Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-18-2013, 04:23 PM   #16276
lmychajluk
Oddometer: 2,119
Yep, same... 30" jeans (sometimes even 29" if I can find them). If I get the chance, I may try that low seat, but I'm not going to buy it just to try. I really don't want to start futzing with the suspension or the geometry of the bike just yet...
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 03-18-2013, 04:40 PM   #16277
byh
Oddometer: 40
Originally Posted by ducnut View Post
When you lower the rear, you're raking out the frontend. If you're talking a bike with a soft-ish rear suspension, lowering only the rear will cause the bike to not finish turns even more. That means you'll be leaning the bike over further and further, yet, it won't turn. This will cause hard parts to drag and/or running off the outside of the turn's exit. You want to equally lower the front and rear. Lowering the front pays off, because most people, who are at their inseam limit, tend to slide forward on the seat at a stop. Don't be afraid to tinker with geometry, as you can always return it to the original position.
Good advice. I would recommend not lowering the suspension, but just get the lower gel seat. If you run a lot of sag to get close to the ground, the bike will bottom out a lot.
I would love to be 5'10", but that's not gonna happen (5'3", 26" inseam).
http://www.my2wheels.com/
byh is offline   Reply With Quote
Old 03-18-2013, 04:57 PM   #16278
cug
Oddometer: 5,027
At least the current low gel seat does nothing in reach to the ground compared to the standard seat as it is just as wide and much harder. On the standard, it might take 5 minutes to get the same reach, but if you have ridden on it for 4k miles, it takes about 10s to sink in and be at an actually better level than with the low one because the ridges aren't as stiff.
I have both these seats at home as my wife likes to ride my Tiger, too, and this is actually from what she said about the seats (and I confirmed pretty much).
It would be better to get a re-shaped low seat from a 3rd party because there you can get want you want/need, not what comes out of a production line a few hundred times ...
R1200R/RS LC Forum
cug is offline   Reply With Quote
Old 03-18-2013, 06:11 PM   #16279
Johno33772
Johnny Africa
Johno33772's Avatar
Oddometer: 898
What's involved in the 12k service that's costs $800-00 per my dealer?
Cheers
KTM 1190R / XR500 Street tracker project/ KTM 500XCW / KTM 300XCW / Sherco 2.9 / Honda ZA50,Ural Patrol, Honda NSR250 ...Yamaha Wave Blaster 1200.
Johno33772 is offline   Reply With Quote
Old 03-18-2013, 06:16 PM   #16280
kingofZroad
kingofZroad's Avatar
Oddometer: 352
Originally Posted by cug View Post
It certainly is - just be careful with what you do there. Maybe it's better to just get used to it. If you don't want a suspension shop to make the XC suspension as stiff as the Roadie suspension, you'll drag hard parts earlier on the XC if you bring it down so low. I wouldn't want to catch hard parts when cornering, might not be an issue for you, but as said before, the Tiger is fairly wide at the pegs, so that stuff drags very early without lowering either bike ...
I cannot even imagine dragging the pegs on my XC!!!
Aren't both bikes on the same frame? If so, wouldn't the extra 2" in the front tire more than compensate for the lowered fork? (Or are you saying the XC suspension will "dive" in the corners under hard braking?)
kingofZroad is offline   Reply With Quote
Old 03-18-2013, 07:13 PM   #16281
cug
Oddometer: 5,027
Valve check and adjustment. But even that shouldn't drive the price that high.
R1200R/RS LC Forum
Old 03-18-2013, 07:19 PM   #16282
cug
Oddometer: 5,027
I did it on the test ride ... was kind of annoyed though. You just need a bump in a corner where you lay over fairly far and the suspension compresses and there you are.
Coming from a Telelever suspension (virtually no dive under braking), the XC felt like a rocking horse. The Roadie much less so due to the stiffer suspension. But still - the XC suspension is definitely better overall than the Roadie's, no question about that. But compared to well adjusted 3rd party suspension, they both suck, the XC just sucks a little less ...
R1200R/RS LC Forum
Old 03-18-2013, 07:19 PM   #16283
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,962
Cheers
That's ridiculous. BTW, you can look at the maintenance schedule in your manual and see what will be done. I inspected my valves a couple of weeks ago. Maybe a 4 hour job. Add a couple to that if any are out of spec.and at 12k miles most people, from what I have read, don't have any valves out of spec.
swimmer is offline   Reply With Quote
Old 03-18-2013, 08:32 PM   #16284
bross
Where we riding to?
bross's Avatar
Oddometer: 4,695
That does seem a little high, but honestly, it costs money to have a shop maintain your bike. What shop rate for you guys, for me it's $90-95/hour. So your 4 hour job is $360 in labour alone and that's just the valves. That's one of the reasons I do all my own servicing, but the main reason is convenience. With no dealer close by I'm almost forced to do all my own, or hotel it on dealer visits. That ain't gonna happen.
Old 03-19-2013, 02:39 AM   #16285
BDKrivit
Kriv
Oddometer: 110
+1 to this; what's the price for our time? I'm also in the $95/hr world in NYC. Plus tax, EPA fluid disposal fees AND my Bonneville needed all 8 shims on it's 12k (to be fair, it was 3 years old and closer to 14k miles). So I dropped $800 total. Good professional service, from a CPA, MD, lawyer or mechanic, costs money-
2014 Tiger 800 XC
IBA# 53256
2012 Minuteman 1000
2013 & 2014 Nutmeg 400
2014 BunBurner 1500
BDKrivit is offline   Reply With Quote
Old 03-19-2013, 04:14 AM   #16286
bluesman
Oddometer: 3,384
Hm. My low seat is not gel and more comfy than stock. Interesting.
Here is my seat
bluesman screwed with this post 03-19-2013 at 04:15 AM Reason: damn picture still too big
bluesman is offline   Reply With Quote
Old 03-19-2013, 05:10 AM   #16287
elan
Oddometer: 131
While I haven't done it myself, 4 hours seems like a long time just to check valves on an inline motor. I do hear it's pretty tight in there though.
Not sure if I'm comparing apples to oranges, but I could check valves on my V-twin TL1000R in a couple hours, taking my time. My CRF450 takes about 30 mins :P
elan is offline   Reply With Quote
Old 03-19-2013, 05:20 AM   #16288
ducnut
Oddometer: 3,321
My dealer says the same.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-19-2013, 06:47 AM   #16289
strider.deano
Oddometer: 334
If your dragging hard parts, your doing it wrong ! With proper suspension settings and body placement, the XC will corner amazingly well and never touch down. But it is not a RR1000.
?.....the XC suspension is definitely better overall than the Roadie's
On a very tight twisty road with decreasing radiuses (radii?), off cambers and smooth pavement the Roadie kicks it. But as you said, "overall", the XC is much more pleasant to ride hard. The best thing about the 800's is the motor. It just loves to be wicked up to 7-8 grand or lugged around at 3-5 grand. .
strider.deano is offline   Reply With Quote
Old 03-19-2013, 06:50 AM   #16290
strider.deano
Oddometer: 334
Times are GMT -7.   It's 12:11 PM.
