Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 06-04-2013, 09:19 AM   #17206
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,710
Originally Posted by rrr70 View Post
$30 for spools and $50 for paddock stand
+1
The spools also help add some swingarm / rear axle crash protection, and weigh a lot less than a centerstand.
Old 06-04-2013, 09:26 AM   #17207
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,363
Originally Posted by BornToWander View Post
I just bought a used 2011 Tiger 800. It is fully-farkled but lacks a centerstand. I have cleaned and oiled the chain by walking the bike along, but in my opinion it's a pain. Of course I could buy a centerstand for it, but I would like to avoid the $300 expense (installed) if possible. The bike has the metal Triumph bash plate, and I am wondering if it is sturdy enough to raise the rear tire via a floor jack???
Any suggestions? If anyone has experience with this, I would sure appreciate hearing from you. Thanks!
For a roadie with tubeless tires this is probably not a biggie. For the XC it would be extremely difficult to remove a wheel for a flat repair in the field without a center stand.
The 'sump guard', as they call it, is mounted on rubber bumpers - not sufficient for lifting the bike in my opinion. Seems to me there's a warning about that in the mounting instructions for it.
Spools and paddock stand is a good option for a roading version.
In any case, an Enduro Star stand is a nice addition to the road-going tool pack: www.endurostar.com
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is offline   Reply With Quote
Old 06-04-2013, 09:35 AM   #17208
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 297
Originally Posted by some call me...tim View Post
It sprang back into position and felt totally normal, besides not going into gear. Kind of like when sometimes on if you're travelling at highway speed and have to come to a quick stop on a bike, you can have issues clicking down into first. In those cases, it's easily resolved by letting out the clutch or rolling the bike a few inches. In my case, though, the clutch and rolling did nothing to help the situation.
Hi Tim,
Had this happen to a friend's Tiger on a ride last summer, it required an actuator part inside the transmission to be replaced... The mechanic told me it was an unlikely issue but the design of the transmission made the service quicker and cheaper than it could have been, which was a compliment on the tiger design IMO. In this case the rider came afoul of a very deep rut and did a 180, coming down hard on the shifter with enough force to shatter an internal part. I came up behind him after it had already happened.
You can see how it looked on the trail from about 2:50 on this video from that ride. http://youtu.be/5EYXJ2LXMec
Wish I could tell you the exact name of the part but I reckon you'll know before I could find out.
Lusting for: Currently Sated with the new XCx
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2015 Tiger 800 XCx -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster, 2011 800 XC
Mr_Chris is offline   Reply With Quote
Old 06-04-2013, 10:42 AM   #17209
ttime4four
ttime4four's Avatar
Oddometer: 272
Originally Posted by blacktiger View Post
What you do in this situation is, save/bookmark this website http://www.worldoftriumph.com/triump...odel_id=560041
Then you can look at the diagrams of the wheels http://www.worldoftriumph.com/triump...lock_03=560041 and look at the bearings which shows their size, item 7 = 20x47x14 so your front spindle is 20mm diameter.
I'll let you practice to find the rear spindle size.
blacktiger,
thanks for this info - I had originally looked at Bike Bandit (similar to your link) for parts info looking for the specs on the axle itself. I didn't think far enough to look at the bearing size.
http://www.bikebandit.com/2011-trium...4256#sch739153
When looking here - it looks like the rear is also 20mm.
Item 4: BEARING,BALL,20 47 14 p/n 1398742
'14 KTM 690 Enduro R
'14 BMW R nine T
ttime4four is online now   Reply With Quote
Old 06-04-2013, 10:55 AM   #17210
fbj913
I ride
fbj913's Avatar
Oddometer: 2,396
pretty sure if you read the manual, or maybe its on the sump guard directions, it says not to raise the bike in that area.
fbj913 is offline   Reply With Quote
Old 06-04-2013, 11:26 AM   #17211
bross
Where we riding to?
bross's Avatar
Oddometer: 4,695
Setting sag
Just trying to set the sag on my XC. Rear travel is 215mm so 30% of that is 70mm. With the bike on the center stand, rear wheel off the ground I measure 66mm from axle to seat seam. With me seated in gear I measure 57mm so my sag is 9mm.
I weigh 200lbs w/o gear so probably 225 with all my gear on so it's not because I'm a featherweight. Shock is set to factory settings. What am I doing wrong? With my weight shouldn't I be seeing a lot more sag?
Old 06-04-2013, 11:42 AM   #17212
fmunson
fmunson's Avatar
Oddometer: 47
Brake cable / Rox Risers
Folks,
My brake cable is just a little to short to add The 2" Rox risers that have been sitting in my farkle box. Do any of you have experience in ordering custom cables or know of an easy solution for the mechanically challenged?
fmunson is offline   Reply With Quote
Old 06-04-2013, 12:19 PM   #17213
strider.deano
Oddometer: 334
Originally Posted by fmunson View Post
Folks,
Do you have a XC or Roadie? The 2" Rox risers worked fine on my XC, no mods needed!
strider.deano is offline   Reply With Quote
Old 06-04-2013, 12:23 PM   #17214
ongrade
Oddometer: 139
Sure your not using a centimeter tape? 66 mm is only 3" roughly.
ongrade is offline   Reply With Quote
Old 06-04-2013, 01:14 PM   #17215
bross
Where we riding to?
bross's Avatar
Oddometer: 4,695
Ding, ding, ding we have a winner and I'm an idiot.
66cm = 660mm
57cm = 570mm
for a sag measurement of 90mm which makes total sense given my weight and the stock suspension. Thanks for pointing out the obvious ongrade and you'd think I'd know that given we have been using the metric system in Canada since the 70s.
Carry on with your regularly scheduled programming.
Old 06-04-2013, 01:54 PM   #17216
outagas
Oddometer: 19
Just buy a paddock stand, Oxford do a twin wheel very robust one for around £60 UK !
Some bobbins and its really easy to lift!
You can then adjust your chain away all day long!
Rgds Lee!
outagas is offline   Reply With Quote
Old 06-04-2013, 02:35 PM   #17217
bross
Where we riding to?
bross's Avatar
Oddometer: 4,695
Rgds Lee!
At home. Doesn't do you any good on a trip. I prefer a center stand, even at home in my shop where I have paddock stands, motorcycle jacks, stands you name it. Even have one of these...
which works OK on street tires but not so well on a bike with knobbies.
Old 06-04-2013, 03:56 PM   #17218
fmunson
fmunson's Avatar
Oddometer: 47
XC, too tight for comfort. I tried to reroute but made it worse.
Old 06-04-2013, 04:11 PM   #17219
Vzuke
Vzuke's Avatar
Oddometer: 150
Risers risers.
I have XC risers on a roadie with the 2" Rox risers.
The clutch cable is taunt at full lock but it doesn't effect the operation.
I put some door edge molding on the gas tank bracket so the cable wouldn't rub.
Vzuke is offline   Reply With Quote
Old 06-04-2013, 04:48 PM   #17220
fbj913
I ride
fbj913's Avatar
Oddometer: 2,396
i've had 2" risers for almost 2 years now. zero problems.
Times are GMT -7.   It's 12:10 PM.
