Old 07-06-2011, 04:33 AM   #7036
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,216
Originally Posted by E-town dirt dude View Post
The bike is supposed to run on premium gas but I ran down to half a tank and put in regular. I didn't notice a difference but I don't know what the long term effects of regular gas would be.
Where does it specify premium gas?
I like beer
jimjim is offline   Reply With Quote
Old 07-06-2011, 05:06 AM   #7037
The Jerk
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,334
This is incorrect, unless the specifications are different for Canadian market bikes. In the U.S., Triumph specifies the bike to run on regular (87 octane) gas.
The Jerk is offline   Reply With Quote
Old 07-06-2011, 06:23 AM   #7038
fbj913
fbj913's Avatar
Oddometer: 1,876
2nd that, read the manual!
Ride 365 LLC
Braaaap!
fbj913 is offline   Reply With Quote
Old 07-06-2011, 07:21 AM   #7039
PirateDunk
Oddometer: 31
We have lots of sand here in WA. My tiger seems to enjoy it.
PirateDunk is offline   Reply With Quote
Old 07-06-2011, 08:58 AM   #7040
bross
Where we riding to?
bross's Avatar
Oddometer: 3,568
Originally Posted by spewler View Post
I've tried it on numerous roads, in both tracks, same result. Did the same test on my Futura, not even a slight pull to the right. When I took care of a friend's BMW boxer, it did the same thing. On the XC, it's a gradual but strong pull that isn't easily countered with pressure on the opposite footpeg.
Boxers do it because that's the way the crank spins. Check your wheel alignment, could be your rear wheel is skewed and therefore sending the bike right. Use the simple string method, only takes a few minutes and once done, will stay in true as long as you turn both adjusting screws the same number of turns whenever you adjust the chain. Chain adjuster marks on the swingarm should not be trusted until you've checked them.
Motorcycle wheel alignment using string
bross is online now   Reply With Quote
Old 07-06-2011, 08:58 AM   #7041
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,414
Originally Posted by bondatomic View Post
Word to the wise: don't ride an English bike during Independence weekend... George Washington will put a screw in your rear tire (3" deck screw to be exact).
Funny you mention that. Look what I found in my tire last night after getting home from a 1500-mile trip through Quebec:
By the way, the bike now has a little over 9000 miles on it; that tire has about 7700. The front tire is the original one. Both could probably manage another 1000 miles or so, but are getting pulled off next week to be replaced with something knobbier.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 31-June 2, 2013
markbvt is offline   Reply With Quote
Old 07-06-2011, 09:01 AM   #7042
bross
Where we riding to?
bross's Avatar
Oddometer: 3,568
--mark
Feel a little wiggle or slip on right hand twisties? That's one lucky puncture, never seen one go in that flat.
Old 07-06-2011, 09:07 AM   #7043
markbvt
Oddometer: 2,414
Agreed, not sure how it managed to go in that parallel to the surface. Must have happened close to home though, because the nail wasn't very worn down yet.
--mark
Old 07-06-2011, 09:56 AM   #7044
spewler
Not (w)reckless
Oddometer: 96
bross, thanks for the tip...I'll give it a go.
spewler is offline   Reply With Quote
Old 07-06-2011, 10:02 AM   #7045
E-town dirt dude
E-town dirt dude's Avatar
Oddometer: 179
The manual specifies 91 octane gas.
E-town dirt dude is offline   Reply With Quote
Old 07-06-2011, 10:04 AM   #7046
E-town dirt dude
Oddometer: 179
Good shot! How do you find the stock tires in the sand?
Old 07-06-2011, 10:36 AM   #7047
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,496
Wow! Nice riding!
Was that sand a bit wet per chance? Hard packed?
I invite you to come down to Dumont Dunes or other dunes here in the California Mojave or Baja and have a go on the Tiger with stock Battlewings.
Down here the best time to ride sand is early AM and hope there was some dew fall the night before. Damp sand is 1000 times easier to manage than the dry, deep stuff.
I have trouble on my dirt bikes in deep sand ... can't imagine it on a 480 lbs. bike with street tires.
But slit beds are always tough.
R1200GS out of shape! Broken Femur up next.
Old 07-06-2011, 10:37 AM   #7048
The Jerk
The Jerk's Avatar
Oddometer: 2,334
Close, but your info is incomplete.
The manual specifies 91 RON octane gas. And this could simply be a difference in the two versions of the owner's manual. The RON method is not used to measure octane in the US. We use what's called the CLC method which is the average of the RON and MON numbers. So the US owner's manual specifically states that 87 octane (by the CLC method) is recommended. In the US that's the lowest grade of fuel available except for some high altitude areas out west.
91 RON is equivalent in octane to 87 CLC.
I thought that 91 RON was the lowest grade available in Canada. Is it not?
Old 07-06-2011, 10:44 AM   #7049
Evomx971
Planning Next Ride
Evomx971's Avatar
Oddometer: 230
Looks like they might be Heidy's to me...
"In the end, it's not the years in your life that count. It's the life in your years." ~ A. Lincoln
'11 Triumph 800XC ABS / '94 Honda XR650L / '06 Yamaha YZ125 / '07 Ural Gear-Up
Thanks to my 2013 Sponsors - Motorex and Leatt
What Next Wander Tour http://advrider.com/forums/showthread.php?t=853663
Evomx971 is offline   Reply With Quote
Old 07-06-2011, 12:06 PM   #7050
markbvt
Oddometer: 2,414
All the Canadian stations I've seen use the same CLC octane numbers as in the US. So 87 CLC is the lowest.
--mark
Times are GMT -7.   It's 10:00 PM.
