Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 07-11-2011, 07:39 AM   #7111
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,035
Originally Posted by fbj913 View Post
Airing down and/or different tires makes a HUGE difference!!! Ball bearing gravel roads or not...
One thing I forgot to mention on that small review: the front forks absorb the small bumps very well.
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Old 07-11-2011, 08:38 AM   #7112
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,193
Picked up my 800XC on Saturday
Saturday:
Sunday:
So far so good. Few pucker moments yesterday but she didn't go down. I really have to get some guards before I do this again.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-11-2011, 08:43 AM   #7113
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,431
I am extremely jealous
Nice looking bike, even for a scouser supporter
Originally Posted by An Appalachian mudsquid
Why do we always hurt the ones we hit?
Cos is offline   Reply With Quote
Old 07-11-2011, 08:50 AM   #7114
Mercury264
Mercury264's Avatar
Oddometer: 22,193
They don't do red so I had to get the closest colo(u)r I could
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-11-2011, 09:04 AM   #7115
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
Sunday:
And some tyres.
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 07-11-2011, 09:10 AM   #7116
Mercury264
Mercury264's Avatar
Oddometer: 22,193
Originally Posted by blacktiger View Post
And some tyres.
Yup...although they weren't that bad (not too much mud out on the trails) but def need something better. Worst thing was not being able to stand (I need risers) - that hindered me more than the tires did.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-11-2011, 09:50 AM   #7117
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 495
It appears that others have had the same "Jerky Throttle" problem as I have had.
Thanks for all the suggestions to my "Jerky Throttle" thread. I will make sure my bike has tune 20495 and have the freeplay taken out by a dealer different from the one that told me it was "normal".
'08 Suzuki DR650
'15 Yamaha FZ 07
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Old 07-11-2011, 10:17 AM   #7118
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
Did you roll the bars forward? It moves them up a lot, but it also puts them slightly further away. I'm happy with the 20mm risers.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 07-11-2011, 10:23 AM   #7119
Mercury264
Mercury264's Avatar
Oddometer: 22,193
What I actually need is to raise and also bring them back towards me a little - I will get some Rox risers to do that.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-11-2011, 11:01 AM   #7120
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
Originally Posted by Lion BR View Post
On corrugations such as in minutes 0:39 and 2:05 and 2:35 and 3:06 you can hear how it makes a lot of noise, coming from the front and the back of the bike. Not much traction on acceleration either (most bikes won't have any traction at all either). I need to check the adjustments for the rear shock.
Good video.
Having had a close look at the chain to swing arm clearance, there isn't much. So I'm fairly convinced all this clattering is the chain slapping on the swing arm protectors. I wonder if there's someone out there that can rig up a video camera pointing at that area?
Old 07-11-2011, 11:35 AM   #7121
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
Airing down tires on a bike this heavy can mean bent rims. And it is such a hassle. I'm mostly a dirt rider and I've ridden bikes with all sorts of tire wear, I know thread makes a difference. But not as much as people tend to believe. Thanks for your comments.
ok
airing down on this bike means you have more control on offroad situations. i would much rather have control than worry about a bent rim. i can ride home with a bent rim. a broken arm may be a little tricky! you dont air down to 12 or 13 like a Dirt Bike, the manual recommends 22psi i think...
fbj913 is offline   Reply With Quote
Old 07-11-2011, 11:42 AM   #7122
Mercury264
Mercury264's Avatar
Oddometer: 22,193
ok
Do you think at that pressure rim locks are required ? Anybody planning on adding rim locks
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-11-2011, 12:19 PM   #7123
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
No. As I understand it the tyres are a very tight fit on the rims. Almost like a tubeless fit. So I don't think rim locks are needed. Also, if they were needed, Triumph would recommend them with the Karoos that are the option tyre. That could also be why the pressure they recommend is 22psi not a dirt bike 12psi.
Old 07-11-2011, 01:38 PM   #7124
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
ok
I 100% agree with this approach. It remains to be seen how tough the Tiger rims will be. Generally speaking, Excel rims of the spec used on the Tiger are pretty strong, can take a good hit. I'd guess running 20 to 22 PSI will not put them at much risk unless you are riding at race pace in nasty rocks.
But as Lion says; low pressures can result in a dented rim. But for me control is everything ... and is literally a life saver. Having owned two Vstroms and ridden several GS's off road, I know the substantial improvement in feel and control that is gained from running lower pressures in front and rear tires.
Yes .... it's a bit of a hassle. But if you don't go too low for off road, then once back on pavement the bike will mostly still work OK
I've gone with lower pressures on street tires (like the Battle Wings) and braking ability and corner confidence was greatly improved. Even better with tires like TKC80's, D606 or T-63's.
Baja is famous for ruining rims ... and I've dented a few there. But I run lower than average pressures on dirt bikes. In Baja ... or other rocky, fast terrain, you do need to increase pressure a bit. But most important, you need to slow down, pay attention and watch for embedded baby heads and square edged holes.
I have no doubt by the end of Summer we should know more about the durability of the Tiger's rims.
A plug in elec. mini compressor makes airing up less a pain ... but pretty slow. Once you've seen a good trials rider do their routine ... you'll understand the value of low pressure tires (Trials riders run about 8 psi). Same principles apply to bigger bikes.
Old 07-11-2011, 01:46 PM   #7125
DabsAlot
DabsAlot's Avatar
Oddometer: 301
I never run that high of air pressure in sections!
2009 BMW F800GS
2008 KTM 250 XCW
2008 Yamaha WR250R
2005 Gas Gas 280 Pro
1975 Yamaha TY-175
DabsAlot is offline   Reply With Quote
Times are GMT -7.   It's 12:17 PM.
