Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 06-24-2013, 06:48 AM   #17401
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
Originally Posted by advtenn View Post
I agree that its not a lubricant.
But WD-40 is enexpensive and 20,000 is ok with me.
I would say your in the right here as long as it's an o-ring. In this case WD-40 is just cleaning/ keeping the rust to a minimum.
fbj913 is offline   Reply With Quote
Old 06-24-2013, 06:50 AM   #17402
dwoodward
dwoodward's Avatar
Oddometer: 5,607
Fair enough. Actually, given I normally replace a chain because it's rusty before it's worn out, WD-40 may make as much as mine, which is 75% cheerful neglect, 20% semi-focused maintenance, and 5% self-flagellation over the cheerful neglect...
dwoodward is offline   Reply With Quote
Old 06-24-2013, 08:11 AM   #17403
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,806
Originally Posted by Bueller View Post
What about the barkbuster handlebar inserts? Do they interfere with the heated grip wiring that runs inside the handlebars?
Sorry I didn't realise you wanted to use OEM heated grips. So no, those inserts will not work.
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 06-24-2013, 08:50 AM   #17404
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
I will get a Scott E-oiler.
I am not going to pollute this thread with chain oiler topic but if you really want the best chain oiler get a pro-oiler. I have about 100k miles on mine (4 different bikes).
swimmer is offline   Reply With Quote
Old 06-24-2013, 09:00 AM   #17405
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,284
That's the one that requires a NASA engineer to program, right?
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 06-24-2013, 09:09 AM   #17406
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
I am sure it might be more involved than the others but it's not really that complicated. Since you tend not to have to adjust the programmed settings (you can adjust the rate up or down simply on the fly for changing conditions if needed) at all once you get it set up it's sort of a one time hassle - until you change bikes.
I am not one to just promote something simply because its the one I bought trying to justify to myself why I bought something, I really think it's the best oiler available. If you contemplate getting one I'd be happy to have a discussion about it offline if no one else wants to hear about it and you can't find the info you are looking for elsewhere.
Old 06-24-2013, 10:03 AM   #17407
cug
Oddometer: 4,923
I'm at least curious in how involved the installation is and what the necessary steps are.
cug is offline   Reply With Quote
Old 06-24-2013, 11:13 AM   #17408
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
OK, I'll try to put together a pictorial of my installation and why I am such a fan of this particular device.
Old 06-24-2013, 11:25 AM   #17409
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 387
Thumb
Originally Posted by fbj913 View Post
here is what i accomplished today! i'm way happier with this than that shotty tool tube! also rode in the pouring rain on these dirty north dakota highways. it looks like i rode through 100 muddy puddles.
Looks great! I want to add a small Pelican as well. How did you mount yours?
TIA
Galen
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is online now   Reply With Quote
Old 06-24-2013, 12:48 PM   #17410
cug
Oddometer: 4,923
Thanks. Much appreciated!
Old 06-24-2013, 01:09 PM   #17411
JWeier
Oddometer: 12
Tool Case
I saw this too. Now i'm looking for it. Find it yet?
There is also this one too: http://www.advmotorrad.com/index.php...product_id=197
JWeier is offline   Reply With Quote
Old 06-24-2013, 02:54 PM   #17412
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
TIA
Galen
Not sure if you can see the happy trails tool mount that fits inside the rack... here it is. http://www.happy-trail.com/Happy-Tra...ity-Shelf.aspx. I attached straight to that. I didn't use the L bracket things just the steel that fits inside the square.
I just attached straight to that. 4 bolts with lock nuts, centered, and low enough that it wouldn't hit the frame when opened. I'll take some more pics this evening.
Old 06-24-2013, 08:18 PM   #17413
PYG RYDR
PYG RYDR's Avatar
Oddometer: 387
Thanks. That is helpful. Of course photos are nice too!
TIA
PYG RYDR
MSTA-NVR
Old 06-24-2013, 09:52 PM   #17414
dwoodward
dwoodward's Avatar
Oddometer: 5,607
Odd malfunction
The fuel hose disconnect from the pump / bottom of the tank spontaneously disconnected today. Other than spraying gas all over a hot engine, and setting me up to do a Colin Edwards impression, no big deal, right?
It's been a year since I was under there- can't imagine it held on that long w/o being fully connected. After it cooled off (and I was sure it wasn't going to go WHOOOF while I was messing with it) I was able to get a hand in there and push it back on and make sure it clicked back into place, but has this happened to anyone else?
I'm planning on ordering a new one tomorrow and replacing it just to be safe.
Old 06-24-2013, 10:08 PM   #17415
rrr70
Oddometer: 152
Put Full Bore tires on the Roadie. Running 42/36 PSI F/R. Very heavy steering at slow pace and I have to push much more to turn at higher speeds. Never had anything like this even with 606 knobbies on KLR. WTF?!
rrr70 is offline   Reply With Quote
Times are GMT -7.   It's 10:23 AM.
