Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 03-27-2013, 06:57 PM   #16441
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
Originally Posted by Seventy One View Post
About the Full Bore tires, it says that the front tire (M41) is Bias ply and the rear (M40) is Radial.
Is that going to be an issue?
Should not be a problem at all.
Old 03-27-2013, 08:01 PM   #16442
T
stay classy
T's Avatar
Oddometer: 5,264
I've never had any problems with this setup but I believe tire manufacturers are required (by their lawyers) to deny that combinations other than two perfectly matched tires, of the same make/model, with equal amounts of tread, and mounted by a factory certified installer will be anything but safe.....
Inconsequential Adventurer
T is offline   Reply With Quote
Old 03-28-2013, 07:05 AM   #16443
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,638
Of course! Not to mention that such a policy helps to sell more tires.
Old 03-28-2013, 08:27 AM   #16444
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,565
Unless your racing on a track & can ride like a pro, you'll never notice the bias front is paired with a radial.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 03-28-2013, 09:58 AM   #16445
bross
Where we riding to?
bross's Avatar
Oddometer: 4,520
BMW F650s, the old thumper model, came from the factory with a radial and bias ply tire with warnings that if you didn't run tires like that you'd die in a fiery crash.
Old 03-28-2013, 10:36 AM   #16446
The Breeze
Oddometer: 204
Bike pulls to the right
Hello Inmates,
Wanted to check and see if this is a common/inherant design issue with the 800XC.
Basically, if you take your hands off the bars while going straight down the road.......the bike will pull to the right. It's very subtle to correct....but basically, I have to continuously counter steer the bike to keep it going straight. The only other way to make the bike go straight (without hands on the bars), is to lean my body off to the left of the bike (i.e., like I'm looking around the left side of the windshield).
Most people won't notice it, but I have carpal tunnel syndrome in my wrists....and on trips where I ride day, after day, it starts to cause me issues.
After testing every thing I thought was causing the problem, like the crown of the road, loose spokes, etc., I finally took the bike to the dealer. They confirmed the issue, and worked with Triumph to try to correct the problem (three weeks in the shop). They adjusted the front end, tightened spokes, put a new wheel on the front, etc., and could not resolve the problem.
Finally, the tech called me and told me that he took to brand new 800XC's off of the show room floor......Guess what???? HE SAID THAT BOTH OF THE NEW BIKES DO IT TOO!!!! He said I was welcome to come down and ride them as well to confirm.
I finally figured out a bandaid solution. I put my Giant Loop Coyote soft bag on the bike......then PUT A 15 LB. BUMBELL IN THE LEFT SIDE OFF THE BAG......and guess what, the bike tracks straight with my hands off the bars!!!!!!!!!!
Next time you're out on your bike, wondering if you could test to see if your bike does the same and advise
Thanks in advance.
The Breeze is offline   Reply With Quote
Old 03-28-2013, 10:56 AM   #16447
gusutavot800
gusutavot800's Avatar
Oddometer: 29
Mine does the same thing, I read somewhere that the additional weight of the exhaust on the right side is what does it, it weights around 15 lbs, I would like to hear from people who have a lighter aftermarket exhaust, maybe it makes a difference
"live everyday as if it was your last, one day you will be right"
gusutavot800 is offline   Reply With Quote
Old 03-28-2013, 10:56 AM   #16448
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,638
Originally Posted by The Breeze View Post
Hello Inmates,
Thanks in advance.
My XC had this issue. I corrected it by adjusting the front wheel.
Now, on a level road, removing my hands from the bars, the bike tracks straight.
Old 03-28-2013, 12:38 PM   #16449
fbj913
I ride
fbj913's Avatar
Oddometer: 2,353
UMMM... why do you need to take your hands off the bars for extended periods of time??? The way I would fix it is not to take my hands off the bars.
fbj913 is offline   Reply With Quote
Old 03-28-2013, 12:48 PM   #16450
The Breeze
Oddometer: 204
Uh ya......
Taking my hands off the bars was to method used to determine the problem.
What I like to do (which I can on my other bikes) is to "rest" my hands lightly on the bars while riding.....and therefore, minimize the vibes that are transferred into my hands/wrists. With this issue on my XC, I have to "counter steer" 24/7.....and push one side, pull on the other, or a combination of both to keep the bike going straight. This requires more pressure on the bars....which sends more "vibes" into my hands....and thus aggravates my carpal tunnel syndrome.
I bought this bike because of it super smooth/low vibration motor. However, because I have to continuously counter steer the bike.......it is causing me more carpal tunnel issues than other bikes that have more vibes....but don't have to be counter steered.
The Breeze screwed with this post 03-28-2013 at 12:58 PM
Old 03-28-2013, 12:56 PM   #16451
rustynut2
Oddometer: 474
My klr did this, it was cured by tweeking the rear wheel. Can't remember which way to tell you to adjust it at the moment. It was simple though, 1/2 turn on one side, ride and see if it was better.
Work harder, millions on welfare depend on you.
12 T800XC
09 KLR 650
rustynut2 is offline   Reply With Quote
Old 03-28-2013, 01:39 PM   #16452
lmychajluk
Oddometer: 1,856
Anyone know the stock size orange indicator bulb for the 800? Can I get it at any auto parts store, or maybe a BMW dealer (closer than the Triumph dealer)?
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 03-28-2013, 02:37 PM   #16453
some call me...tim
some call me...tim's Avatar
Oddometer: 279
Thanks everyone for the feedback on the tires. I went ahead and ordered a set of the Full Bores. I would have liked the longevity of the K60s, but considering that I could get a full set of tires for less than the price of one K60 rear, well, it's hard to not at least give them a try.
some call me...tim is offline   Reply With Quote
Old 03-28-2013, 04:57 PM   #16454
fbj913
I ride
fbj913's Avatar
Oddometer: 2,353
Uh ya......
Ic. Sounds like something is out of wack. Like others said, check wheel alignment. I can rest my hands lightly on the bars with no counter steer. I have never adjusted anything. Good luck.
Old 03-28-2013, 06:32 PM   #16455
marloweluke
The Flying Dutchman
marloweluke's Avatar
Oddometer: 149
Hello Inmates,
Thanks in advance.
Do remember that paved roads are crowned in the center for water run-off, so all road surfaces will slope downward which if you drive on the right side of the road will cause the bike to slowly drift right. No road is engineered flat otherwise standing water would be a hazard. On a straight empty stretch of road you could try riding in the left lane and see if it drifts left. If that is the case it is likely just the road design. Do this at your own risk of course.
It could be the muffler too. I have a carbon LV which is fairly light, so I haven't noticed the problem.
WITHOUT RISK........THERE IS NO ADVENTURE
marloweluke screwed with this post 03-28-2013 at 06:35 PM Reason: add on
marloweluke is offline   Reply With Quote
Times are GMT -7.   It's 05:48 AM.
