Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 07-14-2013, 02:29 PM   #17806
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,567
Originally Posted by ArmyDOC View Post
Dropped my Tiger in the driveway... Looking for a replacement signal light lens. I found one on bikebandit.com but it tried to charge me for 4 at $10 ea. Any other suggestions other than the dealer.
Thanks.
BTW, broke the clutch lever too.
You must be entering something wrong. Bike Bandit lets me select just one. I have a spare new one that I bought from Bike Bandit when I wasn't sure if the indicator assy that I was buying included the lens.
swimmer is offline   Reply With Quote
Old 07-14-2013, 02:31 PM   #17807
theDub
theDub's Avatar
Oddometer: 41
You can buy just one. Enter "1" in the quantity field and click add to cart.
2wheelpros.com is another source I use for OE parts.
theDub is offline   Reply With Quote
Old 07-14-2013, 02:43 PM   #17808
ArmyDOC
ArmyDOC's Avatar
Oddometer: 34
Thanks. Will try it again. I entered "1" and when I to check-out it was $40... I will try it again.
Do not follow where the path may lead. Go instead where there is no path and leave a trail.
2012 Tiger 800
ArmyDOC is offline   Reply With Quote
Old 07-14-2013, 03:32 PM   #17809
ArmyDOC
ArmyDOC's Avatar
Oddometer: 34
Thanks guys. Order confirmed!!
2012 Tiger 800
Old 07-15-2013, 12:14 AM   #17810
SPX
Oddometer: 241
I'm going to attempt to do my own oil change on my 800XC this week. I'm a complete newbie to maintenance, but I think that the oil change is probably a reasonable place for me to start.
What tools will I need to do the oil change? I am thinking a torque wrench (for the filter & drain plug), an oil filter adapter for the wrench, and a set of hex bit sockets (metric?). Have I missed anything else?
I have the filter, crush washer, and oil, which I believe is all the stuff that I will need...
SPX is offline   Reply With Quote
Old 07-15-2013, 04:45 AM   #17811
KildareMan
KildareMan's Avatar
Oddometer: 652
Don't forget something to catch the old oil.
I like to use a measuring jug to pour the oil
KildareMan is offline   Reply With Quote
Old 07-15-2013, 05:08 AM   #17812
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,945
be sure to put in LESS than the manual says you need on the refil. Then dribbed it up to where it should be. Otherwise you will end up overfull. Which is a PIA.....
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 07-15-2013, 07:11 AM   #17813
rustynut2
Oddometer: 479
3 3/4 qts of oil, close enough. If you buy the k & m filter it has a 17mm nut on the end to make it easier next time.
Work harder, millions on welfare depend on you.
12 T800XC
09 KLR 650
rustynut2 is offline   Reply With Quote
Old 07-15-2013, 07:22 AM   #17814
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
I agree with Yankee Dog. Go with less and make it up later. I've over filled mine twice now by using exactly what the manual says.
fbj913 is offline   Reply With Quote
Old 07-15-2013, 08:03 AM   #17815
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,213
Over fill as in to the top of the sight glass, or over fill as in it's pissing out some place?
What is the mechanical issue with over fill and will it hurt anything?
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is offline   Reply With Quote
Old 07-15-2013, 08:14 AM   #17816
rrr70
Oddometer: 144
Did some trail riding again yesterday. Mounted Contour camera on the right side on the engine crash bar. When reviewing the video I noticed that front is using pretty much all it's travel. Ziptie on the fork confirmed it.
What can be done?
rrr70 is offline   Reply With Quote
Old 07-15-2013, 08:17 AM   #17817
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
What can be done?
Is it bottoming out? Causing problems? Why not use all the travel? That's what it's there for.
Old 07-15-2013, 08:20 AM   #17818
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Over fill as in, too much oil. In my case above the over fill line in the site glass. The way I understand (I'm no mechanic) if you overfill- the oil pump works harder and can fail, it will spew out of the vent area in the air box, other motor mechanics will overall work harder, and I'm sure others. google it!
Old 07-15-2013, 08:59 AM   #17819
rrr70
Oddometer: 144
It is bottoming out.
Old 07-15-2013, 09:10 AM   #17820
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
take it to the dealer and see if it's a warranty issue. or have a suspension shop rebuild them. simply changing fluid levels may help. i had mine done with all racetech components. but they had 15,000 hard miles on them.
also, (and again, i'm no mechanic) if you don't feel a problem through the handlebars. or you aren't getting beat to death. i wouldn't worry about it. the travel is there for a reason.
Times are GMT -7.   It's 05:22 AM.
