Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 01-28-2013, 11:10 PM   #15586
PaulSF
Oddometer: 149
Originally Posted by cug View Post
Find a good suspension shop and they'll do it nicely for you. Or spend more money and get a Traxxion/Penske or Traxxion/Wilbers or Oehlins solution.
Matris and Ohlins have both released front cartridge kits for the 800 and XC. So we now have lots of choices.
PaulSF is offline   Reply With Quote
Old 01-29-2013, 12:57 AM   #15587
viper770
viper770's Avatar
Oddometer: 588
Originally Posted by Sound Farm View Post
What do u guys think of a 2012 abs. Xc with 20,000 miles. With a few farkles and triumph panniers for $9000. ??
Good deal? To many miles for the price ? Worth it to just ge a new one ?
I like the price. Don't like the mileage but it has been serviced on regular basis by dealer. Let me know what u think
hey sound farm if that triumph 800xc is from kansas thats my bike i posted for sale lol
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 01-29-2013, 04:54 AM   #15588
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
While we're on forks..... Anyone had their XC forks apart?
I wanted to perhaps reduce the preload (cut down any spacer in there) and/or remove some oil to make them a little softer and, hopefully, make the ride less jittery on the road. When I unscrewed one of the top caps, it didn't want to come off. When it reached the top of the thread it snapped back as if it was being held down by something inside.
Any clues anyone?
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 01-29-2013, 05:56 AM   #15589
PirateDunk
Oddometer: 72
Dropped my 2011 tiger 800xc off at the dealers this morning for some experimental surgery.
Bike has 45000km on the clocks, have had it since new.
Was 200km away in the middle of nowhere this weekend when the gearbox refused to cooperate and I couldnt downshift past 4th. Eventually was able to get the full gearbox range back by half backshifting up before shifting down. Gear shifter has lost its spring.
I had the gear selector spring recall fitted 7000km ago. I'm thinking its broken or disconnected. Hopefully its not been injested by the engine.
Anyone else had this?
PirateDunk is offline   Reply With Quote
Old 01-29-2013, 06:19 AM   #15590
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
New MRA screen.
So today I fitted an MRA screen which was designed to fit an Explorer. http://www.bikehps.com/acatalog/Triu...html#aCOL58227
I do have an advantage in that I already have the Palmer adjustable brackets. So all I had to do was line it up and drill some holes to match.
Layed back in the lowest setting....
Front of screen lowest but the rear raised up....
I do reckon that it could be mounted without the Palmer stuff by using the OE Triumph mounts at the front of the screen and the MRA fittings from their 800 screen http://www.bikehps.com/acatalog/info-COL57407.html at the sides and drilling holes to suit.
I went with this screen for two main reasons :-
a) it's designed to fit around the headlamps and, therefore, looks better than any other screen I've seen.
b) it's wider than other screens I've seen.
Haven't had a chance to try it yet because the weather's pissing down.
Old 01-29-2013, 08:40 AM   #15591
ducnut
Oddometer: 3,320
Any clues anyone?
You need to pull the forks completely off the bike. Once you do that, you can collapse the fork, which will push the spring up and the cap. I'm not thinking there's any retainer. The spring may just be stuck inside the cap. Furthermore, the spacer (if there is one) will probably be at the bottom, which means dumping the oil and refilling. You'll need a fork oil tool, to set the air gap.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 01-29-2013, 06:47 PM   #15592
ssevy
Oddometer: 919
I used a piece of bronze brazing rod with the correct level marked on it, and a turkey baster to add and remove fluid. Alot cheaper than that tool. This was on my Legend, and not a Tiger, so I could be missing something that is different?
ssevy is offline   Reply With Quote
Old 01-30-2013, 02:29 AM   #15593
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
Thanks. I've got the level tool. I was hoping that I could just take the cap off and delve inside. This is obviously going to be more involved. I did find this in my searches. http://www.triumph675.net/forum/showthread.php?t=38739
Old 01-30-2013, 04:26 AM   #15594
protesto
Oddometer: 4
Leovince mapping for Tiger 800xc
Hi,
I'm from Istanbul and this is my first post on this forum. I hope you can help me.
I've recently bought a 2011 model Tiger 800xc. My bike came with a Leovince L Sbk exhaust on it. On the service we've checked software updates and we saw that there are 2 updates: for standard exhaust and arrow exhaust. Since leoovince is performance exhaust we've choosen update for arrow model. I don't know if the mapping of arrow matches with leovince. Should I choose the mapping for standard exhaust?
Thanks for your help.
protesto is offline   Reply With Quote
Old 01-30-2013, 04:50 AM   #15595
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,196
Originally Posted by protesto View Post
Hi,
Welcome to the asylum.
Read this thread and if that doesn't answer your question, ask again in that thread and someone will know.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 01-30-2013, 07:27 AM   #15596
ducnut
Oddometer: 3,320
Those are fully-adjustable.
The last set of forks I had apart, ~8yrs ago, were non-adjustable like the T800. They didn't require a spring compressor.
Hell, dig in. The worst thing that can happen is you have to put 'em back together.
'96 Ducati 900SS
Old 01-30-2013, 10:19 AM   #15597
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,980
Heated grips!
Buddy of mine just picked up his new Triumph 800XC and had the factory Triumph heated grips installed. We were out for a cool blast on the weekend at 25F. His grips didn't seem very warm even on the high setting. We checked my cheap $85. Oxfords and they we almost burning my hands on the highest setting. His grips were just barely warm. Not sure if this is the same on all factory heated grips but if so, save some bucks and install the Oxfords. May want to check with other Triumph owners on this topic.
RED CAT is offline   Reply With Quote
Old 01-30-2013, 10:43 AM   #15598
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
I agree. I did a "How to" about connecting the electrics for the Oxford ones. http://www.tiger800.co.uk/index.php/topic,7459.0.html
Old 01-30-2013, 10:45 AM   #15599
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
My new MRA Explorer screen out in the light.
It works great. Didn't seem to matter where I adjusted it, all was smooth airflow behind it.
Old 01-30-2013, 11:41 AM   #15600
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
do the math on farkels and such. it could be a good deal... 20,0000 isn't a lot of miles in my opinion. not for these bikes.
fbj913 is offline   Reply With Quote
Times are GMT -7.   It's 07:16 PM.
