Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 07-18-2013, 04:50 PM   #17881
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,566
Was doing some curiosity reading and ran across this from a honda owner in Atlanta. Unsolicited, off the wall, don't even know which honda he has:
Switched bike from Rotella t6 to Amsoil
Changed oil in bike today @ 2200 miles and took sample for an oil analysis, however.... i doubt i'm even going to waste the money to compare the two because switching to amsoil was an instant and obvious difference. Previously used rotella t6 since it's a cheap synthetic that tests well and is highly regarded with cycles, plus..... it's a honda, you can fill a honda with old fish grease and it'll be ok.
@ 2200 miles on an oil change, 75% highway and in a less than two month time span, the rotella was black as coal. Not surprised by that, you're not suppose to get long intervals on rotella, it wore out when it was suppose to wear out. The rotella performed within expectations, bike ran good, stayed right at temperature, and had a small amount of shifter clunk, mostly on down shifting. It was nothing beyond the realm of expectation though.
Switched to Amsoil yesterday and didnt really ride the bike until today. About 10 minutes from my house, my reaction was "omg". The difference is night and day. Everything smoother, idles better, low rpm is better, shifting is silent and silky smooth. unbelievable difference. Especially since the change was from a good oil to begin with. Even as someone who already recognizes that oils are not created equal, i didnt expect this dramatic of a difference between oils. Based on the clutch benefit alone, i'm gonna stick with amsoil. The rotella was "good enough", but amsoil difference is amazing.
I can tell you that mine shifted smoother after my last oil change. Will see what it's like after this thousand mile trip coming up over the weekend.
Back when GasGas came out with the new EC series enduros, they had bushings in the shift shafts and amsoil was about the only oil that wouldn't drag or slip and shifted the smoothest. That was back 15 years ago.
The oil wars rage on.
EDIT: BTW, seems like T6 is about $30 a gal at WM. Amsoil is $35 but I have to pay shipping so it ends up being a little more. Both are cheaper than many of the MC specific oils.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is online now   Reply With Quote
Old 07-18-2013, 05:10 PM   #17882
Randyincolo
Oddometer: 96
T6 it is. If Wally World doesn't have it Amazon does:).
Thanks for the input.
Randyincolo is offline   Reply With Quote
Old 07-18-2013, 07:52 PM   #17883
FishrCutB8
Oh HAI!
Location: The Green Between Philadelphia and Pittsburgh
Oddometer: 181
I used T6 and Amsoil in my Suzuki SV1000. Liked the T6. LOVED the Amsoil. As noted above, smoooooooth shifting. Like buttah.
FishrCutB8 is offline   Reply With Quote
Old 07-19-2013, 01:43 AM   #17884
pilot3
Oddometer: 401
Originally Posted by Randyincolo View Post
Never been on Bobs oil web site. Interesting you mention Delo 400 is not a suitable oil yet you recommend syn oils that are 5-40 and yet Triumph states you need 10-40 or 10-50. A minor point for sure. But then you say you would use Delo in some motorcycles but not the Tiger.
One thing I learned with motorcycles is when you change the oil they are always easier to shift for about the first 400-600 miles. I am 60 years old and still waiting for someone to tell me they have suffered an engine failure due to the brand of oil they were using.
Delo 400 is primarily a diesel oil first and for gas motors second. You will see this when looking at its API rating; C ratings precede the S ratings. C is diesel specifications, S for gas.
Look at Amsoil or any other oil made for gas motors and you will see the reverse; S ratings first, C second. If you doubt this, search out the Amsoil or any other diesel specific oils and you will find their C ratings first.
The first letter class is what type of fuel engine the oil is primarily formulated for. It may work for both but not the best choice in some cases. This is part of the purpose of the API rating system.
My thoughts on the early changing though. Oil has a detergent package for a purpose; to clean. By changing oil too frequently, the detergents don't get an opportunity to keep working. Dirty oil is not a bad thing (to be clear, I don't mean black sludge) but it means your detergents are working and cleaning your engine. In addition to that, let's think environmentally. Every oil change done when it doesn't need to be just introduces a few extra quarts of oil for disposal. Yes, we should be recycling but is it really necessary?
FWIW and I realise it may not be much.
pilot3 screwed with this post 07-19-2013 at 01:49 AM
pilot3 is offline   Reply With Quote
Old 07-19-2013, 05:54 AM   #17885
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,140
Not too much at all...
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-19-2013, 06:31 AM   #17886
FishrCutB8
Oh HAI!
Oddometer: 181
Wow. An oil discussion that actually echoes with sense and reliable information. I never thought I would see it. Kind of like a snipe; you know they exist...
Old 07-19-2013, 06:58 AM   #17887
rustynut2
Oddometer: 479
I by the recommended oil, Castrol, on amazon for a little over $7 a quart. Bought by the case, 2 cases = 3 oil changes. About $30 dollars plus a filter.
Work harder, millions on welfare depend on you.
12 T800XC
09 KLR 650
rustynut2 is offline   Reply With Quote
Old 07-19-2013, 08:14 AM   #17888
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Check for local distributors Chris, I found multiple people around town that will honor that price, you just pick it up.
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 07-19-2013, 08:27 AM   #17889
Randyincolo
Oddometer: 96
I picked up three gallons of T6 last night at Wal Mart. It cost $21 and change a gallon so grabbed three jugs.
Old 07-19-2013, 08:30 AM   #17890
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,566
That's a good price!
I'm still going to use Amsoil.
(The smilie is me drinking the koolaid. )
Old 07-19-2013, 10:38 AM   #17891
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,558
This was my experience when going from the T6 to Mobil1 which is why I stated I am earlier that I had been using the T6 but am not currently. I think T6 is still a very good oil at a very good price.
swimmer is online now   Reply With Quote
Old 07-21-2013, 07:58 AM   #17892
fbj913
I ride
fbj913's Avatar
Oddometer: 2,355
Never tried it to be honest, which Amsoil are you recommending?
the only 10-40 cycle oil they make.
http://www.amsoil.com/shop/by-produc...il/motorcycle/
fbj913 is offline   Reply With Quote
Old 07-21-2013, 07:56 PM   #17893
theDub
theDub's Avatar
Oddometer: 41
That's the MCF. There is also this: AMSOIL AMO.
It's 10-40, full synthetic, wet clutch compatable and JASO MA. But I don't think any one buys it because they can pay $1.50 more for the one that says "motorcycle" on the bottle.
theDub is offline   Reply With Quote
Old 07-21-2013, 09:16 PM   #17894
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
Only difference being the MCF moto specific oil is recommended for double the drain interval. The AMO stuff is only recommended for the manufacturers drain interval or longer if you test the oil. I'd rather just pay the $1.50/quart extra and skip the $25 oil analysis cause I do go longer on oil changes, on 4 bikes.
Old 07-22-2013, 02:16 PM   #17895
Charrito
Charrito's Avatar
Oddometer: 96
Wow...gone for a day and this is now an oil thread.
Tapatalk 4! Now with free NSA monitoring!
The views and opinions expressed in any of my posts do not necessarily reflect the views and opinions of this forum or anyone associated with it. Any resemblance to real persons, living or dead, is purely coincidental. Sometimes.
Charrito is offline   Reply With Quote
Times are GMT -7.   It's 09:22 PM.
