Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 06-07-2011, 07:42 AM   #6286
gkgeiger
Every ride is an ADV
gkgeiger's Avatar
Oddometer: 620
Originally Posted by Jim Williams View Post
No vibes on my XC. Smooth as glass.
I put 700 miles last weekend on mine and no problem with vibes.
Getting old is not for Sissy's!
Gene
'14 R1200GSW
'12 NC700X/D
gkgeiger is offline   Reply With Quote
Old 06-07-2011, 07:57 AM   #6287
Moore_Power
Moore_Power's Avatar
Oddometer: 44
Originally Posted by Mack McNamara View Post
Please do tell about the accesories we see in the pic ... they don't look like they're oem.
I'm refering in particular to the crashbars and the bashplate?
SW-MOTECH Accessories
'11 Triumph Tiger 800 XC
'11 BMW R1200RT
Moore_Power is offline   Reply With Quote
Old 06-07-2011, 08:23 AM   #6288
soph9
Bike Addict
soph9's Avatar
Oddometer: 2,380
I noticed no one has a kick stand extended foot print yet on their bikes...for those who have been off road..loaded with luggage and gear..any issues of the bike wanting to take a nap on that little foot print of a kick stand?
soph9 is offline   Reply With Quote
Old 06-07-2011, 08:58 AM   #6289
TAMPAJIM
Oddometer: 459
I got the Touratech foot pad extender a few weeks ago. Went on easy and is working very well. It does conflict with the center stand, you have to put the side stand down before you can use the center stand but no big deal.
I read somewhere that the Rodie has a different centerstand than the XC so maybe no problem with the XC.
__________
Jim
TAMPAJIM is offline   Reply With Quote
Old 06-07-2011, 10:39 AM   #6290
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
Tampajim, what did you use for highway pegs? If my engine guards ever show up, then I want to do the same thing.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 06-07-2011, 10:42 AM   #6291
CDTSTR
CDTSTR's Avatar
Oddometer: 9
Thumb Baffle Removal
Originally Posted by Ducken View Post
I used a metal cutting wheel on a dremel to cut the bead holding the stainless steel screw to the baffle, then unscrewed the screw. I couldn't get the baffle to slip out, and then drilled a 5/16" hole at 12 o'clock above the main exhaust exit so that I could use a cotter pin puller like a slide hammer to encourage the baffle to come out. If I ever wanted to put the baffle back in, a stainless steel button head screw could fill the hole that I drilled in the baffle. But even with the baffle out, the exhaust tone is very civil, no reason to put the baffle back in as far as I'm concerned. Ken
Thanks Ducken! I will give that a shot.
Think I'm gonna like this............
CDTSTR is offline   Reply With Quote
Old 06-07-2011, 11:22 AM   #6292
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Three test rides ... two XC's one T800. One of the smoothest bikes I've ridden. As smooth or smoother than my 1050 ... which is so smooth the BMW guys shit themselves when they ride it.
The only time I felt some vibes was when holding the XC up around 8 to 9000 rpm. But hardly an issue. At cruise speeds, no vibes that I noticed.
Old 06-07-2011, 11:24 AM   #6293
RaY YreKa
I Am the Mayor
RaY YreKa's Avatar
Oddometer: 16,265
Originally Posted by AllOrds View Post
Can I Play?
Just picked up last Friday. Loving it!
Gorgeous.
IBA #40578
shine on, you crazy emo diamond
RaY YreKa is offline   Reply With Quote
Old 06-07-2011, 12:03 PM   #6294
BAMF
B.A.M.F. -acronym
BAMF's Avatar
Oddometer: 48
Consider this your invite, there will be a lot of kawasaki Versys there but we are encouraging any adv bikers to come as well.
roll call (riders that stated they will be there)
ZerothLaw
brothercannon
thecreeper77
glowcat13 (maybe)
e moneybags
BAMF
naudan
Pretbek
Martinh (maybe)
Blipco
kswaid
Hawkshot99 (short visit)
Meetup time is 11-12 am at the below meetup point on the weekend of June 25-26
any brothers from canada wanna come join in on the fun?
