Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 02-27-2013, 03:32 AM   #15961
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,703
Originally Posted by PirateDunk View Post
Lack of parts supply has also extended to wheel bearings, seals and brake pads.
If only Triumph would list the commercial bearing sizes like KTM do so that I could get hold of them locally before taking them out.
All the above are available from just about any local Jap bike dealer (the callipers are used on loads of stuff) or bearing supplier. Yes you need to know the size but if you know where to look :- http://www.worldoftriumph.com/triump...lock_03=560041 number 7 has the size in the title.
2002 black Tiger955i, 72000 miles and counting.
2012 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is online now   Reply With Quote
Old 02-27-2013, 03:45 AM   #15962
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,703
Brake callipers are fine, the disc rivets started to fret, resulting in lots of clanking and would ultimately have led to brake failure. I.e the floating discs floated too much.
That is quite normal and absolutely nothing to worry about. When I first got my BMW R100GS it had disc rattle that would get heads turning when riding on cobbled streets. It consistently got through MOT after MOT. After a few years I got fed up with the racket and swapped the disc for an EBC Pro-lite.
I think you're being too fussy.
Old 02-27-2013, 03:48 AM   #15963
PirateDunk
Oddometer: 67
How many sets of brake pads did you get through before that happened?
PirateDunk is offline   Reply With Quote
Old 02-27-2013, 06:19 AM   #15964
fbj913
I ride
fbj913's Avatar
Oddometer: 2,354
No pic, the old discs have since gone to the tip.
The Disc does float, ever so slightly. Grab yours and give it a tug forwards or backwards. It will move a bit. The rivets allow it to move to as it heats up.
Definitely not the calipers.
hummm, ok. thanks
fbj913 is offline   Reply With Quote
Old 02-27-2013, 07:54 AM   #15965
ducnut
Oddometer: 3,301
Some floating discs have a spring-washer contained within the buttons and some don't. Just because the disc moves or rattles doesn't make it worn out. You guys are starting to sound like a bunch of Harley riders.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-27-2013, 08:04 AM   #15966
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 3,821
cam chain tensioner noise at cold starts
Originally Posted by swimmer View Post
Mine primarily does it only on cold starts. When I take it apart soon I'll know if anything is broken or if its just a case of the little spring thing being out of whack. I guess it's easier and quicker for me to look myself rather than have the dealer look at it. Plus, if they don't find anything they think is wrong then I am stuck with a bill and no better off.
I was asking whether the problem with the CCT (noise, spring out of whack) was a warranty issue or not.
So let me ask this question differently:
If you have this noise at start up (and eventually it graduates to being there all the time) and you do nothing about it, is this going to create any damage to the engine?
If so, isn't this something that Triumph should take care under warranty?
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Old 02-27-2013, 08:24 AM   #15967
ducnut
Oddometer: 3,301
It is covered by warranty.
If left uncorrected, it will damage the engine. It can be as minor as casing damage, from the chain whacking the inside, which generates metal fragments. Or, it can be as serious as total tensioner failure, which would allow the cam timing to skip and bend valves and possible other engine damage.
'96 Ducati 900SS
Old 02-27-2013, 08:59 AM   #15968
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,480
If it did it all the time then yes. But as a previous poster noted, his did it on start up only and when he took his CCT out he found the spring on the CCT that puts tension on when there is no oil pressure (start up) to be out of placed. He popped the spring back into place and problem solved. That''s what I am hoping for as dropping the bike off etc... is a major hassle. If that is not problem with mine I'll consider taking it in. But yes, a bad CCT would be a warranty item.
swimmer is offline   Reply With Quote
Old 02-27-2013, 11:03 AM   #15969
Lion BR
Lion BR's Avatar
Oddometer: 3,821
Thanks guys!
Old 02-27-2013, 04:50 PM   #15970
PirateDunk
Oddometer: 67
The spring washers help to increase the clamping stresses of the rivets.
I work with and design aircraft components. If a rivet or bolt gets slop it has zero fatigue life.
i.e. If you stick a 6mm bolt in an 8mm hole it can carry zero load. Simples.
I apologise for being too fussy. I have a syndrome called self preservation. I've noticed Hardly-Worthit drivers don't have this basic human instinct.
Old 02-27-2013, 05:00 PM   #15971
ducnut
Oddometer: 3,301
Not being too fussy.
Your bolt example is dead-on. However, I can't tell you how many iron, Brembo race rotors I've heard rattle, to include new, out-of-the-box examples. Brake Tech iron rotors do the same. They float freely, without spring washers. IDK, I'm not an engineer. But, I'd think the engineers, who specialize in these components, have a pretty good idea what they're doing. In fact, before floating rotors became mainstream, they didn't have spring washers. When nearly every sportbike started coming with them, people started complaining about the rattling.
'96 Ducati 900SS
Old 02-28-2013, 01:33 AM   #15972
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,703
The 100GS was like it when I bought it. It only had 11250 miles on the clock.
Old 02-28-2013, 01:39 AM   #15973
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,703
That depends on which direction that load is. i.e. the bolt itself has shear strength depending on the material it's made from. If the load is 90 degrees to the axis it'll carry a load up to that strength.
Now if you replace bolt with bobbin...............
Old 02-28-2013, 11:15 AM   #15974
fbj913
I ride
fbj913's Avatar
Oddometer: 2,354
molded frame protectors
i just ordered these from my dealer. anyone else using these?
http://store.proitalia.com/triumph-t...-p-160002.html
Old 02-28-2013, 01:29 PM   #15975
Windy Rider
Pussy Power
Windy Rider's Avatar
Oddometer: 348
Yes, I've been looking for these, be ordering some, I have nearly worn though the paint in places. Thanks for posting
2011 Triumph Tiger xc
Blog: http://thetigerhunt.tumblr.com
http://tiger800xc.tumblr.com
Windy Rider is offline   Reply With Quote
Times are GMT -7.   It's 02:16 AM.
