Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-02-2013, 09:53 AM   #15991
GearHd6
GearHd6's Avatar
Oddometer: 166
The throttle cable bracket that is attached to the throttle bodies didn't get in the way of removing the valve cover? I needed to remove the bracket in order to get the cover off. The book says to completely remove the throttle bodies.
2015 Tiger 800 XCx
2004 CRF250X
GearHd6 is offline   Reply With Quote
Old 03-02-2013, 10:08 AM   #15992
The Toad
Let There Be Light
The Toad's Avatar
Oddometer: 1,167
quite possibly a strange questions... engine "sound".. "noise" ???
Minutes away from pulling the trigger on a Tiger
Its a used bike and all seems fine EXCEPT... the engine makes what to me sounds a bit "strange"??? I know sounds can be hard to explain but Ill give it a shot... there seems to be a "whirring" sound coming from the front/top of the motor... almost.. I say.. almost.. like an accessory belt on a car that needs some lube....
Ive owner lots and lots and lots of bikes and the engines often sound very different... but this is a new one too me anyway..
Is this a "normal" engine sound for the Tiger???
thanks,
-Brian
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 03-02-2013, 10:11 AM   #15993
bluesman
Oddometer: 3,350
thanks,
-Brian
Whine/whirr or whistling is signature sound of that and some other Triumph engines. But without hearing it - not easy to say 100% that it is usual or not. Generally it is not very silent motor.
bluesman is offline   Reply With Quote
Old 03-02-2013, 10:56 AM   #15994
ducnut
Oddometer: 3,320
thanks,
-Brian
Signature sound of the modern, Triumph triple. It's the counter-balancer drive gears, as they're straight-cut and that causes the whirring/whining sound. That sound should be more apparent, down on the right side of the engine.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-02-2013, 11:17 AM   #15995
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,728
thanks,
-Brian
yes
swimmer is offline   Reply With Quote
Old 03-02-2013, 11:18 AM   #15996
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,728
The cam cover gets stuck between that bracket and the finned heat sink on the other side. Loosen but not completely removing that heat sink seemed easier to me so that's what I did.
Old 03-02-2013, 12:12 PM   #15997
The Toad
Let There Be Light
The Toad's Avatar
Oddometer: 1,167
thanks for the replies on the "whirring" sound quesiton...
now I know.
Trigger is pulled (non XC)... should be in the garage by tomorrow.
Let the farkleing/mods begin
Speaking of mods.... I will be mounting some more aggressive tires (probably the Shinko 705's).. wondering if the lower front fender causes a problem with taller tires???
Also open to suggestions as far as what (more aggressive) tires?
thanks,
-Brian
Old 03-02-2013, 01:31 PM   #15998
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,032
thanks,
-Brian
Consider FullBore USA's. The rear is v-rated and tubless. For all I know the front 19 is too. I have about 3K on mine on the XC, they will probly go another thou. Good tire on and off pavement. And cheap as hell.
Unless you're really going to see more than the occasional dirt road the scorp trails that come on them are a superb tire. Air down to about 22 for dirt traction. But then you dd need to air back up for hiway. I carry a 12v pump.
Personally I wouldn't do anything more aggressive for a roadie. Heideneau K60's are another good choice - more $$, and little more aggressive tread.
Not mods req'd for either.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is online now   Reply With Quote
Old 03-03-2013, 01:55 AM   #15999
KildareMan
KildareMan's Avatar
Oddometer: 681
Personally I found the scorpion tyres to lose all semblance of grip when half worn. Rubbish on the road. A better, much better,tyre is the Dunlop trailmax. Raising the mudguard on the 800, ad opposed to the xc, requires changing the brake hoses.
Sent from my Tiger 800
KildareMan is offline   Reply With Quote
Old 03-03-2013, 07:12 AM   #16000
Poweranger
Oddometer: 778
What kind of mileage are you getting with the Trailmax?
Also curious what kind of mileage I might expect with the stock scorp trails? What are you guys getting?
Poweranger is offline   Reply With Quote
Old 03-03-2013, 08:12 AM   #16001
CPORet
I Am Kirok!
CPORet's Avatar
Oddometer: 309
I replaced my original set of Scorpion Trails at 11,300. The front had a little better than 50% tread,
and the rears were pretty close to the wear bars. Had the money so I figured I'd just change them
out now. Plus, it gave me the opportunity to have the TPMS sensors installed.
I don't think the Scorpion Trails are horrible, but I'm thinking about Dunops for the next pair.
CPORet is offline   Reply With Quote
Old 03-03-2013, 12:07 PM   #16002
Hulley
Oddometer: 110
Well I should be ordering 2013 800 XC soon and I have a few questions.
Are the Triumph accessories any good? I'm thinking of ordering my 800 XC with these items.
Center Stand
Bash plate
Engine crash bars
Radiator guard.
For the money I think they are priced fine but not sure of their protection worthyness. I've been a motocrosser all my life and have no problems wanting to tackle some nice trails.
I am a do-it-yourself kind of guy and have no problem buying aftermarket bars/bash plate etc and installing them myself. I was just thinking it would be easier getting them at time of sale.
Steve
Hulley is offline   Reply With Quote
Old 03-03-2013, 01:11 PM   #16003
bluesman
Oddometer: 3,350
Center Stand
Bash plate
Engine crash bars
Radiator guard.
Steve
In my opinion bash plate is excellent. Some say not because it does not cover oil filter from flying rocks. Which cab be dealt with by filter cover.
Engine guards are excellent, but won't protect top part. I use separate tank bars for that.
I do not see point in rad guard because stock XC have deep honeycomb plastic guard, rather sufficient in my opinion.
Old 03-03-2013, 01:12 PM   #16004
Poweranger
Oddometer: 778
Registration and Insurance papers?
So where do you guys keep em on your Tigers? I just put my plate on today and got to thinking of this. I like to keep them some where permanent on the bike. Not in a tank bag or other removable luggage. The only thing I can think of is in a zip lock bag stuffed under the rear seat someplace.
Old 03-03-2013, 01:20 PM   #16005
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,032
+1
That's what I do, and a copy in my wallet since that's always in my pocket as well.
Put the extra key in your backpack or hide on the bike somewhere. I find this difficult at best though, so I just make sure I have a spare along somewhere.
Center Stand
Bash plate
Engine crash bars
Radiator guard.
Steve
The first three I got with my new one, highly recommended. The Altrider sump guard comes up a little higher but it's kind of moot. None of them are a true 'skid' or 'bash' plate. They are just mounted on rubber bumpers to the bottom of the engine. They're there to keep flying rocks from crashing into your engine. This is not a dirtbike.
The altrider tail rack is a good one, so is the CJ Designs one, I have the latter. A seahorse 720 as a topbox and backrest for the wife, although she hasn't spent much time on it.
My engine guards aren't on yet in this pic. Something heavier duty for handguards are also suggested if you're gonna dump it off pavement.
browneye screwed with this post 03-03-2013 at 01:28 PM
Times are GMT -7.   It's 07:16 AM.
