01-10-2013, 01:03 PM
#15361 |
Oddometer: 10
Good deal on a 800xc?
Went into my local triumph dealer to check out an 800xc. Loved it! Then they let me take one for an hour long ride, now in truly in love! I decided while I was there, to see if I can get some numbers and actually afford one. The bike after TTL and prep/destination charges is $14,566. Then they are offering $3,500 for my 2000 ZRX 1100, plus they will take off $2000 from the $14,566. That would bring what I would finance to $9066 for 60mo at around $200/mo. Good deal? |
01-10-2013, 01:11 PM
#15362 | |
Oddometer: 1,841
http://www.triumphmotorcycles.com/mo...specifications
Ride 365 LLC Braaaap! |
01-10-2013, 01:14 PM
#15363 | |
Oddometer: 886
_______________ 2012 Tiger 800 XC |
01-10-2013, 01:32 PM
#15364 |
Oddometer: 10
01-10-2013, 01:39 PM
#15365 |
Oddometer: 886
look around. You can get a better deal than that. You can buy one at an out of town dealer over the web for far less.
01-10-2013, 01:45 PM
#15366 |
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,393
Dunno where you're located, but last I heard, Triumph's freight charge was $450 for all dealers in the continental US. Looks like your dealer is tacking on $350 in "prep" fees. You should be able to get them to eliminate those, and also drop the base price of the bike a bit -- and by the way, Triumph is still advertising $11,999 as the price for a 2013 Tiger 800 XC with ABS, so your dealer seems to be $600 too high. Assuming you're in the US.
Definitely shop around. You can do a lot better. --mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe My ride reports: Missile silos, Labrador, twisties, and more Bennington Triumph Bash, May 31-June 2, 2013 |
01-10-2013, 02:08 PM
#15367 |
Oddometer: 886
Ok. So I go to service the drive chain today after 6K miles, as in remove and soak in cleaner, and there is no master link. WTF? So what brand master link do I need or am I blind?
01-10-2013, 02:20 PM
#15368 | |
Oddometer: 10
Thanks guys!
01-10-2013, 02:39 PM
#15369 |
armchair asshole
Oddometer: 2,539
I think all road bikes just have a rivet type master link and everyone just cleans it on the bike. Is this your first road bike/motorcycle? Obviously if you are wanting to take the chain off you'll have to grind it off. And then either put a new rivet link on or a clip type link in which case I'd use the same brand as the chain.
01-10-2013, 02:41 PM
#15370 | |
PIN IT & BANG GEARS
Oddometer: 2,506
Not a good idea to 'soak' an o-ring chain. The o-rings keep the grease inside the rollers and the dirt outside. Depending on what you're soaking with, can seep into the roller internals, and/or breakdown or swell the o-rings. Better to hose it with WD and wipe down, use a wire brush to remove caked on lube/dirt mixture. Then apply a good chain lube. Chain lube on a o-ring type chain is just to quiet it and reduce friction between the chain the sprocket teeth. Some have reported very long life just cleaning with WD40. Everybody has their opinion though, it's like picking oil or tires.
Chris Brown - "The Browneye" ![]() http://www.stewardsofthesequoia.org/ • Grand Canyon Adventure Ride 2012 Laguna Seca 2012 RR • Sequoia 3-Day Campout • Thanksgiving 2012 |
01-10-2013, 04:18 PM
#15371 | |||
Oddometer: 2,442
Do not use a wire brush, as it will tear up the O-rings. There are plenty of plastic-bristle, parts-cleaning brushes available; even a stiff toothbrush will work.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
01-10-2013, 04:25 PM
#15372 |
armchair asshole
Oddometer: 2,539
01-10-2013, 05:09 PM
#15373 |
Oddometer: 119
That's the way its done. The heads are rounded over with a press when the chain is assembled. A chain tool will press them out with no problem. Never heard of grinding the head off first.
01-10-2013, 05:11 PM
#15374 |
Oddometer: 2,442
Yes. A nice chain tool (RK is what I have) will push it right out.
01-10-2013, 05:27 PM
#15375 |
armchair asshole
Oddometer: 2,539
I don't see the point when grinding the head off makes everything much gentler.
