Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 03-28-2013, 08:37 PM   #16456
ongrade
Oddometer: 138
Originally Posted by Lion BR View Post
For the record, my XC also pulls to the right.
Check your rear wheel alignment to the swing arm pivot.
ongrade is offline   Reply With Quote
Old 03-28-2013, 08:39 PM   #16457
The Breeze
Oddometer: 205
Not sure about LionBR, but I did check the "rear wheel alignment to swing arm pivot".....and the dealer did it as well.....bike still pulls t the right.
The Breeze is offline   Reply With Quote
Old 03-28-2013, 08:59 PM   #16458
ongrade
Oddometer: 138
Try the alignment method on this site. It's for Harley's but doing this should show you if the frame is tweaked. Might even be able to adjust the rear wheel to the front enough to fix the off tracking.
http://glide-pro.com/media.html
Old 03-29-2013, 02:55 AM   #16459
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,750
Thanks for the feedback.
Unfortunately, I've ridden on the opposite side of the road (which should cause me to drift left)....but the bike is either balanced (if the camber is steep enough) or if the camber is slight.....it will actually pull to the right (up hill!). I've adjusted the rear axle/chain...still pulls right. The dealer tried the above....readjusted everything and it stills pull to the right. They even put a new front wheel on to test/verify the spokes/hub alignment.....still pulls to the right.
The next step was for them to swap front ends. This would verify that it's either the front end or the frame. They were going to do this, until they pulled the two new units off the floor, and they did the same thing.
I'm pretty sure it's a design issue (i.e., the weight of the big can coupled with the extremely steep rake of the front end). Like I said, it's very slight.....and most people, without carpal tunnel issues, on day rides.....wouldn't even notice the issue.
Oh well, at least I have a fix.....hang 15lbs on the left side of the bike (or less, if I install a lighter weight exhaust). My plan is to mount a tool tube on the left side of the bike (I always carry these tools, pump, parts, etc. anyway) and this should balance the bike.
It's just kind of a bummer that I have to do this............ Subsequent to this noticing this, I've taken my DR650 and WR250R on the same roads....taken my hands off the bars, and the bikes track straight as an arrow.
Originally Posted by rustynut2 View Post
My klr did this, it was cured by tweeking the rear wheel. Can't remember which way to tell you to adjust it at the moment. It was simple though, 1/2 turn on one side, ride and see if it was better.
That's what I would try. Adjust the rear wheel so that it steers you towards the left.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 03-29-2013, 08:17 AM   #16460
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
Pulling in either direction can be the stock tyres, tyres are supposed to be stored upright when not in use but if you store them laying down in huge piles (like in a factory) they can deform.
Blue&Yellow is offline   Reply With Quote
Old 03-29-2013, 11:47 PM   #16461
pilot3
Oddometer: 408
I need a couple of Wolfman Rack measurements if someone could spare a moment to visit their bike.
I've got the Scorpion can and don't like how far the Wolfman racks stick out on that side. To that end, I'm starting the design process for a snug fit rack. I've already got their bags.
What I need are the height and width of the Wolfman hoop on their rack and also the length of the straight horizontal segment before it begins to curve. I'll have the CAD program deal with drawing the radius of the curve.
No idea how costly this may end up but I figure its time to give it a go.
Thanks in advance,
p3
pilot3 is offline   Reply With Quote
Old 03-30-2013, 06:24 AM   #16462
riceaterslc
Urinal Cake Engineer
Oddometer: 130
p3
height = 7"
width = 12"
straight line = 6"
i have a .pdf i received from wolfman if you want. shoot me a PM if interested.