Here is our EXACT meetup point: 41.312872 -74.006252
Here is the meetup point on a map: http://maps.google.com/?ie=UTF8&ll=4...,0.021136&z=16
Here is a topographical map (for elevation): http://www.nysparks.com/parks/attach...inTrailMap.pdf
Here is our route: http://maps.google.com/maps?f=d&sour...,1.783905&z=10
Here is the campsite: http://newyorkstateparks.reserveamer...ex=CampingSpot
Here is the local hotel: http://www.visitbearmountain.com/accommodations.htm
Here are some cabins down the road: http://newyorkstateparks.reserveamer...=NY&parkId=326
Here is the local bar/eatery: http://www.captains-table.com/
2011 Kawa Versys
1997 KLR 650
sure beats the shiz out of trying to start the old 82 XJ650 every morning with heat lamps and starter fluid
www.carbonmade.nealjordan.com
BAMF is offline   Reply With Quote
Old 06-07-2011, 12:59 PM   #6295
3Putt
Is that a gimmie?
3Putt's Avatar
Oddometer: 631
I put the Touratech foot on my XC, but it made contact with the center stand so I sent it back. A guy on the Tiger 800 board had the same problem, said all he had to do was grind away 5mm.
Tom
2013 RT
3Putt is offline   Reply With Quote
Old 06-07-2011, 01:14 PM   #6296
TAMPAJIM
Oddometer: 459
Pegs are black Rivco- they are the only ones I found that work because they have a angle adjustment.
The mounting clamps are a problem because the Triumph guard is only 7/8". Rivco makes this size in black but I used this one from Twisted Throttle http://www.twistedthrottle.com/trade/productview/4665
because it allowed me to fabricate 4" extensions from 1.5" bar steel (Home Depot).
I'm not concerned about a side drop as the pegs will fold up behind the engine guards but I probably would be concerned about using those homemade 4" forward extensions if I were a serious off road rider. Then the stock 1.5" Rivco clamps might be the better solution.
__________
Jim
Old 06-07-2011, 01:15 PM   #6297
Birdy68
Scared, but wants to
Birdy68's Avatar
Oddometer: 90
Originally Posted by Lion BR View Post
The VIN number tells what is your bike's model year. The 10th digit of the VIN is the international code for model year. If the 10th digit on your bike's VIN is a "B", the bike is a 2011 model. If it is a "C", it is a 2012 model year. So, for you guys with black frame bikes, is the 10th digit a B or a C?
Lion
Graphite frame and I have a 'B'
Birdy68
-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-
Leave the pork pies for now - get the sausage rolls while they're hot!
Birdy68 is offline   Reply With Quote
Old 06-07-2011, 01:26 PM   #6298
TAMPAJIM
Oddometer: 459
3Putt is that a aftermarket centerstand? Mine is a OEM Roadie, is black and doesn't look like that.
I have plenty of clearance but you do have to put the sidestand down first .
__________
Jim
Old 06-07-2011, 02:57 PM   #6299
KildareMan
KildareMan's Avatar
Oddometer: 652
Originally Posted by 3Putt View Post
I put the Touratech foot on too, but it made contact with the centerstand so I sent it back. A guy on the UK board had the same problem, said all he had to do was grind away 5mm.
That was me. Cut as required, for me about 5mm, off the corner nearest the centre stand. You still have to have the side stand out to use the centre stand, but to me that makes sense anyway.
KildareMan is offline   Reply With Quote
Old 06-07-2011, 05:32 PM   #6300
jphish
Oddometer: 617
Yeah - my Touratech "foot" for side stand sticks on centerstand. Will need to do 'hatchet job' on offending foot part. Need bigger footprint here in the soggy NW - so dont want to send back. But...ya'd think Touratech would have gotten this right in first place - I'm sure were not the only ones with "sticky foot".
jphish is offline   Reply With Quote
Times are GMT -7.   It's 06:21 PM.
