Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 07-12-2011, 08:58 AM   #7156
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,198
Originally Posted by Mercury264 View Post
I do like the look of those guards. I've never bought bars like this before, does H&B have a good rep do you know ?
Thanks to a truck trying to kill me, I bounced mine off a Toyota and they held up really well on my BMW. Very beefy bars and well coated. I'd buy HB stuff again in a heartbeat.
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 07-12-2011, 10:34 AM   #7157
Evomx971
Defrosting in NM
Evomx971's Avatar
Oddometer: 276
Originally Posted by blacktiger View Post
Well, that puts that one to bed.
I still think it's the chain slapping the plastic swingarm guards but it'll be difficult to prove since we can't ride without a chain.
I now agree that it's chain slap. I've been one of the chronic complainers of clacking when riding off road. I have the Triumph centerstand, it fits and works great. I do have a small strap that I tie it up with for piece of mind but I don't think it's actually causing any noise. I spent a bunch of time riding up and down the lane to my house with no helmet and leaned over the bike. I could ride with my hand on the centerstand and sidestand and confirmed that they are not the noise-makers. While leaned over, it does look like it's the chain. Just flicking the chain in the shop you can hear that it would clack pretty loud against the slider. Triumph has a pretty complex looking multi-piece chain slider on there that I would have guessed was designed to quiet the chain noise... doesn't seem like it works to me.
"In the end, it's not the years in your life that count. It's the life in your years." ~ A. Lincoln
'11 Triumph 800XC ABS / '94 Honda XR650L / '06 Yamaha YZ125
Thanks to my 2015 Sponsor: Motorex
What Next Wander Tour http://advrider.com/forums/showthread.php?t=853663
Evomx971 is offline   Reply With Quote
Old 07-12-2011, 10:48 AM   #7158
Evomx971
Defrosting in NM
Evomx971's Avatar
Oddometer: 276
ECU tunes and stalling
I'm watching all the post on the stalling issues closely, that's really too bad that it does seem to be growing into more than just a very random problem and there isn't a clear cause or cure. Also interesting that none of the mag or 'net tests ever mentioned getting a bike exhibiting any of the issues.
My '11 800XC-ABS has ran well from day one luckily. At around 800 miles I put on the Arrow pipe and had that map installed.
FWIW, I did have the bike die unexplainably very early on, migh have had 100 miles on it. Pulled clutch in for a stop and it just died. That's only happened once. I've also had it stall maybe twice when doing a U-turn or something while slipping the clutch and "blipping" the throttle a little, like you would a two stroke... it doesn't seem to like that much. Like others have said, to me the idle is a bit on the rough side compared to the overall smoothness of the engine.
Regarding throttle response. When the bike had the stock pipe and original map, I agree, it was borderline twitchy. For me, the Arrow pipe and map really softened the response. I was actually a little put off by the softness of the response down low with the Arrow pipe/map and strongly considered going back to stock... however, after riding the bike off road with the pipe and map, it really worked well, so planning to leave it, at least for now.
Old 07-12-2011, 10:53 AM   #7159
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,080
I hope they are good, as I have a set on order for my bike.
I havent heard anything bad about H&B and usually, anything from Germany has to pass a lot of TUV (approval) tests and is generally pretty good.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 07-12-2011, 11:52 AM   #7160
itsatdm
itsatdm's Avatar
Oddometer: 4,873
Another source of clacking (It was a big deal in Parallel universe) are the brake rotors. They are two piece with rivets holding the outer to the inners. They are designed to flex, but some can be noisy until the rivets get filled with dirt and grime. To test the theory some inmates even zipped tied the rotors at the connecting point and their noise went away.
Just shows how anal we can be
Old 07-12-2011, 01:57 PM   #7161
3Putt
Is that a gimmie?
3Putt's Avatar
Oddometer: 637
Is this what I'm feeling? I discover this when I forgot to use any rear brake. When I'm rolling to a stop, say 5 or 10mph and I apply enough brake for the nose to dive, I hear a clank and feel a moderate thump on the bars.
Tom
2013 RT
3Putt is offline   Reply With Quote
Old 07-12-2011, 02:31 PM   #7162
Evomx971
Defrosting in NM
Evomx971's Avatar
Oddometer: 276
I don't think that's what that is... other's have complained of a similar symptom and a few have made head bearing adjustments to fix. Early on, mine did it but hasn't lately. I've checked the head bearings once I got the centerstand put on it and they feel fine doing the fork shake test. One inmate noted that to fix his, they had to put a washer under the nut on top of the top triple clamp (it currently does not have one there).
