Old 01-04-2013, 07:59 PM   #15331
burmbuster
burmbuster's Avatar
Oddometer: 886
I did the same thing except I also had a TKC 80 front that I snipped all of the rubber bits off of as well. How long did it take to do front and rear tires? About 3 beers.
_______________
2012 Tiger 800 XC
burmbuster is offline   Reply With Quote
Old 01-05-2013, 02:08 AM   #15332
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 2,506
Send a message via Yahoo to blacktiger
Originally Posted by soldierguy View Post
I just had K60 Scouts put on my 800XC today.
I'm thinking I'll try about 30/35 psi front/rear initially (for the road), then adjust from there.
That'll do OK. Those are the pressures I use especially with luggage. Although I have found them still OK on road at 15F/20R when coming off dirt back onto the road. They are stiff buggers.
2002 Tiger955i in black, 68500 miles.
2012 Tiger800XC in black, 19000 miles.
Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)...
blacktiger is offline   Reply With Quote
Old 01-05-2013, 06:11 AM   #15333
doxbike
Oddometer: 135
Can't remember where I got the figures (maybe from Leslie and Cheryl's trip to Alaska?) but I run 33F and 36R on the street and it handles like a slot car. Drop down 7 psi on each end, 26F and 29R for easy OTR, and down another 6 psi for the deep stuff. Of course what do I know? I got to know some sagebrush and rocks on a first name basis last week-end
doxbike is offline   Reply With Quote
Old 01-05-2013, 09:53 AM   #15334
NABRXX
Oddometer: 42
I took the dive today...
Put down the cash for a green 2013 800xc...should be ready for pick up by next week...I'm an ex gs800 owner ( wrecked it)...looking forward to the smooth triple!!!
NABRXX is offline   Reply With Quote
Old 01-05-2013, 10:20 AM   #15335
some call me...tim
Oddometer: 124
I have a set of Oxford heated grips that I want to hook up, and would like to use switched power--the set I have claims to switch them off if the voltage gets too low, but I don't readily trust that. Ideally, I'd like to use the connection for the OEM heated grips, but if I understand correctly, that won't work because of a relay that turns the power on to that connection separately from the ignition? I know there's the Eastern Beaver kit you can get to make it plug and play, but I was hoping to get these installed this weekend. Is there any way around the relay without getting the EB kit? Or another easy-ish circuit to tap into? (I know people have used headlight circuits before, but I've also heard that's generally a no-no.)
some call me...tim is offline   Reply With Quote
Old 01-05-2013, 03:39 PM   #15336
Ducken
Ducken's Avatar
Oddometer: 102
Heidenau K60
(Heidi K60's) Likewise 33 front, 36 rear with excellent results for the last 8000 miles. Switched from 140 rear to 150 wide after the first 1000 miles, I think the 140 is better off road, but like the 150 better on road and it works well enough off road, just to stir up another hornets nest. Ken
How appropriate for my 100th post to stir up trouble...
Ducken screwed with this post 01-05-2013 at 03:41 PM Reason: 100th post
Ducken is offline   Reply With Quote
Old 01-06-2013, 04:21 AM   #15337
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 239
Tim,
All the relays are the same -- well maybe not every single one but... I looked last time and saw the same relay on three or more circuits. It's a key on thing, just what you want -- it's not "separately from the ignition", if I understand what you meant correctly. If the relay is there or you get a replacement from your dealer for the one you don't have, then the problem is the switch has no less than 6 wires going to it, so you'll need to find the load power vs the lamp power & I guess vampire it or whatever you want. It's all right under the tank just behind the head stock when you have it installed factory, so the harness bits should be tucked away there for you.
If I recall correctly the grips and auxiliary lights are the same relay, and I believe headlights, and instrument cluster too -- the lamps and grips ones are hiding down on the side of the rad under the cowls, and the others are in the battery compartment.
Chek with your meck a nick,
Lusting for: 2013 Triumph Trophy SE
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2011 Tiger 800 XC -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster
Mr_Chris is offline   Reply With Quote
Old 01-06-2013, 05:08 AM   #15338
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 2,506
This is easy if you take the tank off. There's a plug for the Triumph grips. Just follow my photos here :- http://s396.photobucket.com/albums/p...IPS%20INSTALL/
Old 01-06-2013, 08:42 AM   #15339
Evomx971
Planning Next Ride
Evomx971's Avatar
Oddometer: 230
Motion Pro bead breaker
Sorry if someone else has already shared, but as anyone that has ever changed the rear tire on an 800XC knows, the bead is something terrible to get knocked down without a tire machine. Major fear of having to do it along the road and I would consider myself very proficient and changing tires. I had one of those chisel shaped bead poppers in my bag but had tried using it at home for tire changes and it really didn't help much. The bead area is really wide on that rear rim.
I saw the Motion Pro Bead Pro reviewed in a magazine and got one immediately.
http://www.motionpro.com/motorcycle/...ro™_tire_tool/
It's pricey, I think it was around $75 at my local dealer but it works. It takes about one trip around the bead to get it pushed down a little, but then as you start your second pass, it'll knock it all the way down. The other lever in the pictures is the third one I carry with me. I've had it forever since it works on lots of bikes. Also a Motion Pro item. Has a 27mm on one end. Crazy light weight and works very good as a tire lever.
