Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 12-28-2012, 07:48 PM   #15241
doxbike
Oddometer: 269
Originally Posted by elan View Post
I want handguards for my roadie to block the wind and rain. I was prepared to pay for the barkbuster storms, but most places are out of stock from what I've seen.
Is there any reason why I couldn't just order some of the MUCH cheaper moose aluminum handguards with the fat bar mounts and mount them on my tiger? What am I missing here? Why are the barkbuster / touratechs so freaking expensive?
I have the moose setup on my motard CRF 450, so maybe I'll try swapping them over to see...
I tried the Ascerbis, but the aluminum bar was hitting the brake reservoir, don't know about the Mooses (Meese?)
doxbike is offline   Reply With Quote
Old 12-28-2012, 08:38 PM   #15242
pilot3
Oddometer: 402
I'll just add a quick comment. I actually researched the whole hand guard issue at length before I bought my Barkbusters. I couldn't figure out why BB through TwistedThrottle were so much more than buying from BB.
I emailed BB and they spelled it out for me. Basically the Tiger has a different bar contour along with the placement of its controls so all the normal configurations don't match up. BB designed a special set to simply bolt up to the Tiger bars. That's what you're paying for.
I bit the bullet and bought them and it was worth every penny. I also got the bar end weights which are awesome too but did require me to purchase some additional bolts. I'll try to elaborate more later.
p3
pilot3 is offline   Reply With Quote
Old 12-29-2012, 08:29 AM   #15243
Kawidad
Kawidad's Avatar
Oddometer: 4,747
Originally Posted by burgerking View Post
Or buy one of these things
http://www.triumph-sbf.de/Dateien/pr...76ba9ee1ae732e
seems a neat solution and not as prone to breaking as the larger huggers.
Holy crap 149 Euros!!!
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 12-30-2012, 03:26 AM   #15244
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 293
p3
I have bark busters on my tiger and I completely, utterly HATE them. They don't fit unless you bend them a bit here and there, and then they are tight as buggery and require moving the banjo on the master brake cylinder -- no answer for the kink in the clutch cable. You can either run your levers too high or too low or else wedge the clutch cable over the mount.
Perhaps the fact that they suck on Tigers is why there is this "special set". DO NOT BUY THEM otherwise unless you're a short person perhaps things might line up for you then. I've been close to buying a second set of HDB guards and I'm still suffering because I don't want to throw away my investment. And I feel like I should use the Aussie product but it's hurting me let me tell you.
Lusting for: Currently Sated with the new XCx
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2015 Tiger 800 XCx -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster, 2011 800 XC
Mr_Chris is offline   Reply With Quote
Old 12-30-2012, 06:23 AM   #15245
mjr
mjr's Avatar
Oddometer: 26
Send them my way if you don't want them.........
mjr is offline   Reply With Quote
Old 12-30-2012, 07:51 AM   #15246
fbj913
I ride
fbj913's Avatar
Oddometer: 2,354
mine works fine. you can move the reservoir.
fbj913 is offline   Reply With Quote
Old 12-30-2012, 09:37 AM   #15247
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,462
FWIW and maybe only pertinent to those seeking the extra weather protection of the bark buster storm guards over OEM and not worried about having a full aluminum brace attaching to the inner part of the handlebar, the bark buster end mount only guards work fine on the tiger and are a little cheaper. They bolt up in a few minutes.
http://www.twistedthrottle.com/barkb...ar-end-inserts
swimmer is online now   Reply With Quote
Old 12-30-2012, 09:47 AM   #15248
some call me...tim
some call me...tim's Avatar
Oddometer: 279
Interesting, I put mine on with minimal effort and everything lines up pretty well. I did have to adjust the brake line a smidge, and ran left side bark buster between the clutch cable and the electrical wires. Everything seems fine to me. Did you get the "non-special set" or something?
some call me...tim is offline   Reply With Quote
Old 12-30-2012, 10:16 AM   #15249
jmcg
Turpinated..
jmcg's Avatar
Oddometer: 448
Bark busters fit well on my (wife's) Tiger, nil adjustments required.
Very pleased with the product.
JM.
jmcg is offline   Reply With Quote
Old 12-30-2012, 01:42 PM   #15250
elan
Oddometer: 128
Thanks guys, I figured as much. Just eying up the handguards between my CRF and the tiger bars, I could tell there would be interference on the left side with the cables. I know they make some of the mounts that go around the cables, but then there's the bar contour issue. In all honesty, I'll probably just go with the barkbusters. I'll just have to stay home and drink for a few weekends instead of going to the bar to justify it
p3
I'd honestly probably be fine with something like this as I don't see myself going offroad.
elan screwed with this post 12-30-2012 at 01:48 PM
elan is offline   Reply With Quote
Old 12-30-2012, 06:34 PM   #15251
ABHooligan
The Flying Mythos
ABHooligan's Avatar
Oddometer: 1,123
Handguards
I installed Acerbis Mutli-Concept guards. They come with large and small shields, and metal mounting hardware. Probably not as strong as HDB, but a lot cheaper than Barkbusters from Twisted Throttle. I didn't have any interference with the bike controls.
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost."
James Dickey
ABHooligan is offline   Reply With Quote
Old 12-30-2012, 06:45 PM   #15252
cug
Oddometer: 4,858
Barkbusters work great protecting the bike:
cug is offline   Reply With Quote
Old 12-30-2012, 11:30 PM   #15253
Vzuke
Vzuke's Avatar
Oddometer: 145
BarkBuster Mod
I wasn't to happy about the BarkBuster mounts. So I threw more money at it!
I didn't like how the clutch cable had to go up and over and if you adjusted the clutch mount below it wasn't comfortable.
So I found some Moose racing mounts that you could buy separately.
Of course the brake side wasn't really a problem but I needed symmetry.
I need to find some better wind protection than the Barkbuster covers provide. Sometimes form doesn't provide function even with the little lip extensions in place.
Vzuke screwed with this post 12-30-2012 at 11:33 PM Reason: lost picture
Vzuke is offline   Reply With Quote
Old 12-31-2012, 12:07 AM   #15254
spacekadet
Oddometer: 226
Originally Posted by Vzuke View Post
I wasn't to happy about the BarkBuster mounts....
Those Moose mounts look really good. I just did a quick search for them and found loads of different types. Which model is the one you fitted?
spacekadet is offline   Reply With Quote
Old 12-31-2012, 03:19 AM   #15255
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 293
Yeah. I just went into the Peter Stevens dealer where I bought the Tiger and asked for the Barkbusters. Figured that because I am tall and have the bars rotated up and the risers etc, it must be my fault... so I popped them in the vise and did some gentle persuading. They got lined up good but then I realised when I did the left side that the clutch cable was smack dab in the middle of the mount... after I had just moved the banjo to get around the other one.
I don't have a good idea to fix the clutch as it's not movable like the master cylinder banjo bolt. So I have it jammed against the mount with some sheet metal wrapped around it as sacrificial rub protection. Looks shit and when I decided I would adjust my bars a bit different I realised I had customised the bend for this specific configuration so I would need to take the vise to them again.. And then they'd be hard-wired for THAT config. feck that.
Those moose mounts look like they would solve the clutch cable problem though. Thanks for telling us about those.
Times are GMT -7.   It's 09:23 PM.
