Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 01-24-2014, 08:35 PM   #19456
klinquist
übergeek
klinquist's Avatar
Oddometer: 1,095
Originally Posted by lawdogmd View Post
Yeah, no worries. I have been thinking about trimming that down after a full shake down. I am also considering buying the full bracket from Twisted Throttle, putting the 15% IMS coupon to good use perhaps.
I've got the SWMotech fog light brackets - very nice and dual mount points.
My 2013 Tiger 800 "Off-Roadie" (plate GETLOZT) - My 2003 DRZ (plate LV DRT RD) - My 2003 E350 Adventure Van (plate ADV VAN) - Amateur Radio W1ADV
klinquist is offline   Reply With Quote
Old 01-25-2014, 06:11 AM   #19457
motonut
Old Guy
Oddometer: 62
Biggest concern...
LawDog,
Looks are important to some... I may be one... BUT, the problem with the HD hardware is flexibility. They will give you a failure in time. I absolutely agree to go with some quality mounts for that reason.
motonut is offline   Reply With Quote
Old 01-25-2014, 07:54 AM   #19458
lawdogmd
Oddometer: 28
Originally Posted by motonut View Post
LawDog,
What can I say, I used to have a KLR. Old habits die hard.
lawdogmd is offline   Reply With Quote
Old 01-25-2014, 01:11 PM   #19459
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 488
Originally Posted by klinquist View Post
For those interested..
Ran the gas tank low yesterday... at 1 bar remaining the miles-to-empty read 4 then ---.... then the 1 bar disappeared and miles-to-empty said 0.
Rode another 3 miles or so and put in 4.45 gallons... so apparently you have .5 gallons beyond the 0 miles remaining.
Also for those interested..
I ran the gas tank dry. Bike began to sputter 20 miles after gauge read -- miles to empty. I rode the bike at a conservation pace during the 20 miles. I would say my findings corroborate klinquist's.
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. Ferris Bueller
Baja 2012, my first moto tour
Oaxaca, Estados Unidos Mexicanos
akaDigger is offline   Reply With Quote
Old 01-25-2014, 01:57 PM   #19460
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 488
Fuel Tank Weir Gone South
Okay, I knew there was an issue with this flimsy weir. I knew guys had complained about how easily they were knocked down into the tank. I still let random strangers fuel my bike during my just completed tour of Mexico. Now I will obviously have to get it out of the tank. No problem there. Can it be saved or is it f-ked? Any thing else I should know before I attempt to fix it?
I believe it was still in place when I took this photo.
I wish I had had my camera in hand when this attendant walked around the back of my bike and stuck the nozzle in the exhaust pipe. Don't wig out. I shut her down before there was any danger.
Old 01-25-2014, 02:31 PM   #19461
GearHd6
GearHd6's Avatar
Oddometer: 159
I assume you're talking about the bars that block the fuel fill? Mine are metal and rugged, some are plastic and very fragile. I'd just leave the pieces in the tank. No big deal.
2011 Tiger 800
2004 CRF250X
1998 Daytona
GearHd6 is offline   Reply With Quote
Old 01-25-2014, 04:27 PM   #19462
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 488
If that piece is made of plastic I should be able to salvage it. They should have left the fill weir as it was on my '11, steel and rugged.
Old 01-25-2014, 05:14 PM   #19463
pilot3
Oddometer: 407
TuneECU and DealerTool
I've got DealerTool which came with the USB to OBDII cable.
Is anyone using that same cable for TuneECU or does it require a different one?
I know the software differences, just want to know if the DT cable is compatible with both.
pilot3 is offline   Reply With Quote
Old 01-25-2014, 06:10 PM   #19464
kag
Wander Lust
kag's Avatar
Oddometer: 1,635
I say ride the thing until a great deal pops up for some mounts. Your mount is working
The fuel tank filler guard on my wife's Tiger 800 did not last 3 fill ups before it ended up in the tank. Its still floating around in there and there is no plan to fish it out either.
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 01-25-2014, 06:21 PM   #19465
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
I have both, and must use specific and separate cables for each.
Old 01-25-2014, 07:36 PM   #19466
kingofZroad
kingofZroad's Avatar
Oddometer: 342
Metal ones fall out too!! I got mine out before it could bounce around in the tank and do further damage...
Sent from my iPhone using the "hunt & peck" typing method...
kingofZroad is offline   Reply With Quote
Old 01-26-2014, 04:21 AM   #19467
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 295
I believe those are in there to protect an otherwise vulnerable fuel pump. But as long as la chica doesn't crack your fuel pump with the next overzealous thrust, you should be okay.
Lusting for: Currently Sated with the new XCx
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2015 Tiger 800 XCx -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster, 2011 800 XC
Mr_Chris is offline   Reply With Quote
Old 01-26-2014, 06:09 AM   #19468
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 488
I began fueling it myself after I noticed it was knocked out for that very reason. I had to admit to my riding buddy (who always fuels his bike himself) that I had let it happen. I got a good "I told you" from him.
Old 01-26-2014, 01:52 PM   #19469
WantToRideMoar
Oddometer: 310
2013 Tiger 800XC: I broke the center plastic support rod that passes through the windshield mount.
Bikebandit's schematic here is incorrect, though:
http://www.bikebandit.com/2013-trium...5146#sch784281
Part #7 is the area that broke, but the way it is on their schematic, part #7 has two tabs that stick out from it. My bike, there is an integral rod to part #14 made of plastic. Those tabs pass through a hollow opening in part #7.
Anyone know any other place to get parts for a Tiger?
2013 Tiger 800XC
1993 XR600R
WantToRideMoar is offline   Reply With Quote
Old 01-26-2014, 01:56 PM   #19470
IronJackWhitton
IronJackWhitton's Avatar
Oddometer: 136
So far stateside the cheapest for accessories is "all things triumph" out of Detroit. Granted I only know about accessories from them, but they are a dealer I think so they may be able to get parts for you.
IronJackWhitton is offline   Reply With Quote
Times are GMT -7.   It's 10:01 PM.
