05-08-2011, 03:13 PM
#5476 |
Oddometer: 513
The reflectors on the front forks of US bikes look hideous. Can they be easily removed? Not fitted on my 800 thank god.
I'm so clever sometimes I don't understand a single word of what I'm saying |
05-08-2011, 03:14 PM
#5477 |
05-08-2011, 03:31 PM
#5478 | |
Risk Taker
Oddometer: 1,130
They were removed 5 minutes after I got home. One bolt and done. Looks waaay better!!
2011 Triumph 800 XC 2007 Honda CRF 250X 1994 Kawasaki KLX 650R THE ADVENTURES OF TYSON AND HOBBES THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear! |
05-08-2011, 03:34 PM
#5479 | |
on the road o'dreams
Oddometer: 5,510
I attended an intro event for the Uly some years ago and got to hear Erik himself explain just how different his Uly was from a Harley. Would take a page to run it all down .... but one quick blast on one is really all you need for an I.Q. update. No real connection IMHO to your typical HD. Once you get used to all the Buell quirks ... it's a great bike. Such a shame HD big wigs pulled the plug. The Buell has a very different character from the Tiger ... 180 degrees ... but ALL GOOD in it's own way. And it's that diversity that everyone should be thankful for. |
05-08-2011, 03:43 PM
#5480 |
Oddometer: 5,510
Thanks for posting a rear view of the bags. First time I've really seen that rear angle. Me likes.
05-08-2011, 03:49 PM
#5481 | |
Oddometer: 5,510
A guy in the UK made a custom mounting rack that allows you to use the Left side pannier on the Right exhaust side. You need to go with a low pipe ... which are available for the 1050 Tiger. This puts the pipe Under the pannier and doubles your space in that bag. The fit of this set up looks OEM good ... and the bags fit perfectly and are balanced. I'm quite sure someone will do similar for the 800 Tiger's. |
05-08-2011, 04:14 PM
#5482 |
CAJUN
Oddometer: 1,645
It may not be just looks. It could effect stability if the luggage is not balanced from side to side. If one bag sticks out farther than the other, there would be more drag on that side, especially at speed. When I had my F650 with Vario bags I rode with the luggage telescoped in to the smallest width whenever possible. That reduced drag enough to improve fuel efficiency by 4 mpg.
05-08-2011, 04:29 PM
#5483 | |
And you could be right about the wind drag on the panniers. Never really thought of that. And I'm sure they can't help gas mileage much, but hey, fuel is cheap right?! LOL
05-08-2011, 08:54 PM
#5484 | |
Wrecking Ball
Oddometer: 1,501
Tiger 800 tools
But as my husband and I were looking over the Tiger this afternoon, it occurred to us that we didn't have a 17mm hex for the front axle, either. Since we are planning a 4-day trip at the end of the month, we thought it would be a good idea to kind of go around the bike and see what other specific tools might be needed for the Tiger, in addition to our general tire repair kit and miscellaneous tools. We found out that the stock Tiger tool kit is a bit, uh, incomplete: 27mm rear axle wrench, & extension bar 5mm Allen key philips/straight slot combo screwdriver & handle 10mm/12mm box end combo wrench 13mm box end wrench So, you might have enough to get some of the plastic bits off, and maybe the rear wheel. If you need to remove the front wheel, it's not happening with the stock kit. I'd also recommend getting a real tool roll. The bottom seam of my stock plastic tool bag split open at some point over the last few hundred miles. So, we are planning on adding the following to our on-bike tool kit: 17mm Allen key (Front axle) 8mm Allen (handlebar pinch bolts) 6mm Allen (fork pinch bolts and handlebar pinch bolts) 7,8,10,12,13,14mm sockets and ratchet. (A cursory check showed that some of the bolts can't be accessed with the stock combo wrench) T-30 Torx bit (Fork guard covers) T-40 Torx bit (Front brake rotor) This is for the XC model. Not sure if the 800 road model has different hardware. Plus I'm sure we missed a few things, but this should cover general maintenance items. If you guys think of anything else, please add it to the list! I also noticed that there are 4 fuse sizes: 5A, 10A, 15A, 20A. There are a couple empty slots in the fuse blocks, but no spares. I'll pick up a few spares, but I just haven't figured out what style of fuse it is. ![]() Oh, and over 1200 miles and still going strong on my bike! Feels like she has loosened up very nicely. I did have a "low" of 49mpg on one tank, but I've really stopped tracking it for the most part.
MDR2011 Ride Report AMA, BRC 2008 Street Triple, 2011 Tiger 800XC, 2007 DR650, 2007 TE250, 2001 G-G280 |
05-08-2011, 09:18 PM
#5485 | |
Thumper Pilot
Oddometer: 4,321
I'm just too damn lazy to hold a grudge. The time invested isn't worth the aggravation it takes to stay mad. |
05-08-2011, 11:32 PM
#5486 |
Poseur Extraordinaire
Oddometer: 1,093
![]() Thanks for the great review. This part will be making me laugh for days.
2007 Suzuki DL650ABS "Aw, isn't that cute, the new one smiles at you instead of the old one glowering at you" -SlowPhil |
05-09-2011, 12:47 AM
#5487 |
Oddometer: 20
I like better the looks to the F800GS, I just can't get into the lop-sided headlights. As for the 'Stroms, surplus plastic for a bike for dodgy surfaces, plus ugly in person. It's bizarre, the Stroms look really good in photos to me, blech in person.
Absolute Steel—Steel building kits easily assembled by unskilled labor using common tools. Watch the video & see for yourself. |
05-09-2011, 01:05 AM
#5488 |
Oddometer: 20
I rode the Tiger 800 street version today. Too good and too smooth! No doubt! It definitely makes the BMW feel like a tractor.
05-09-2011, 03:01 AM
#5489 |
Oddometer: 35
Well, I just got an email from the dealer where I put down a deposit back in February for a T800 ABS in Black. He's claiming that no black 800s were made in the 2011 model (I guess he means the silver frame) and that that Black 800 ABS with the graphite frame won't make it into the country until mid to late july which would be too late for me to take the trip I was planning.
I thought I saw a few pictures of a black 800 somewhere on here. Anyone know which page it was on? In addition, with this news, and the general feeling that the dealer in Cali isn't doing his job properly, I think I'm going to search around for another dealer who can hook it up. I'd be interested to hear of any good, hard working dealers in Northern California (giving up on the so-cal leg of my trip), or somewhere near North Carolina (an alternative starting point). Any other suggestions for trying to get a black 800 ABS for pickup (and honestly I'd think about flying anywhere in the US for pickup) for the beginning of July? |
05-09-2011, 04:06 AM
#5490 | |
Oddometer: 267
2013 Husky TR 650 2011 Tiger 800(sold) 2012 Super 10 2008 KLR(Sold) 1990 KLR |
