Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 05-02-2013, 06:39 AM   #16816
cory1848
Oddometer: 314
Originally Posted by markbvt View Post
You don't need a center stand or swingarm spools. The chain is supposed to be adjusted with the bike on the sidestand. If you adjust it with the rear wheel off the ground, it'll be too tight when the suspension is compressed.
--mark
My manual says to adjust chain while the bike it upright with no weight on it. No mention of it being on the side stand.
Place the motorcycle on a level surface and
hold it in an upright position with no weight
on it. Rotate the rear wheel by pushing the
motorcycle to find the position where the
chain is tightest, and measure the vertical
movement of the chain midway between the
sprockets.
I checked the alignment and tension and the alignment was off about 1/16 of an inch. I fixed that my rear brake stuttering problem when away. The chain measured from the bottom seems to have about 40-50mm of play which I am questioning too loose? I know it is recommended to run the chains a little loose on the XCs but that seems like a lot. On my sportsbikes I have owned in the past, the chain was alway set with about an inch play while I was sitting on it. But that was race suspension without the travel of the XC. So would a chain being too loose cause the dreaded 4k vibration?
Finally got ahold of a service manual so will be checking torque on every bolt I can find this weekend. I suspect maybe a loose exhaust system bolt somewhere as well.
cory1848 is offline   Reply With Quote
Old 05-02-2013, 06:52 AM   #16817
Gronked
Oddometer: 20
800 Roadie vs BMW 1200GSA
Appologies if this has been covered elsewhere, I looked but didn't find anything.
I'm wondering if anyone can give an insight as to how the T800 roadie (NOT THE XC) would compare with the BMW1200GSA off road and adventure riding in general.
Both have the 19" front, but the GSA has spoked wheels.
T800 is lighter and easier to get your feet on the ground.
I don't know specs like ground clearance and suspension travel.
I just ask because I test-road the T800 and REALLY liked it... but didn't take it off the tarmac. I have owned a GSA in the past and done some easy dirt with it.
So as an adv bike and the one bike to own if you can own only one bike, would the T800 go anywhere the GSA would?
Assuming 1up only, limited off road skills, not intending to go mental in the dirt. Living in Australia, there is probly no dire need for the 33ltr GSA fuel tank.
Gronked is offline   Reply With Quote
Old 05-02-2013, 07:42 AM   #16818
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
Just an old dirtbike subject, but I put my rear axle nut on the brake side. That way if it hits a rock then it will get tighter instead of loose.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 05-02-2013, 07:47 AM   #16819
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,261
The A model GS is a special upgraded model. You really should be comparing to a standard R1200GS. The A has upgraded suspension, bigger tank, lots of guards and armor. It's taller and heavier, and has a lower first gear for crawling. It would be a little more adventure oriented than the T800.
Spoked wheels are an option on a GS. (Not sure about the A model) Standard are cast wheels like the Tiger. OTOH the spoked wheels on a GS are configured for tubeless tires.
The Tiger feels svelt and lively, the GS not so much.
Either bike will go anywhere you want to take it.
I have ridden both, as well as the Super Tenere. I did not bother with the Explorer, by the time I got to the Triumph store I had already elminated liter-plus bikes because they are so bulky. At the time I liked the Tenere better than the GS. The later felt cumbersome, shifted clunky, clutch is kind of odd (dry clutch) and the torque when you goose the throttle tries to rotate the bike over. I liked it just fine 2-up on the freeway, cruises nice and comfortable with good passing power. The Tenere was smoother and more refined, shifted like butter, but also feels really heavy at slow speed maneuvering for parking. Now having owned the 800XC for the better part of a year and 6K miles, I'd strongly suggest trying the Explorer 1200 if you're looking for the biggest bikes. And if you're going to spend that much money and that big of bike, and you mainly ride on the road, also look at Ducati Multistrada and Moto Guzzi Stelvio. On a budget the new Honda Crosstourer is getting favorable response, and there's the venerable Suzuki V-Strom big and small.
The GS is extremely popular and there is tons of aftermarket support. They hold their value well and are quite dependable, although there are known failures of the final drive, and they can be very expensive to maintain if you rely on the dealer. Older used models come up and can be a good buy on a budget.
