Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 06-07-2013, 07:59 AM   #17251
fbj913
I ride
fbj913's Avatar
Oddometer: 2,356
there is like 8 pages of the filler hole bar discussion somewhere. this thread or maybe the XC offroad thread. some were plastic and they are breaking off and falling into the tank.
fbj913 is offline   Reply With Quote
Old 06-07-2013, 11:54 AM   #17252
thickwicket
Oddometer: 28
My Tiger Speaks
Hello Inmates....
I'm in Tiger heaven on my new '13 XC and amazingly, I have one month off to get to know this bike. As is always the case with a new bike, there are discoveries along the way. I originally posted this on triumphrat.net but thought I would throw it up here and see if anyone has any ideas...
......."I had the time today to go for a 4 hour ride: a mix of highway (keeping the RPMs below 5000 ) and city, some rush-hour traffic (first gear for MILES...) and a quick night-time spin to finish off the day. First of all, I am hearing a strange sound coming from either the front or rear wheel: it sounds like a moan. I know, I know... but that IS what it sounds like. I noticed it at around 2500 RPM, in first gear - it is rhythmic in that it seems to be controlled by the rotation of the wheel. Also, the rear brake makes a sound I can't quite describe...
I have had only one other new bike before this one (and I know all machines have their quirks) and I am determined to just enjoy this bike, but I just wanted to see if anyone else has experienced these noises. You are right, I am breaking in a new bike so I do expect some things will rear up and then fade away as things loosen up a bit...."
Ideas? (And thanks!!)
thickwicket
If you're too comfortable, you're not breaking new ground
http://daily-201.tumblr.com
Member I.A.T.S.E. 891
thickwicket is offline   Reply With Quote
Old 06-07-2013, 12:11 PM   #17253
fbj913
I ride
fbj913's Avatar
Oddometer: 2,356
Originally Posted by thickwicket View Post
Hello Inmates....
thickwicket
no idea about any of those noises. maybe take it back to the dealer and have them ride it...
Old 06-07-2013, 12:21 PM   #17254
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
Hello Inmates....
thickwicket
Check your chain tension, dealers are notorious for over tightening a chain, especially with the longer travel on the XC and with chains, looser is better. You should have 1 1/2" free play. If it's banjo string tight you might be getting a harmonic off it as the suspension goes through it's stroke.
Got a center stand? Check your rear wheel spins freely and no binding of the brake disc. Check alignment of the rear wheel. You can use the string method but I like this Motion Pro tool for that job, makes it quick and easy.
String Alignment method
Old 06-07-2013, 12:25 PM   #17255
lmychajluk
Oddometer: 1,928
.... I noticed it at around 2500 RPM, in first gear - it is rhythmic in that it seems to be controlled by the rotation of the wheel. Also, the rear brake makes a sound I can't quite describe...
thickwicket
Could it be that the rear wheel isn't in alignment, and the brake is rubbing a bit? Can you put it on the center stand (or a stand) and watch the rear wheel spin and listen for the sound?
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 06-07-2013, 01:06 PM   #17256
fbj913
I ride
fbj913's Avatar
Oddometer: 2,356
OOh i like that thing. A zip tie works well too. Just attach it to the swing arm somewhere and see if the wheel hits while spinning...
Old 06-07-2013, 04:20 PM   #17257
some call me...tim
some call me...tim's Avatar
Oddometer: 279
Originally Posted by blacktiger View Post
And when you get it back, repaired, I hope you're going to make some "brake snakes" which should help prevent the levers doing strange things. Quite common in Enduro circles. Here's my homemade setup using a pushbike brake inner and an electrical screw terminal connector. Total cost = 2.50 for both sides.
http://www.youtube.com/watch?v=WtTE08HliM4
Some levers actually come pre-fitted http://www.ebay.co.uk/bhp/brake-snake
Another observation regarding protecting the foot levers.........none, absolutely NONE of the crashbars available for these bikes offers any protection to the levers.
You know? Some sort of loop just ahead of the levers (refer to above photo) would stop them digging into the dirt in a fall.
