Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 04-14-2013, 06:25 AM   #16651
lmychajluk
Oddometer: 2,018
Ah... did a little Googling this morning. I suppose the 'PacSafe' thing you guys are talking about is the wire net, and not just the retractable cable lock linked above? I have the 50L OEM bag, so I can see throwing my jacket on top, putting my helmet on the seat, and throwing that net over the whole kit & kaboodle might be a good security option.
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is online now   Reply With Quote
Old 04-14-2013, 07:15 AM   #16652
Big Jon
Big Jon's Avatar
Oddometer: 339
Thumb
Congrats and welcome! We expect pics when you bring her home...
JON
Big Jon is offline   Reply With Quote
Old 04-14-2013, 09:08 AM   #16653
riverman
Life is great !
Oddometer: 180
Actually it was the cable lock that I was referring to. I discounted the net as it is too bulky and heavy for the few times a year I would use it.
Rory aka "Riverman"
'11 WR250R
'13 Tiger 800XC
riverman is offline   Reply With Quote
Old 04-14-2013, 03:01 PM   #16654
Seventy One
Seventy One's Avatar
Oddometer: 490
Dumb question about heated gear...
I'm looking at buying a jacket and pair of gloves from Warm N Safe but am a little confused as to how it all gets powered. The bike comes with one BMW/Powerlet plug already, and I've added a second because I was under the impression that this is what heated gear used. Now that I've done a little homework on it, I've found that's not the case.
I see WnS (as well as Gerbings) come with their own fused battery leads. Which should I use? Are the Powerlet/BMW plugs the prefered way or doesn't it matter?
BTW, are there currently any discounts for the WnS gear?
Thanks in advance.
"Dynamite comes in small packages." ~Anon.
2009 DR650
2013 800XC
Seventy One is online now   Reply With Quote
Old 04-14-2013, 03:28 PM   #16655
lmychajluk
Oddometer: 2,018
Most heated gear will use a coax connection, not a Powerlet plug, but there are adapters that you can get relatively cheap. Each manufacturer will tell you that their stuff is only meant for their gear, but it seems to me that all the stuff is pretty much interchangable .Gerbings and Powerlet both have the adapters. Look at the link below and you'll find a 1/2 dozen of slightly varying styles.
http://www.revzilla.com/heated-motor...atured&tab=all
-Lee
Old 04-14-2013, 07:24 PM   #16656
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 896
The Tiger is a very capable machine, have you done any off road?
XCRider803 is online now   Reply With Quote
Old 04-15-2013, 04:05 AM   #16657
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,966
you can buy an adapter and use your powerlet plug if you like. But the W&S (like all heated gear) comes with a pigtail that attaches directly to your battery. Hang the end out from underneath the seat in a convienient spot and you are good to go.
The Gerbing and W&S connectors are compatable by the way. I am currently using a Gerbing pigtail with my W&S liner.
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 04-15-2013, 05:32 AM   #16658
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,669
I have a full complement of WnS gear, and have no problems running it off of the secondary (under seat) powerlet power outlet. The only extra piece needed is the powerlet-to-coax adapter, available from WnS.
The wiring of the aux power outlet is enough to handle heat gear.
Old 04-15-2013, 06:00 AM   #16659
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
Thanks in advance.
Just buy a plug and fit it onto the leads. That way I easily move from one bike to the other and plug in the kit.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 04-15-2013, 08:52 PM   #16660
Borytop
Borytop's Avatar
Oddometer: 15
GPS Mount
Mounted the GPS this weekend! Thanks to henryII for his valuable input.
Borytop is offline   Reply With Quote
Old 04-15-2013, 09:54 PM   #16661
Windy Rider
Pussy Power
Windy Rider's Avatar
Oddometer: 364
Great set up, better than on the handle bars, could you please post a pic of the bottom mount attached to the bike
Cheers
2011 Triumph Tiger 800xc
Windy Rider is offline   Reply With Quote
Old 04-16-2013, 04:30 AM   #16662
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
Cheers
Some people use the "U" clamp around the bracket but I drilled two holes to suit the diamond shaped ball mount....
Old 04-16-2013, 05:25 AM   #16663
Cabriolet
Oddometer: 52
Same here,
Two holes, RAM diamond mount.
Held in place by two Stainless Steel cap head alan screws with stainles nyloc nuts.
With a RAM security key wing nut replacement.
Touratech locking mount, GTS-12 traffic antenna.
I also have the honda remote control
Bit awkward to see, but it is the small black rectangle about the size of a box of matches, mounted between the Scottoiler display and the Garmin Edge 800, really handy for turing the music volume up and down and zooming in and out to see junctions, much easier to press than the clunky tactile buttion on the Zumo 550.
Cabriolet is offline   Reply With Quote
Old 04-16-2013, 05:26 AM   #16664
Borytop
Borytop's Avatar
Oddometer: 15
Cheers
Also drilled two holes.
Old 04-16-2013, 05:33 AM   #16665
Windy Rider
Pussy Power
Oddometer: 364
Times are GMT -7.   It's 07:31 PM.