The T800 is a different animal really, smooth and agile, I prefer it's suspension over the GS. The 19" front wheel is realy the only similarity, everything else is different. I would encourage you to ride both and decide for yourself. Either will tour on the hiway just fine, and either will venture off on dirt roads just fine as well. Either can be configured easily for luggage.
EDIT: BTW, you didn't mention budget. A T800 and a loaded GSA are like ten grand difference in cost. I've suggested a spread of new bike costs from about 8 grand to over 20.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 05-02-2013, 09:39 AM   #16820
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,753
Man if I hit a rock that hard to loosen a nut that's been tightened to 80 ft lbs. I'm thinking I might have more serious problems.
jimjim is offline   Reply With Quote
Old 05-02-2013, 10:23 AM   #16821
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,399
Yep, and dont make the mistake of over tightening it, so that it can be loosened for a trail/road side tire change, since most of us don't carry along a breaker bar in our tool kits. I had two flats last winter and may have stayed at a Holiday Inn Express to acquire this wisdom.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 05-02-2013, 11:59 AM   #16822
fbj913
I ride
fbj913's Avatar
Oddometer: 2,365
decently long size crescent wrench does the trick. if need be you just use your foot to push it. i keep one under the rear seat.
fbj913 is offline   Reply With Quote
Old 05-02-2013, 12:38 PM   #16823
cug
Oddometer: 4,968
I use one of these. Works great.
cug is offline   Reply With Quote
Old 05-02-2013, 04:56 PM   #16824
jmcg
Turpinated..
jmcg's Avatar
Oddometer: 449
I can't speak from experience for the GS/GSA, but I can say that the Roadie will handle easy dirt in Australian conditions.
We spent 2 weeks doing a 2up ride (mostly tarmac) with no issues worth reporting.
I was commuting over 100kms every day on the bike in reasonable comfort.
My wife rides the roadie on dirt trails around home with no dramas.
Fuel range is not an issue unless you're really going off the beaten track. Save on size and weight for everyday use, take a fuel bladder if going bush I reckon..
Tubeless tyres are the way to go for incompetents like me
The Tiger in general is, as so many here have reported, a great 'all round' bike.
The roadie will go most places the XC can, missing out on some suspension travel, etc.. It's up to how you ride and use it, I guess.
The roadie was the easy choice for us because we wanted to tour on-road mainly with the ability to follow some dirt tracks occasionally. I don't feel the need to take a 'big' bike on really gnarly single track, so it suits my purposes just fine.
Sorry I can't offer more of a comparison, but as someone has said, I think you're comparing two bikes that aren't really in the same category (price, weight, off-road ability, range).
What I can say is: if you choose the Tiger, you won't be disappointed.
All the best.
Cheers,
JM.
jmcg is offline   Reply With Quote
Old 05-02-2013, 05:13 PM   #16825
strider.deano
Oddometer: 333
strider.deano is offline   Reply With Quote
Old 05-03-2013, 10:42 AM   #16826
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,870
I just use the one that came in the meagre tool kit. Do up the nut with it and you should be able to undo it with it. I've never, in 40 years, bothered to torque an axle nut to spec.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 05-03-2013, 11:35 AM   #16827
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,765
Well kids, seems after nearly 34,000 miles I've finally had something go wrong on my Tiger: the fuel gauge float seems to have developed a leak. The last tank of gas appeared to get depleted extremely quickly, and when I filled up last night, the gauge only went back up to two bars from the top.
Oh well, it was just a convenience anyway. I've always done fine riding my Bonneville and XR650L without fuel gauges, just using the trip meter. If at some point I get the Safari tank, I'll use the opportunity to also replace the float, but until then, no big deal.
Naturally this happened two weeks after the warranty expired.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 05-03-2013, 11:38 AM   #16828
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,853
--mark
Only two weeks after warranty expiration I'd definitely still take it to the dealer. I think there is good chance they could still take care of it for you.
swimmer is offline   Reply With Quote
Old 05-03-2013, 12:38 PM   #16829
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,262
--mark
I thought the warranty was 2 years OR 24,000miles - whichever comes first ?
I will say that my crank snapped on my Sprint well out of warranty and Triumph took care of it all.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-03-2013, 12:40 PM   #16830
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,853
unlimited mileage.
Times are GMT -7.   It's 05:52 PM.