Well, after some difficulty, the bike has finally made it into the shop. The diagnosis is as Mr. Chris suggested, the knock broke the detent wheel, which is part #5 in this schematic: http://www.bikebandit.com/2012-trium...4268#sch740799 The part is only $25, but other small parts like the gasket and circlips will need to be replaced. And part of the broken detent wheel is still in the engine, so an oil and filter change will be needed. Basically, looking at ~$300 for parts and labor, which is not covered by warranty. I tried to get it covered, but they wouldn't do it since it wasn't a manufacturing defect. The lady I spoke with at Triumph NA and she gave me the same silver lining rationale that Mr. Chris alluded to: it could be a lot worse with other designs which would require the case to be split in order to get to the mechanism.
So yeah, I'm kinda bummed that such a minor little incident made for such a miserable Sunday outing is costing me $400+. It seems like the Tiger's rugged good looks are actually disguising a glass jaw. I guess it's comforting to know that this isn't a regular issue (the mechanic said he'd never seen it before either), but still, a bummer.
Blacktiger is right about how there's no protection for the levers. I don't know if those brake snakes would have helped in my situation, but they certainly wouldn't hurt either. I'll be attaching some of those when I get the bike back again, for sure. I also wonder if a folding shift lever might have made a difference?
some call me...tim is offline   Reply With Quote
Old 06-07-2013, 04:25 PM   #17258
fbj913
I ride
fbj913's Avatar
Oddometer: 2,356
take it back now if you don't want to spend money on it. or stay on the paved roads for a better chance of not spending money on it. its a tough bike, but still has mechanical parts that can and will break. things happen.
Old 06-07-2013, 04:38 PM   #17259
some call me...tim
Oddometer: 279
Yeah, I get that. I've already spent a decent amount on things that are supposed to protect it, to help prevent things happening. This was it's first real jaunt into off road terrain, and as such, I wasn't going anywhere too gnarly, or pushing too hard. Just a low speed dump into soft dirt/mud and the bike was rendered useless.
Old 06-07-2013, 05:11 PM   #17260
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,585
broken shifter linkage
A folding shift lever is probably a good recommendation. Add the cable guard thingies as well.
I keep saying this bike is a ROAD BIKE outfited to go off pavement - IT'S NOT A DIRTBIKE. If you dump it and break shit it's gonna cost you.
No matter what kind of guards and protections you install on the bike it's still a 475lb road bike. One look at the air filter tells you that, and a quick glance at the curb weight.
Sorry yours broke, though I do feel for ya.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 06-07-2013, 05:24 PM   #17261
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,563
That's been my favorite part so far. Talking about the filler hole.
swimmer is offline   Reply With Quote
Old 06-07-2013, 05:30 PM   #17262
JWeier
Oddometer: 12
Sargent Saddle Seat Issues
Does anyone on hear have a sargent saddle for their Tiger 800? I just bought the low version and have two issues.
1. I can't install the riders seat when both bars under the seat are set to low. The issue is that I can't get both the front and rear bars under the lips at the same time. I've verified that any other bar combination (low, high or high, low) work.
2. The passengers seat latch pin doesn't latch. I've tried pushing down (and almost tipped the bike) and I've verified that nothing is in the way.
Any ideas, thoughts or experiences with this situation and saddle?
JWeier is offline   Reply With Quote
Old 06-07-2013, 06:59 PM   #17263
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,266
Some of you who are handy with a wrench and/or those of you who are experiencing vibration in your T800's might want to read my post in the Tiger 800 problems thread:
http://advrider.com/forums/showpost....&postcount=353
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 06-07-2013, 07:22 PM   #17264
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,585
Outstanding. Certainly worth a check.
Old 06-07-2013, 10:02 PM   #17265
rrr70
Oddometer: 144
Is broken turn signals stalks a known issue on T800s? Found RR turn signal hanging on the wire. I guess another visit to the dealer tomorrow.
rrr70 screwed with this post 06-07-2013 at 10:09 PM
rrr70 is offline   Reply With Quote
Times are GMT -7.   It's 02:06 PM.
