Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 11-25-2012, 03:46 AM   #15031
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 297
Originally Posted by briansoren View Post
Just wanted to show the old girl off! Finally think I have all the additions complete.
Very nice. Now please go out into the hills and smash it into the ground a few times so it looks decent.
Lusting for: Currently Sated with the new XCx
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2015 Tiger 800 XCx -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster, 2011 800 XC
Mr_Chris is offline   Reply With Quote
Old 11-25-2012, 03:59 AM   #15032
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 297
Originally Posted by Mercury264 View Post
So on my last trip I got the dreaded 'won't idle' condition after riding in some very dusty conditions. I managed with it though but as winter is here, I figure time to do some maintenance and I have a few questions...
1. stock air filter looks toast - that said, can I blow it out and re-use it ? I am going to fit my Uni pre-filter this time round.
2. I have what appears to be a breather pipe left over from somewhere It's near the front on the right as you sit on the bike - it's not one of the 2 that go into the tank at the back - is it a crank breather maybe ?
3. I cleaned the stepper motor etc. - where are folks putting the grease - just under the rubber boot or basically all over the shaft etc. ?
Cheers
1. You've taken it all apart. Don't save a few bucks now, do it right. Put on a good / pre-filter not required filter. Sure you can run with less, but a pre-filter is extra, not replacement filtration. It is also exposed and could be torn or pinched over time (as unlikely as it may seem at the moment) and you don't want to find out you've been running dirty air at the point you discover the tear.
2. Sorry I can't help you there.
3. Take the shaft and bushing off and clean them with solvent etc. Then (clean finger) put some decent waterproof grease on the shaft all round, then mount the bushing with a tiny bead of grease over the ends of the bushing. So put a bit on each end, then slide it over, and the grease seals out the dust from getting in. It makes no difference if anything sticks to the grease, the problem is the grit getting INSIDE the bushing. The grease on the shaft lubes it and fills the gap, and the buildup on the ends seal out the dust. Then just have 'em do it once a year or whenever you have some reason to take the air box off IMO.
Last ride I saw 3 tigers (out of 20) pull up with the idle problem during 2 days offroad. They all said, I never thought it would happen to me. If you're down under you got it worse apparently, and if you're like me and can't keep up with the Gods at the front, you'll end up riding in some dust sometimes. Nice fine Aussie dust rawr! I was so happy I had mine all lubed up!
Chris
Old 11-25-2012, 04:56 AM   #15033
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,452
I've been doing the roadside WD-40 dance lately. This seems like a fix, and I can't help but wonder why the fudge Triumph hasn't issued a recall on this issue. There are some folks out there that are swearing off Triumph because they aren't mechanically inclined enough to take care of this, or don't do the internet. As of last week, my local dealer still claims to not have ever heard of this problem
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-25-2012, 06:57 AM   #15034
ducnut
Oddometer: 3,320
That looks great!
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 11-25-2012, 07:23 AM   #15035
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,419
Must say, although I have the Triumph gel seat, I always carry that same Airhawk with me for long trips. Also, fashioned a wooden beaded seat pad from a car type that works great for long jumps.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 11-25-2012, 08:20 PM   #15036
briansoren
Oddometer: 15
It has been in many hills. I just didn't show everyone the other side.
Thanks jmcg and ducnut!
briansoren is offline   Reply With Quote
Old 11-25-2012, 08:52 PM   #15037
ravlin
Oddometer: 5
n00b checking in, Hi everyone.
Being the newest n00b here, I will go ahead and take the above advice as well, sans compliment as I am still figuring out this whole forum thing (posting anyways, been a creep for a couple years) and you all know what a stock black XC looks like anyway.
Given the 1000+ pages of glory here, I am sure it will be a while before I can find something worth saying... so beware the sarcasm
Triumph Tiger 800 XC... Pastel Black and bone stock
ravlin is offline   Reply With Quote
Old 11-26-2012, 07:23 AM   #15038
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,261
Originally Posted by Rob Dirt View Post
You should use some all purpose spray lube that does not attract dust as bad as grease. Lube the stepper arm & the throttle roller. The throttle roller is located where the stepper motor arm is going.
I would replace the air filter.
Thanks Rob
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 11-26-2012, 07:26 AM   #15039
Mercury264
Mercury264's Avatar
Oddometer: 22,261
Originally Posted by blacktiger View Post
1. I would do what I've done and fit a DNA or K&N filter because, with the pre-filter you don't need the full filtration of a stock filter. This is mine after 6K behind the pre-filter
The pre-filter does most of the work...
I don't think I'll ever need to get into the airbox ever again.
2. Don't know.
3. Refer to what Rob Dirt wrote.
Chris
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 11-26-2012, 07:29 AM   #15040
Mercury264
Mercury264's Avatar
Oddometer: 22,261
This is the hose that I mentioned in my previous posts:
And my air filter (approx 10K miles):
I have to say, I did like the fact that Triumph put in semi-captive screws etc. where there is a possibility that said screw might fall in the throttle bodies. Nice touch.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 11-26-2012, 11:27 AM   #15041
briansoren
Oddometer: 15
Is that with or without a pre-filter?
Old 11-26-2012, 11:29 AM   #15042
Mercury264
Mercury264's Avatar
Oddometer: 22,261
Without - I have a pre-filter that I plan on fitting once I get a new air filter. BTW, the other side of the filter was spotless so it was clearly doing it's job.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 11-26-2012, 04:53 PM   #15043
OneWheelDrive
OneWheelDrive's Avatar
Oddometer: 286
Originally Posted by Dr. Doofenshmirtz View Post
Onewheeldrive.net is testing the Tiger800XC right now and i'm following their posts on facebook.
Hey thanks for the post, we've finished the video review of the bike:
Neil Johnston
Tiger 800XC and Tiger Explorer 1200 Review Video: http://www.youtube.com/watch?v=X4fbnw6De24
OneWheelDrive is offline   Reply With Quote
Old 11-26-2012, 08:05 PM   #15044
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,251
Hmmm...the back and forth was just a little distracting. "Motorcycle journalist" is a real job?
"Irregardless" is not a real word.
Glad you mentioned the Explorer being updated to more XC function. Still, it's a hundred pounds more than the 800 which is already too heavy for real offroad going. Funny, the terrain is always pretty darn flat. Try 3' sand whoops, or a field of baby-head boulders.
Anyhoo, I do like mine, wouldn't trade it for anything else....yet.
Nice scenery, great place to ride, eh? No, I didn't hear enough 'eh's' and there was no 'aboot'.
I think I'll ride mine up there next summer. Back to my birthplace.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 11-27-2012, 05:37 AM   #15045
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,868
I should emphasize that my photo, quoted by you above, shows the dirty side of the DNA filter. So, as I wrote, the pre-filter does most of the filtering.
It makes me wonder if we need to fit a filter inside the airbox at all when we're using the pre-filter.
Oh, and, I found an easy way to remove the pre-filter from the airbox. The rubber is flexible enough that you can just insert a flat blade screw driver in the middle at the top, and push it right through, and it'll lever out nicely.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger screwed with this post 11-27-2012 at 05:43 AM
blacktiger is offline   Reply With Quote
Times are GMT -7.   It's 11:12 PM.
