Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 06-19-2013, 02:06 AM   #17356
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,893
Originally Posted by browneye View Post
I don't 'trail ride' my 800 so the bigger one would just be more of the same great features the 800 has.
I thought that some years ago when I traded an XJ650YICS for an XJ900S. It's not always the case of the big brother is better.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 06-19-2013, 08:40 AM   #17357
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,373
That motor mount shim is what blows me away. Would never have found that myself.
Thanks Bueller!!
Glad it helped. Between that adjustment and the throttle body sync I just did during my 12k service the bike is the best it's ever been!
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 06-19-2013, 08:42 AM   #17358
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,956
I'm actually happy to find out I have the shim type mount as it seems like now that I have fixed it, it shouldn't go out of adjustment.
Just curious, do you recall what numbers you were getting on your throttle sync before adjusting? Just wondering how far off it was. At 14k miles mine were all reading the same value.
swimmer is online now   Reply With Quote
Old 06-19-2013, 09:34 AM   #17359
cug
Oddometer: 5,021
I remember that you need a cable extension for the fuel pump to do the throttle body sync. Is that correct?
cug is offline   Reply With Quote
Old 06-19-2013, 11:35 AM   #17360
KildareMan
KildareMan's Avatar
Oddometer: 692
You can get by with the tank resting on a block of wood at the rear
Sent from my Tiger 800
KildareMan is offline   Reply With Quote
Old 06-19-2013, 11:45 AM   #17361
cug
Oddometer: 5,021
Old 06-19-2013, 11:50 AM   #17362
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,956
Before you get too worried about pulling your tank etc... just plug in TuneECU and see if your TB's are in need of any attention in the first place.
Old 06-19-2013, 12:04 PM   #17363
cug
Oddometer: 5,021
Understood. I'll do that this weekend. Need to work out some other things first.
Old 06-19-2013, 12:17 PM   #17364
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,956
I only mention but I was planning for supporting the tank while still being able to access the adjusters etc... and then I just connected to the ECU and everything was fine.
Old 06-19-2013, 01:32 PM   #17365
cug
Oddometer: 5,021
I'm a lazy bastard - I would never touch the tank before I knew I absolutely had to ...
Have to take the fork apart today, maybe as part of that I run it for a short while with Dealertool attached and see what the TBS tool says. Have to look up how this is done anyways, haven't done it before.
Old 06-19-2013, 04:45 PM   #17366
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,373
1 & 2 were pretty even at 630 hot idle, while #3 would read 620. That was within spec, but since i had it all apart anyway i decided to get it as close to perfect as possible - a carry over OCD habit from the days when i rode a surging BMW oilhead RT. Because the data refresh is a bit slow in TuneEcu, I adjusted 1 & 3 so they matched 2 (which is controlled by the stepper motor), and continued fine adjustment until they would all change to the next increment pretty much uniformly - or as close as I could get it.
Old 06-19-2013, 04:49 PM   #17367
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,373
I rested the tank on the rear tangs for the rear mount by moving the tank slightly to one side. No block of wood needed.
Old 06-20-2013, 05:15 PM   #17368
fbj913
I ride
fbj913's Avatar
Oddometer: 2,394
Originally Posted by Mercury264 View Post
I thought I saw a post in one of the many Tigger 800 threads about someone who had mounted a small pelican box on the inside of their pannier racks as a small toolbox but buggered if I can find the post.
Anybody here that did that
I saw this too. Now i'm looking for it. Find it yet?
fbj913 is offline   Reply With Quote
Old 06-20-2013, 05:44 PM   #17369
RodT
Oddometer: 352
Brake pads question?
Is there a difference in ABS model brakes pads and non- ABS pads? They have both listed on E-bay, but the Triumph parts fiche only lists one type. I searched for this , but no luck.
Any fool can criticize,condem and complain and most fools do. Ben Franklin
RodT is offline   Reply With Quote
Old 06-20-2013, 05:45 PM   #17370
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,956
no difference
Times are GMT -7.   It's 09:08 PM.