"In the end, it's not the years in your life that count. It's the life in your years." ~ A. Lincoln
'11 Triumph 800XC ABS / '94 Honda XR650L / '06 Yamaha YZ125 / '07 Ural Gear-Up
Thanks to my 2013 Sponsors - Motorex and Leatt
What Next Wander Tour http://advrider.com/forums/showthread.php?t=853663
Evomx971 is offline   Reply With Quote
Old 01-06-2013, 08:46 AM   #15340
some call me...tim
Oddometer: 124
Originally Posted by Mr_Chris View Post
Tim,
Ah, thanks for the clarification. I had been gung-ho about just going in and installing the grips until I did a quick search to see if anyone had tips and saw that it might not be as straightforward as I thought. If I understand correctly, it should actually be a bit more like I'd originally expected. I am indeed planning on just using a vampire connector to attach to the existing wiring. I'm guessing maybe things are more problematic if one is trying to simply find the female connector to the OEM harness and hardwire that to the grips (which would have 2 wires instead of the OEM's 3.) Or, I could be talking out of my ass.
Excellent, thanks for the pics, that will be super helpful. I'd hoped to be able to do this without taking the tank off, but it sounds like it might be worth the extra effort in this case.
Old 01-06-2013, 09:05 AM   #15341
dljocky
Oddometer: 641
Thanks for the report on this. I've been looking at it for a good while now, even while it was being in the pre-production mode. I think I'll get one.
[QUOTE=Evomx971;20410022]
QUOTE]
dljocky is offline   Reply With Quote
Old 01-06-2013, 09:21 AM   #15342
Evomx971
Planning Next Ride
Evomx971's Avatar
Oddometer: 230
Heavier rear spring option for 800XC
I'm 190 pounds w/o gear on, almost always have Jesse aluminum panniers on the bike, and have always had the preload on the stock shock spring at max and still felt I probably had too much sag. With any luggage at all, I had to use the manual lever on the headlight to keep from blinding oncoming drivers, even with the lights on low. Put The Girlfriend on and the spring was way overwhelmed.
Finally decided to do something about it. Really had a hard time finding spring options. AV_MECH worked with Sasquatch Suspension in Idaho and figured out new spring rates but that suspension guy is in jail now...
I took my own sag measurements and compared to what AV_MECH had for targets. The front was spot on which didn't surprise me as it's always felt about right. The rear had about 3/4" too much sag with no luggage.
HyperPro lists a spring kit but feedback I got from an inmate indicated it was really stiff. I exchanged some emails with Klaus (info@epmperf.com) at EPM (which carries HyperPro in the US) and he shared that they have a progressive spring that fits the 800XC that would fall between the one listed in the kit and stock. He said the heavier spring is 141-212 N/mm and the next one down is 103-143 N/mm. I've seen some different numbers, but I think stock is around 100 N/mm straight rate.
I really wanted something heavier but didn't have time to do a bunch of experimenting since I'm leaving on a trip soon (tomorrow actually) so decided to try the 103-143. $139 for a purple one, $149 for black. I got black. Part number is SP-MO 1198.
My buddy Doug at the local KTM/Ducati shop helped me swap the springs. Unfortunately his spring compressor wouldn't work with the plastic sleeve the Triumph shock has so we had to go old school and use tie downs.
Note - if you're pulling the shock out, it helps immensely to pull off the shift linkage at the shift shaft and remove the countershaft sprocket cover.
My target sag with rider is a tick under 3". With me on the bike and no luggage, I ended up at 2.625" at max preload. I haven't measured it with everything loaded up but I think it's going to be about right. I did about 30 miles on it yesterday and it felt great. The whole attitude of the bike is better with the rear end up about an inch. The spring is going to end up still slightly soft with full luggage and a passenger, but it's definitely a step in the right direction.
On a side note, Race Tech didn't list anything for the 800, but I had sent them an email in early December to see if they had done any work yet. I got a response a couple of days ago (I had already bought and installed the HyperPro spring by then) that YES, they have products and settings for the Tiger 800's. Gold valves, springs, etc. Terry Diederichs (terry@racetech.com) was the person that responded to me. So there may be some good options there as well.
Old 01-07-2013, 07:09 AM   #15343
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,393
Seriously???
I'm 250lbs, and even packed for a two-week trip I don't need to crank the preload to max on the stock shock. Did you get the bike new? If not, maybe the previous owner put a softer spring on...?
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 31-June 2, 2013
markbvt is offline   Reply With Quote
Old 01-07-2013, 07:30 AM   #15344
levain
STILL Jim Williams
levain's Avatar
Oddometer: 5,952
That's great to know. I use a Best Rest Beadbrakr. It works. It's a nice tool, but its also big, clunky, heavy and complicated considering it breaks beads Those Motion Pros look like a simple upgrade, esp. if you can confirm there use on a rear XC tire
Click Here!
2012 Triumph Tiger 800 XC
1971 Lambretta DL
levain is offline   Reply With Quote
Old 01-07-2013, 12:30 PM   #15345
TerraUnFirma
Fair/Not Balanced
TerraUnFirma's Avatar
Oddometer: 332
+1 on the Motion Pro Bead Breaker...got one a few weeks ago and changed the D606 on my DRZ the other night...worked like a champ!!! Also great that the two pieces work as tire irons, so those and the MP axle nut wrench and you're good to go.
I thought the D606 was hard to spoon on when it originally did it...the MotoZ Tractionator I put on took it to a whole new level, especially since it was cold in my garage. I wouldn't even want to think about doing a Heidi cold!
Tom Stites - Dawsonville, GA -
'11 Triumph Tiger 800XC ABS
'97 BMW R1100RT
'06 Suzuki DRz400s
'08 Yamaha WR250R
TerraUnFirma is offline   Reply With Quote
Times are GMT -7.   It's 01:44 AM.
