Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 01-10-2013, 05:18 PM   #15316
ducnut
Oddometer: 3,301
Originally Posted by swimmer View Post
I think all road bikes just have a rivet type master link and everyone just cleans it on the bike. Is this your first road bike/motorcycle? Obviously if you are wanting to take the chain off you'll have to grind it off. And then either put a new rivet link on or a clip type link in which case I'd use the same brand as the chain.
A chain tool will press out the pin, with no grinding necessary.
Originally Posted by browneye View Post
Master links are riveted on roadbikes. You can get a new one from your parts house, but they're pretty tough to do without a riveting breaker tool. They don't cost that much. You could use a clip type link but most prefer a revited one for a bike that will do over a hundred.
Safety wire is what I do on a clip-style link.
Not a good idea to 'soak' an o-ring chain. The o-rings keep the grease inside the rollers and the dirt outside. Depending on what you're soaking with, can seep into the roller internals, and/or breakdown or swell the o-rings.
Agreed.
Better to hose it with WD and wipe down, use a wire brush to remove caked on lube/dirt mixture. Then apply a good chain lube.
Do not use a wire brush, as it will tear up the O-rings. There are plenty of plastic-bristle, parts-cleaning brushes available; even a stiff toothbrush will work.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 01-10-2013, 05:25 PM   #15317
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,478
So, you are saying you push the pin out without grinding the head off first? That's fucked up.
swimmer is online now   Reply With Quote
Old 01-10-2013, 06:09 PM   #15318
Oshiat
Oddometer: 157
That's the way its done. The heads are rounded over with a press when the chain is assembled. A chain tool will press them out with no problem. Never heard of grinding the head off first.
Oshiat is offline   Reply With Quote
Old 01-10-2013, 06:11 PM   #15319
ducnut
Oddometer: 3,301
Yes. A nice chain tool (RK is what I have) will push it right out.
'96 Ducati 900SS
Old 01-10-2013, 06:27 PM   #15320
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,478
I don't see the point when grinding the head off makes everything much gentler.
Old 01-10-2013, 07:00 PM   #15321
fbj913
I ride
fbj913's Avatar
Oddometer: 2,354
Gentle and grinding do not go together... Like said before, just use a chain tool.
fbj913 is offline   Reply With Quote
Old 01-10-2013, 07:48 PM   #15322
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,478
lol, yes forcing metal through a hole smaller than its diameter is less gentle than taking a dremel tool and removing the material so the pin comes out much easier. Sure.
Old 01-10-2013, 08:54 PM   #15323
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,317
Ya, I always ground the tops of the pins when splitting chain. They practically fall out then. But it was always with a bench grinder with a chain already off the bike.
I have never riveted a chain. I think I have a riveter too, just never had to use it. I've never had a roadbike long enough to wear a chain out.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 01-10-2013, 10:12 PM   #15324
marloweluke
The Flying Dutchman
marloweluke's Avatar
Oddometer: 149
I've always had a new chain riveted on because I have lost clip-style links twice. Luckily I've caught it on time both times without the chain coming apart. Would be interested to see how you would safety wire the link. Pictures????
WITHOUT RISK........THERE IS NO ADVENTURE
marloweluke is offline   Reply With Quote
Old 01-11-2013, 03:15 AM   #15325
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,702
Thing is, that metal went through the hole before it was swaged over on assembly. So all you're doing is making it bend back to its original size. No damage done to anything. And you don't have bits of grinding wheel and metal flakes everywhere.
2002 black Tiger955i, 72000 miles and counting.
2012 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 01-11-2013, 04:44 AM   #15326
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,078
That just doesn't seem right to me. Is the pin that is swaged over softer then the side-plate with the hole in ? Logic would suggest there will be some damage if you don't grind the top of the pin.
Anyway, this is a somewhat superfluous discussion since the days of taking a chain off and boiling it etc. to clean/lube it are long (long) gone with good O ring chains.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 01-11-2013, 06:44 AM   #15327
ducnut
Oddometer: 3,301
I went through my track bike pics, but, don't have one of the link.
Simply run the wire around the plate of the master link and tighten.
I've never lost a clip, wired or not.
'96 Ducati 900SS
Old 01-11-2013, 06:53 AM   #15328
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,684
Originally Posted by burmbuster View Post
Ok. So I go to service the drive chain today after 6K miles, as in remove and soak in cleaner, and there is no master link. WTF? So what brand master link do I need or am I blind?
Most of these factory chains are actually endless -- there is no master link per se, they're simply manufactured to be a continuous loop and installed before the swingarm.
As others are pointing out, don't worry about removing it until it's spent (whereupon you can just grind through one of the links). Personally, I don't even bother to clean the chain, I just lube religiously using the Dupont Teflon Multi-Use stuff. My XC still has the original chain and has about 31,000 miles on it -- I'll be replacing the chain soon though just so I don't have to do it partway into the riding season.
When you do get a replacement chain, definitely get the kind with the rivet master link.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 30-June 1, 2014
markbvt is offline   Reply With Quote
Old 01-11-2013, 08:45 AM   #15329
cug
Oddometer: 4,858
On my Transalp in the 90s (only other bike where I had to change chains myself) I got an OEM chain as a closed loop in the right size, took the swingarm out, installed the new chain, swingarm back in - took three hours overall. Can't imagine I'd be that much faster without taking the swingarm out ... A lot of time is spent swearing when trying to get the front sprocket off ...
cug is online now   Reply With Quote
Old 01-11-2013, 12:33 PM   #15330
burmbuster
burmbuster's Avatar
Oddometer: 1,429
Well I happened to be close by my Triumph dealer today and dropped in about the chain and master link. Triumph dosent even offer a master link. I bought a can of Motorex chain cleaner in order to clean it while its on the bike. I will stick with the original OEM chain until I run out of adjustment. Then its on to a DID. Thanks for all of the input.
Brad
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Times are GMT -7.   It's 06:00 PM.
