Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 09-24-2013, 11:01 AM   #18586
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,176
Question Front Rotor Tourque Bit Size
Anyone know what size the torque/star bit is for the front rotors? I need to replace the bent one with this nice new one and I don't have the correct size bit.
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is offline   Reply With Quote
Old 09-24-2013, 12:05 PM   #18587
henkew
Oddometer: 70
Originally Posted by browneye View Post
Lake Stevens, eh? Wifey's folks are in Marysville, her best friend in Lake Stevens.
Then ride Van-Isle to Port Hardy, BC Ferry to Prince Rupert, Steward, Hyder, then either Cassiar to Watson Lake and loop back to Bella Coola, or east to Prince George and south thru BC Interior.
I don't know her, but small world! Sounds like a great trip you have planned, I'll be watching for your ride report ;)
henkew is offline   Reply With Quote
Old 09-24-2013, 01:19 PM   #18588
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 435
Utility vehicle
I needed to haul a bail of straw to cover the grass seed I sowed this morning. The guy said he'd never seen anyone haul straw on a 'cycle before. I replied, "me either".
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. Ferris Bueller
Baja 2012, my first moto tour
Oaxaca, Estados Unidos Mexicanos
akaDigger is offline   Reply With Quote
Old 09-24-2013, 02:13 PM   #18589
btao
RIP Lilolita
Oddometer: 1,011
I got a set of bigger sizes that you can put a socket on. Remind me in the morning to bring them with me and I can stop at your place first before B&B (burgers n beer)
_________________________
Current: '13 Tiger 800 XC, '09 Subi WRX, '11 405hp Sti (wifey's) Past: '74 Honda CB 360, '81 Yamaha 650 Special II, '01 Bandit 1200S, '07 Bandit 1250S
btao is offline   Reply With Quote
Old 09-24-2013, 02:15 PM   #18590
btao
RIP Lilolita
Oddometer: 1,011
note: I did NOT say nudge me.
just trying to fend off any wise cracks from you hooligans
Old 09-24-2013, 02:23 PM   #18591
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 435
Front rotor takes T-40 torx bit. Torque to 22n or 16ft lbs.
Old 09-24-2013, 03:32 PM   #18592
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,176
Thanks Digger, so the torque is halfway between damn tight and friggin tight
I found a torque bit size table and measured screws with calipers and I also came up with #40
Lord John Whorfin
Old 09-24-2013, 05:15 PM   #18593
SMIFFXC
SMIFFXC's Avatar
Oddometer: 137
There's got to be a redneck joke in there somewhere...
SMIFFXC is offline   Reply With Quote
Old 09-24-2013, 06:23 PM   #18594
bassogap
Haulin' the kids around
bassogap's Avatar
Oddometer: 1,417
I grew up in LS...was pretty rural, then. LSHS, class of '82...
bassogap is offline   Reply With Quote
Old 09-24-2013, 06:46 PM   #18595
Seventy One
Seventy One's Avatar
Oddometer: 431
Is there some trick to shimming these engines?
I tore it down for the 12k service on the 13th of this month. The intakes were good but the exhausts were all off (tight). Most ranging around .227 - .290 clearance.
So I bought the appropriate shims and put it back together. I measured everything before buttoning it up and found that I was still off. It all came apart again and new shims were installed. Once again I double checked everything and found that I was still off. Things were getting closer but certainly not where they should have been, and still, way under spec (tight).
This is the formula I've been using to get the needed shim size.
A= (B-C) + D
A. New shim thickness
B. Recorded valve clearance
C. Specified valve clearance (.325- .375) (exhaust 800 XC)
D. Old shim thickness
I have pulled these cams out and re-re-re-re-re shimmed this bitch no less than 8 times since the 13th and am ready to throw a match on the POS and call my insurance agent.
I started it yesterday and all I heard was valve clatter. It wasn't the hydraulic tensioner I heard, it was valves. I measured everything an hour ago and everything was still around .250 -.330 +/- (nothing loose and most still too tight). WTF?!
I'm not a bad mechanic but this thing is making a complete fool outta me. What am I doing wrong?
PRESS SPACE BAR TO CONTINUE
____________________________________
2009 DR650
2013 Tiger 800XC
Seventy One is offline   Reply With Quote
Old 09-24-2013, 07:38 PM   #18596
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,275
Sounds like you're using inches instead of mm, so I'm at a loss with your numbers (which is odd coming from a yank that builds boats) but shims come in .05mm increments. Seems your math is correct. I just figure what the next size up or down is, added or subtracted to the shim that's in there to give me the right clearance based on what my feeler gauge is saying. If the clerance is .10mm and I need 15 and the one that is in there is marked 235 then I get a 230.
Are you sure you got the cam chain tensioner set right? They can be tricky.
Are you getting different clearance figures when you reinstall the cams?
Are you measuring in the right place?
I've never had to change more than a size up or down to get the proper clearance. But I haven't done the tiger either.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 09-24-2013, 09:41 PM   #18597
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,609
If you want more clearance you need a thinner shim.
Wouldn't it be A = D - (C - B)?
Using the above example:
D = 235
C = 15
B = 10
235 - 5 = 230
A = 230
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 09-25-2013, 12:40 AM   #18598
jolly green giant
biggles
jolly green giant's Avatar
Oddometer: 97
Revs at 90 mph
New to this thread. I am considering buying a Tiger 800 both for commuting and touring and was wondering what kind of revs the engine reaches while doing 90 mph. I currently have a GS and a Varadero and both seem to hang around 5000 revs at 90 mph which leaves the engine note at low pitch.
jolly green giant is offline   Reply With Quote
Old 09-25-2013, 05:40 AM   #18599
KildareMan
KildareMan's Avatar
Oddometer: 647
With stock gearing you'll be well over 6,000rpm. For me at 6k I'm doing 133km/h or so (approx 83mph)
KildareMan is offline   Reply With Quote
Old 09-25-2013, 08:11 AM   #18600
btao
RIP Lilolita
Oddometer: 1,011
This is one of the interesting differences in the Tiger vs F800GS, and one of distinction. I just finished reading the comparo in Motorcyclist Mag that also highlighted this, so I'll share my 2c after a half hour test ride on the GS.
The Tiger engine with its 3 cylinders is a beautifully revving engine with a 9,800RPM redline and makes more power higher in the range. The GS was "industrial" in the linear manner it provided power. It wasn't impressive, but functional. It's said to be an advantage on the trail but I wasn't able to test. If you spend any time at all on the road, the Tiger will be more fun.
The GS got very vibratious over 6000RPM and felt like you were pushing it beyond its comfort zone. It was fine when it was in the sweet spot. Because you never wanted to push the GS it always seems to get better gas mileage.
The Tiger is just way too much fun to wwWWWAAAAAAAAAAA!!! up in the range. And it's silky smooth the whole time. It was like a completely different machine once I got past the break in period and could use the throttle and rest of the range. My cheeks were sore from that ride because I was grinning so much...
Yea, the GS may be slightly better off road, but the Tiger, to me, was better if you were 50/50 because you could have fun on the trails, but still have fun on street rides rather than just riding around. All you need to wrestle with is what tires...
Times are GMT -7.   It's 06:05 AM.
