructor-Track Coach |
01-18-2013, 06:04 AM
#52 | |
Archvillain
Oddometer: 30,420
The one in the picture is the original GCI table, but this one is exactly like it even down to the little velcro loops for hanging a grocery bag to use for trash.
01-18-2013, 06:30 AM
#53 | |
Tundra Thumper
Oddometer: 2,226
Thanks.....
01-18-2013, 09:22 AM
#54 |
Bon Vivant
Oddometer: 672
I found this on Ebay and it looks very interesting. Comes in three sizes and under 2 pounds. Called the Buck703
Somebody buy one and give use a review... http://www.ebay.com/itm/New-Black-Li...-/190709993624 ![]() ![]() .
Michael...... (that's a pretentious Mike) aka beatnikmike Misanthropist... Everyone seems normal until you get to know them. All education is liberalizing |
01-18-2013, 10:26 AM
#55 | |
Mentally Retired
Oddometer: 1,112
West - "Oeste Sanchez" |
01-18-2013, 11:15 AM
#56 |
Bon Vivant
Oddometer: 672
West:
Me! ….. It's not for me….. I would neverrrrr....... well Many of the inmates of this asylum are forever in search of the lighter more compact gadget. So they may make their outdoor experience even more like an indoor experience. I was simply providing a service by passing on information to aid them in their quest for more and lighter stuff. But back to me …. I am perfectly happy to set my cozeeeed beer on a dead possum in fact if said possum is not to long dead they make a mighty fine pillow and not bad smoking either….. .
01-18-2013, 01:34 PM
#57 |
Oddometer: 2,079
Talking about Ebay and chinse stuff...you can find these folding tables there too, for less than 50$:
![]() ![]() I don't dislike the aluminium one. Not sure I'd use it but it looks cool.
2010 Buell Ulysses 1984 Suzuki GR650 "Tempter" |
01-18-2013, 06:23 PM
#58 | |
I See Faces...
Oddometer: 256
First, I removed the two outer slats by drilling out the rivets underneath: ![]() KEEP IN MIND, THE FOLLOWING PHOTOGRAPHS ARE POST-MODIFICATION. Next, I trimmed off the slat supports, as close to the remaining slats as possible, using a file to remove burrs and sharp corners: ![]() I then removed the leg supports by removing the round plastic buttons and drilling out the rivets. I then moved the support as close to the slats as I could with the table closed, and re-riveted. The aluminum is so thin you don't really need a drill, you can push a hole through with a punch. After riveting, replaced the plastic buttons: ![]() After the above step, I removed the plastic "feet", and chopped the legs. Replaced "feet". Lastly, I changed the leg pivot point. To do this you'll need to drill out the existing rivets, and replace with a coupla binding rivets. I also used nylon washers. The binding rivets can be purchased at Home Depot. This is a stock photo, they are not the length I used: ![]() I picked a point about halfway down the new, shorter legs. You can see the old pivot holes circled in red: ![]() Final dimensions are 18.5"w x 14.5"d x 12"h open, 18.5" x 16.25" x 2" folded. I hope this helps! Cheers
01-18-2013, 07:02 PM
#59 |
Oddometer: 51
I had been thinking about the need for a Table Shaped Object (TSO) for a couple of years whilie struggling with all sorts of makeshift arrangements. Recently I added a single seat and wooden pack rack to transform my old R90 into a sort of up-market postie bike. I also made some new soft bags to go with this setup. To mount the bags properly I then needed some Rack Shaped Objects (RSOs). At this stage it dawned on me that two connected RSOs looked pretty similar to a TSO, if a lid could be added. So here is my particular DIY solution.
The RSO / TSO sitting inverted on the wooden rack. The black stuff is rubber sheet. The lid is 9mm hardwood marine ply with a few coats of marine varnish. Legs are 6mm stainless rod, Bars between legs are 25x3 and 40x3 stainless. I ground rounded points on the feet so they can stick into the ground if necessary. Bags hanging off the subframe with the TSO in place. There is a bit of soft grippy material to protect the rack. ![]() Bag straps tensioned over the TSO to hold it all together, and my bedroll pack on top. ![]() I've done about 2500kms with this setup. The TSO has proved its usefulness, but I'm now looking for a bigger bit of marine ply. The table could be somewhat larger in length and breadth. O and here is a shot of the sort of use the table has been getting.
Cheers Charlie, and the lovely Brunhilde (74 R90/6) |
01-18-2013, 10:35 PM
#60 |
I See Faces...
Oddometer: 256
