Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-19-2013, 05:46 PM   #16306
cug
Oddometer: 5,022
Originally Posted by strider.deano View Post
You're right....I don't know and I wasn't there. No offense intended.
No offense taken. Just the typical response to "you're doing it wrong ..." ...
Maybe I'm doing wrong, but I've only nicked a peg once or twice with the XC.
I generally ride in a way that reduces the likelyhood, like shift body weight and such, but I'm not a "knee out, hang off" rider and the ergonomics of the Tiger don't support that well anyways.
The main issue with this, as already mentioned, are bumps in the middle of a nice laid over corner. The softer the suspension the more you get additional compression there and the more likely you are to touch down.
Therefore personally I think that lowering the XC combines the two downsides of XC and Roadie in a dangerous way: soft(er) suspension and low ground clearance. I never understood that. If the very basic layout of the bike doesn't fit you, why force it in a way that generally doesn't work very well? Lowered bikes all have issues in one way or another. You're likely to get better results with a bike that was meant to be low enough. But again, that might just be me.
R1200R/RS LC Forum
cug is offline   Reply With Quote
Old 03-19-2013, 05:50 PM   #16307
ducnut
Oddometer: 3,321
Originally Posted by blacktiger View Post
A chunk of the price comes from all the gaskets and O rings they replace when the valve cover comes off.
If they're replacing the valve cover and plug hole O-rings with a valve check, find a new dealer, as those are reusable.
Originally Posted by bross View Post
My beef is why can't they build a moto engine with hydraulic valves?
It's all about the RPM. Hydraulic valvetrains simply can't be spun up. The bikes you note are cruisers, which won't even see the RPM where the triple starts coming on.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-19-2013, 05:54 PM   #16308
marloweluke
The Flying Dutchman
marloweluke's Avatar
Oddometer: 149
[QUOTE= It's all about the RPM. Hydraulic valvetrains simply can't be spun up. The bikes you note are cruisers, which won't even see the RPM where the triple starts coming on.[/QUOTE]
I'm quite sure my 1985 Honda Nighthawk 750 S had hydraulic valve adjusters. Can't remember what the redline was, but pretty sure it was around 10,000 like the Tiger. Awesome bike for it's day, including shaft drive. Maintenance was indeed minimal, but you did have to balance the carbs once in a while.
WITHOUT RISK........THERE IS NO ADVENTURE
marloweluke is offline   Reply With Quote
Old 03-19-2013, 05:58 PM   #16309
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,056
Roadie off-roadie too!
Saw this and thought of you FFs...
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 03-19-2013, 06:00 PM   #16310
ducnut
Oddometer: 3,321
Originally Posted by cug View Post
The biggest downside of the Tiger is the mushy brake. It's just not a "well defined" stopper. I heard different brake pads can make that better and would love to hear positive stories about that, but compared to other bikes I rode, it's certainly its biggest weakness.
I think you and I are probably similar, in riding styles and experience. I use Ferodo, on everything that I personally ride. Their Sinter Grip ST is a pad I think you should try. They can be a little noisy, but, they're very aggressive without the need for a lot of temperature. If that doesn't give you the lever feel you desire, you can easily swap a takeoff master cylinder from a more sporty Triumph. I'm not sure on all the piston diameters of each bike, but, that's where I'd be looking.
'96 Ducati 900SS
Old 03-19-2013, 06:08 PM   #16311
ducnut
Oddometer: 3,321
Definitely, nice bikes, even today.
I no longer work in a dealership. Otherwise, I could verify exactly what it had. A quick web search shows that it had rocker arms, but, can't quickly find anything further.
'96 Ducati 900SS
Old 03-19-2013, 06:27 PM   #16312
Poweranger
Oddometer: 804
While we are on the subject of brakes I have noticed my fronts produce a lot of brake dust. I'm still in the break in period but do not remember my other new bikes producing dust. Do these pads just produce dust at break in and then clean up later? Or are they just the cheaper ones that always produce lots of black dust?
Poweranger is offline   Reply With Quote
Old 03-19-2013, 06:30 PM   #16313
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 917
Yep, my 650 Nighthawk from that era had hydrolic lifters, tensioner and shaft drive. Ran like a scaulded dog and never had to do anything to it.
XCRider803 screwed with this post 03-19-2013 at 06:50 PM
XCRider803 is offline   Reply With Quote
Old 03-19-2013, 06:32 PM   #16314
ducnut
Oddometer: 3,321
I'm not exactly sure what the compound is. But, organic pads are the dustiest and least aggressive. Semi-metallic are less dusty and quite a bit more aggressive. Given the intended use of the XC, they're probably organic. If they're too aggressive, people always complain.
'96 Ducati 900SS
Old 03-19-2013, 07:30 PM   #16315
kingofZroad
kingofZroad's Avatar
Oddometer: 352
I wish the rear brake was more aggressive...
kingofZroad is offline   Reply With Quote
Old 03-20-2013, 03:09 AM   #16316
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,895
They should be but according to the Triumph manual they're replaced on a service. I certainly won't be replacing them every time when I start doing it myself.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 03-20-2013, 03:10 AM   #16317
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,895
Not true. The Honda CBX750 in the mid '80s had Hydraulic tappets. http://en.wikipedia.org/wiki/Honda_CBX750
http://teamrc17.net/articles/104/a-r...rbike-magazine
Look under "Power train".
blacktiger screwed with this post 03-20-2013 at 03:21 AM
Old 03-20-2013, 03:15 AM   #16318
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,895
Thing is, IMO, you don't want an aggressive front brake on a bike that's likely to be ridden on dirt. I think they got it right for the XC at least. That slight "mushy" feel gives the brake, er, feel. e.g. I can drag the front going down loose hills using my "brain ABS".
Old 03-20-2013, 05:41 AM   #16319
ducatirdr
Re-entry Noob
ducatirdr's Avatar
Oddometer: 135
I have a KTM woods bike and it has excellent brakes with strong initial bite. The brakes feel like overkill on that machine. I adjust to them quickly and appreciate their strong, save my arse, initial bite stopping power. I wish my Triumph had that same inital bite. I'd rather have to back off, then feel like I need to squeeze the juice out of them. They have a feeling of being undersize for the machine to me. I'm sure there is a reason for this like you mention but I wish they had a bit stronger feel to them.
04 Buell XB12R - Feels fast but isn't = Good street sport bike
12 KTM 350EXC-F - Enduro machine with plate so I can ride to the trails near my house
13 Triumph Tiger 800XC - Sold after clutch stranded me at 4K miles in Berkshires
2000 Ducati 996S - Madness
2014 H-D Breakout - Nothing like a big scooter to relax a bit
ducatirdr is offline   Reply With Quote
Old 03-20-2013, 05:50 AM   #16320
KildareMan
KildareMan's Avatar
Oddometer: 692
Try EBC HH pads.
KildareMan is offline   Reply With Quote
Times are GMT -7.   It's 06:17 AM.