09 Street Triple R
12 Tiger 800XC
12 350 EXC-F
riceaterslc is online now   Reply With Quote
Old 03-30-2013, 08:44 PM   #16463
pilot3
Oddometer: 408
Originally Posted by riceaterslc View Post
height = 7"
width = 12"
straight line = 6"
Thank you sir! PM forthcoming.
p3
Old 03-31-2013, 05:34 PM   #16464
rockchucker
rockchucker's Avatar
Oddometer: 23
New XC sprung a leak
Any help from the collective would be appreciated. New, ~300 miles, xc got hungry and ate a screw that came out of the back half of he chain guide, munched on the cs sprocket guard and chewed a hole in the rubber coolant hose immediately in front of the cs sprocket. 500 mile service scheduled for next Saturday the 6th but it looks like I'll be trailering it there 150 miles and having a 300 mile service instead of 500. Should I be requesting a new cs sprocket and chain? Any thing else?
Thanks for any advice and loctite is your friend!
rockchucker is online now   Reply With Quote
Old 03-31-2013, 06:26 PM   #16465
Poweranger
Oddometer: 751
I would demand it. But It should all be covered without a problem. I will be checking mine since I have a few hundred miles now.
Poweranger is offline   Reply With Quote
Old 03-31-2013, 06:36 PM   #16466
rockchucker
Oddometer: 23
Yeah, I'm thinking chain, sprocket, sprocket guard, chain guide/swingarm guard and hose. We'll see what they say on Tuesday.
Old 04-01-2013, 05:59 AM   #16467
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,220
A little dirt goes a long way
Well, after 900 miles, I was finely able to get the Tiger out on somewhat technical (Class II+ for you kayakers) old jeep trails. Coming from a 2000 YZF 426, the Tiger XC blew me away on how well it tracks, rolls over chunky rocky terrain and handled when I had to blaze a turnaround through off trail. Every time I ride, I'm more impressed and am stoked I bought the Tiger.
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is offline   Reply With Quote
Old 04-01-2013, 07:37 AM   #16468
ducatirdr
Re-entry Noob
ducatirdr's Avatar
Oddometer: 132
I had the same experience this past Saturday. I hunted for some access trails to some right of way locations that are frequented by quads and dirtbikes. I found the Tiger XC with the stock tires did MUCH better than expected. I had experienced the feeling of the front washing out a bunch of times on sections where its lack of traction had it pushing and then recovering like a champ. I even was gassing it through the whoops getting some wheelies over them and even getting a little air in some sections. It was so much fun I spent the whole day off road on it surprising myself at the hits it was handling in bony sections and on moderate hill climbs. The last trail I was on was really wet and I though I may have bitten off more than the bike could handle. The sun was starting to get low toward early evening and I muscled the bike out of the muck pushing it as I fed it some throttle. I got it free and decided to call it a day. Just as I pulled onto the street the rear tire went flat. I pulled over not 15 feet from the trail exit to find a big nail in my rear tire. I called a friend with a trailer...
I went home and ordered a TKC80 front and Heideneau rear for it.
04 Buell XB12R - Feels fast but isn't = Good street sport bike
12 KTM 350EXC-F - Enduro machine with plate so I can ride to the trails near my house
13 Triumph Tiger 800XC - Sold after clutch stranded me at 4K miles in Berkshires
2000 Ducati 996S - Madness
2014 H-D Breakout - Nothing like a big scooter to relax a bit
ducatirdr is offline   Reply With Quote
Old 04-01-2013, 10:58 AM   #16469
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,750
It's obvious (to us!!) that it's either an oversight on assembly or poor PDI. Probably both. I would hope that anything that has been damaged by this will be replaced FOC, including chain and sprockets.
Old 04-01-2013, 11:08 AM   #16470
TxLoneRider
TxLoneRider's Avatar
Oddometer: 343
Eh? Errant bolt
Wow, I would also want to make sure there is a note on this on record. I, personally, would be reasonably worried about a premature failure of the counter shaft bearing, wheel bearings, or possibly even the engine castings.
Having the nut jam in the chain at the counter shaft sprockets could create large amounts of stress in the bearing and castings in the area ???
no??
TxLoneRider is offline   Reply With Quote
Times are GMT -7.   It's 05:59 AM.