Old 07-12-2011, 05:02 PM   #7163
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 495
Mine does this as well.
'08 Suzuki DR650
'15 Yamaha FZ 07
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Old 07-12-2011, 05:24 PM   #7164
E-town dirt dude
E-town dirt dude's Avatar
Oddometer: 205
Originally Posted by Lion BR View Post
Please keep us posted.
Lion
Picked up the bike today. Dealer said they adjusted the throttle bodies and fixed it. Riding the bike I'm now finding that there is an occasional hesitation off idle and the fuel economy has dropped. Before the service I was getting a fuel economy reading of 3.8 to 4 liters per hundred kilometers at a steady 100 km/h. That has now increased to about 4.5 liters per 100 km/h. I'll ask them to adjust it again when I take it in to get the heated grips installed.
I wish they had just friggin left it alone. It ran better and got better gas mileage before the first "Mandatory" service.
All it takes for evil to triumph is for good men to do nothing
E-town dirt dude is offline   Reply With Quote
Old 07-12-2011, 06:52 PM   #7165
Dmarino
Dmarino's Avatar
Oddometer: 203
Same issue for 6900 miles here. Today I had the dealer adjust the headstock and it's fixed :)! The dads bike is doing the same thing as well. I suspected the rotors as well but it was not it.
Edit: I could not feel any play with the forks in the air before the adjustment.
11' Triumph Tiger 800 ABS | 04' DRZ400E
Dmarino is offline   Reply With Quote
Old 07-12-2011, 07:47 PM   #7166
abruzzi
abruzzi's Avatar
Oddometer: 985
Is there a way to search just THIS thread ? Lots of good info in here but boy it's long...
Go to google or bing, and use the following search query:
site:advrider.com 599070 search terms
It's less than perfect, but 599070 is the thread number, site:advrider.com limits results to this board, and replace "search terms" with what you want to search for. Here is an example:
http://tinyurl.com/6gyp3mw
Geof
http://tigertriple.com/
abruzzi is offline   Reply With Quote
Old 07-12-2011, 10:14 PM   #7167
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,024
Does anyone make a replacement shock for the non-XC yet? The stock one has way, way too much rebound damping and no adjustments. I can push down on the rear and it takes 15 seconds for it to come back up!
Has anyone worked on the forks yet? The shock is so bad that you can't tell what the forks are doing.
"Son, you can't do both"
Old 07-13-2011, 02:20 AM   #7168
dhula
Oddometer: 73
I have had the forks of my roadie apart a few times (almost 10 I reckon) trying to sort out a bouncing issue that the dealer now tells me is caused by "the little waves in the road".
Swapping oils (I've tried 5, 7.5, 10[stock] and 15w) and springs (i've had stock and 0.95kg.mm in there) does bring about some changes and IMO the 5w oil in the front is a pretty good compromise. I've not pulled the cart out of the front but suspect it will be standard showa kinda stuff.
Maybe there is something in a swap of rear shock or at least a valving/oil viscosity change in the bum
dhula is offline   Reply With Quote
Old 07-13-2011, 07:51 AM   #7169
jphish
Oddometer: 617
For rear shock, check with Jay @ www.sasquatchrider.com 208-9682112. Have one soon for XC - not sure about non XC model. j
jphish is offline   Reply With Quote
Old 07-13-2011, 08:30 AM   #7170
Deano955
Insatiable
Deano955's Avatar
Oddometer: 4,017
Originally Posted by E-town dirt dude View Post
I took my bike in today for the first service. It had a minor rough idling issue but nothing major. They loaded the new map and right away it would stall ...to the point that it can't be ridden. Very frustrating...I showed up ready to ride it away and they said...yeh..it won't run...but we will contact Triumph tomorrow to see if they know of a way to fix it. The service guy said that this is the fourth XC he's seen with the same issue.
Mine has the same issue as well. It's been in the shop for 8 days now. Still not fixed. Last I heard, they had the throttle bodies off looking for air leaks. None were found. The shop is "waiting on Triumph"...
Sorry to hear others are having the same problems. Not good!
Save $5 off your smugmug account with this coupon( 1qoLJk8tfsGWM )
COHVCO, AMA, ETC...
Deano955 is offline   Reply With Quote
Times are GMT -7.   It's 08:10 PM.
