Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 07-09-2011, 07:00 PM   #7081
PaulSF
Oddometer: 148
Originally Posted by jimjim View Post
Kind of looks like the bleed screw that's in the upper radiator hose on some of the early models.
yup. that's what it looks like. Lives in the hose valve on the top bend in the middle of the upper hose on the left side of the engine.
PaulSF is offline   Reply With Quote
Old 07-09-2011, 07:08 PM   #7082
The Jerk
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,642
I'm guessing he would know it if that was missing.
2000 Kawasaki W650
The Jerk is online now   Reply With Quote
Old 07-09-2011, 07:11 PM   #7083
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,676
Didn't say it was missing.
jimjim is offline   Reply With Quote
Old 07-09-2011, 08:03 PM   #7084
dogmoon
dogmoon's Avatar
Oddometer: 313
Engine light
Any suggestions I was riding my new 800 Tiger today with less than 200 miles on it. I was down shifting coming to a stop when the engine died in first gear. I restarted the engine and noticed the engine light not turning off I shut the engine down and restarted and it stayed on again. I got off checked the fluids and let it set. I then took off the positive cable on the battery thinking it would reboot the computor. I then put the positive cable back on but no luck the engine light would not go off. I rode about 60 miles home with no problem. I looked at the book and it just says call your nearest local Triumph Dealer. I am open to suggestions. Thanks
Sometimes it takes a whole tank of fuel before you can think straight!
dogmoon is offline   Reply With Quote
Old 07-09-2011, 10:12 PM   #7085
dhula
Oddometer: 73
Kinda does look like it, but at the same time kinda looks too long but could be wrong. I don't have my tiger here to check
dhula is offline   Reply With Quote
Old 07-09-2011, 10:17 PM   #7086
tedesco886
Oddometer: 46
I suggest you take it to your nearest Triumph dealer.
tedesco886 is offline   Reply With Quote
Old 07-09-2011, 11:35 PM   #7087
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,774
Whilst I understand that in the USA sometimes your dealer is a long way away but the bike is still under warranty so take it to the dealer.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 07-09-2011, 11:39 PM   #7088
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,774
Originally Posted by av_mech View Post
Anybody have any idea what the hell this is? I was changing my oil and adding the bash plate (finally) and this fell on the floor. There's a chance it isn't from the bike and I didn't see anything obviously missing. It's a thumb screw with a 3MM hex in the head. Thoughts?
Photobucket
I've been over and under my bike fitting all sorts of stuff but I ain't seen anything like that anywhere.
With the knurled end it looks like it's to adjust something so if I were you, next time you visit the dealer, take it in and show them.
To me it looks a bit like a Bonnie seat bolt. That's the bolt what holds the seat on.
Old 07-10-2011, 06:48 AM   #7089
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Yep take it to the dealer. I'm not sure you can reset fault codes on these bikes by taking off the battery cable. It's best to take it in.
fbj913 is offline   Reply With Quote
Old 07-10-2011, 06:58 AM   #7090
av_mech
Risk Taker
av_mech's Avatar
Oddometer: 1,143
Im just getting to know my bike and I haven't seen anything like it. It was just weird how it fell on my leg while I was pulling the drain plug. I totally agree that it's an adjustment screw of some kind. It isnt the radiator bleed. That one is still there and not nearly as long. I've been working a ton of ot and I haven't had a chance to really investigate. Thanks Blacktiger for giving me a good feeling it isn't from the bike. There is a chance somehow that bolt ended up in my tool roll, which I pulled out of my tool tube, which is mounted almost directly above where it fell from. Hopefully anyways. I'll let you know if anything blows up.
2011 Triumph 800 XC
2007 Honda CRF 250X
1994 Kawasaki KLX 650R
THE ADVENTURES OF TYSON AND HOBBES
THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear!
av_mech is offline   Reply With Quote
Old 07-10-2011, 09:08 AM   #7091
The Jerk
The Jerk's Avatar
Oddometer: 2,642
As you found, removing the battery cable doesn't do anything to clear fault codes (and that's a good thing; otherwise troubleshooting would be very difficult).
Here's a little primer on the check engine light:
The check engine light (CEL) will come on whenever the ECU has detected some sort of fault in the engine management system. This generally happens because one of the components of the engine management system provides feedback to the ECU that was out of the expected range or perhaps has lost communication with the ECU entirely. The ECU will make a note of the issue by storing a fault code. The fault code contains information about what sensor it was and what the problem was. At the same, time, the ECU turns on the CEL so that you know a fault code has been stored. There is nothing wrong with operating the engine with the CEL lit up, it's just there to let you know that there was a problem and you should get it checked out.
The engine management system can still work fine with a sensor down; just perhaps not as efficiently as normal depending on what sensor is out of commission. In other words, you're not going to hurt anything by continuing to ride it as long as the engine is not noticeably running poorly (i.e. misfiring).
If the problem that triggered the CEL happens to go away on its own after a certain number of cycles, then the ECU will turn the CEL off. But the fault code will still be stored so next time the bike is hooked up to the diagnostic system they can see what the issue was.
You can also check fault codes yourself if you have a program like DealerTool or TuneECU (freeware). This will give you an idea of where the trouble may lie, though you should understand that a fault code about a particular component does not necessarily mean the component itself is bad. It's just a lead on where to start troubleshooting.
2000 Kawasaki W650
Old 07-10-2011, 10:47 AM   #7092
Johnny Dakar
Fuckin' Smartass
Johnny Dakar's Avatar
Oddometer: 14,054
My brain keeps barking out, "Check the seat! Check the Seat!"
"Just sharing this quiet time is intimate, our tent, our bikes and our faces illuminated by yellow light from the fire. This is why we travel. To experience those rare moments of perfection of solitude of life."
-Simon Thomas
Johnny Dakar is offline   Reply With Quote
Old 07-10-2011, 12:25 PM   #7093
av_mech
Risk Taker
av_mech's Avatar
Oddometer: 1,143
I'll check when I get home. If I can ever get out of work. These 70+ hour weeks are seriously cutting into my fun time.
2011 Triumph 800 XC
2007 Honda CRF 250X
Old 07-10-2011, 01:49 PM   #7094
ssevy
Oddometer: 900
The combination of knurled head and non-threaded blunt end really looks like an idle adjusting screw. Some General Motors screws used to hold seats, etc., also have a blunt end like that, but the knurling only makes sense for something that is going to be adjusted by the fingers.
ssevy is online now   Reply With Quote
Old 07-10-2011, 03:39 PM   #7095
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 495
Question Throttle Problem??
Has anyone else, besides me, had a problem their throttle. I notice that my throttle is what I would call twichy or abrupt--like there is very little "space" between giving the bike more gas and letting off the throttle. It is difficult to keep a steady speed as it seems like I am either "off" or "on" the throttle. Even bumps in the road cause the "touchy" throttle to give the engine more (or less) gas.
I told the dealer about the problem at the 500 mile service and they (of course) said everything was "normal".
'08 Suzuki DR650
'15 Yamaha FZ 07
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Times are GMT -7.   It's 02:16 PM.
