07-12-2011, 05:24 PM
#7201 |
Oddometer: 179
Picked up the bike today. Dealer said they adjusted the throttle bodies and fixed it. Riding the bike I'm now finding that there is an occasional hesitation off idle and the fuel economy has dropped. Before the service I was getting a fuel economy reading of 3.8 to 4 liters per hundred kilometers at a steady 100 km/h. That has now increased to about 4.5 liters per 100 km/h. I'll ask them to adjust it again when I take it in to get the heated grips installed.
I wish they had just friggin left it alone. It ran better and got better gas mileage before the first "Mandatory" service.
All it takes for evil to triumph is for good men to do nothing |
07-12-2011, 06:52 PM
#7202 | |
Edit: I could not feel any play with the forks in the air before the adjustment.
________________________________________________ 11' Triumph Tiger 800 ABS | 04' DRZ400E |
07-12-2011, 07:47 PM
#7203 | |
Oddometer: 637
site:advrider.com 599070 search terms It's less than perfect, but 599070 is the thread number, site:advrider.com limits results to this board, and replace "search terms" with what you want to search for. Here is an example: http://tinyurl.com/6gyp3mw Geof |
07-12-2011, 10:14 PM
#7204 |
Zoob
Oddometer: 1,019
Does anyone make a replacement shock for the non-XC yet? The stock one has way, way too much rebound damping and no adjustments. I can push down on the rear and it takes 15 seconds for it to come back up!
Has anyone worked on the forks yet? The shock is so bad that you can't tell what the forks are doing.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
07-13-2011, 02:20 AM
#7205 |
Oddometer: 73
I have had the forks of my roadie apart a few times (almost 10 I reckon) trying to sort out a bouncing issue that the dealer now tells me is caused by "the little waves in the road".
Swapping oils (I've tried 5, 7.5, 10[stock] and 15w) and springs (i've had stock and 0.95kg.mm in there) does bring about some changes and IMO the 5w oil in the front is a pretty good compromise. I've not pulled the cart out of the front but suspect it will be standard showa kinda stuff. Maybe there is something in a swap of rear shock or at least a valving/oil viscosity change in the bum |
07-13-2011, 07:51 AM
#7206 |
Oddometer: 596
For rear shock, check with Jay @ www.sasquatchrider.com 208-9682112. Have one soon for XC - not sure about non XC model. j
07-13-2011, 08:30 AM
#7207 | |
Insatiable
Oddometer: 3,685
Sorry to hear others are having the same problems. Not good!
Triumph Tiger XC --- KTM 525 EXC --- Honda XX AMA Defender COHVCO Member Save $5 off your smugmug account with this coupon( 1qoLJk8tfsGWM ) |
07-13-2011, 10:24 AM
#7208 | |
Scared, but wants to
Oddometer: 90
Birdy68 -x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x- Leave the pork pies for now - get the sausage rolls while they're hot! |
07-13-2011, 10:44 AM
#7209 |
Oddometer: 512
I'm so clever sometimes I don't understand a single word of what I'm saying |
07-13-2011, 05:26 PM
#7210 |
After a two month wait my guard came in. Almost looks out of place on the dirty bike.
07-13-2011, 08:26 PM
#7211 | |
Oddometer: 862
Russ |
07-14-2011, 06:23 AM
#7212 |
Every ride is an ADV
Oddometer: 501
Has anyone installed a Fenda Extrenda without the screws that were furnished. If so is the tape holding it OK?
"If more is better, then two much must be just right" Gene '12 T100 110th Anniversary '12 NC700X/D |
07-14-2011, 06:35 AM
#7213 |
Homebrew Guru
Oddometer: 1,469
When I put put mine on my V-Strom, I didn't use the screws. I scuffed the heck out of the fender and the Extenda where they meet. Then I applied a heavy duty adhesive/sealer that I got at work and clamped them together. Several years later it was still holding strong.
sparkyairracing.com |
07-14-2011, 07:15 AM
#7214 | |
Once you go Triple...
Oddometer: 20,486
I use Google all the time to search the site but I could never figure out how to search just a single thread - I used the entire URL and that didn't work so I'm glad there is a way....
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
07-14-2011, 07:18 AM
#7215 | |
Oddometer: 20,486
![]() Thanks
