Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 08-02-2011, 06:00 PM   #7621
TAMPAJIM
Oddometer: 495
You may have a point. That vent is very low.
It's my understanding that vent serves as a air intake to equalize negative pressure in the fuel tank caused by the fuel pump. If water temporarily blocked it, maybe a sensor that controls the system sent an error message to the computer..
Does seem a bad place to mount a canister on a dual purpose bike. The BMW one is up around the cylinder heads.
You could test it by starting the bike then blocking off the vent
Disclaimer: I'm just speculating, I really don't know much about this technical stuff..
__________
Jim
TAMPAJIM screwed with this post 08-02-2011 at 06:13 PM
TAMPAJIM is offline   Reply With Quote
Old 08-02-2011, 06:07 PM   #7622
G-Funk
That ... Umm ..... "Dude"
G-Funk's Avatar
Oddometer: 5,259
Me, I would reroute that hose intake up ......... and I'm noting this as well, for when I do buy one .....
And my dislclaimer: I too, know really nothing about this stuff .....
G.
03 Caponord
"The Funness out-weighs the Dumbness ....." - Mr. Jetmoto
G-Funk is offline   Reply With Quote
Old 08-02-2011, 06:16 PM   #7623
Deano955
Insatiable
Deano955's Avatar
Oddometer: 4,054
G.
G-
I know the same. I'm thinking that right angle hose is an overflow. Meant to drain the canister when/ if it fills up w/ whatever it fills up with. I hope Triumph figures out all this stalling, idling, poor running bullshit by the time you are ready to buy one. If not, don't buy one yet.
I'm totally frustrated with my bike. Want a replacement or refund and told the Customer Relations Manager at Triumph so. He's not responded since...
I'm gonna try the test- blocking it off while running- in a bit....
Save $5 off your smugmug account with this coupon( 1qoLJk8tfsGWM )
COHVCO, AMA, ETC...
Deano955 is offline   Reply With Quote
Old 08-02-2011, 06:22 PM   #7624
cug
Oddometer: 5,031
Use a T piece to route another hose high up because that thing might also be an overflow ...
R1200R/RS LC Forum
cug is online now   Reply With Quote
Old 08-02-2011, 07:02 PM   #7625
ButtonPushingMonkey
Oddometer: 44
A simple check valve would prevent backflow, but since the majority of the people having the issue are having it without fording a river I would say you are chasing ghosts if you focus on the canister. This at least is easy to test. Stick the tube in a cup of water while it is running to see if it sucks it in
ButtonPushingMonkey is offline   Reply With Quote
Old 08-02-2011, 08:44 PM   #7626
Xcountry-Rider
Oddometer: 912
Brilliant!!
Xcountry-Rider is offline   Reply With Quote
Old 08-03-2011, 04:16 AM   #7627
woodys3b
Oddometer: 150
Stalling in closed loop
If the Tiger is indeed in closed loop mode at idle, I would try to disconnect the O2 sensor and see if that makes a difference.
This should force the bike to operate in open loop mode all the time which is no big deal.
When engine breaking on the Tiger, there is a lot of noise coming from the cat. This is unburned fuel igniting as it hits the very hot cat. Maybe the computer is reacting to all that excess fuel in the exhaust and leaning the bike out causing it to stall. It starts again when the throttle is opened a tad because the ECU sees that the throttle is no longer in the idle position and moves to a section of the map that is open loop.
Just a thought.
woodys3b is offline   Reply With Quote
Old 08-03-2011, 07:21 AM   #7628
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 499
Question
I wonder what effect a Power Commander (or Power Commander like device) would have on the stalling issue??
According to the Power Commander site they are in the process of developing one for the 800.
http://www.powercommander.com
'08 Suzuki DR650
'15 Yamaha FZ 07
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Old 08-03-2011, 07:36 AM   #7629
Roadscum
Oddometer: 2,507
You shouldn't have to buy a solution. Triumph will soon solve the problem and all will be well in tiger land.
Regards, Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Roadscum is offline   Reply With Quote
Old 08-03-2011, 08:17 AM   #7630
ButtonPushingMonkey
Oddometer: 44
tiger 875cc turbo diesel twin
Bring the twin back, with a twist...am I the only one who thinks the tiger would be heaven with the new fiat tdi 875cc twin?
Old 08-03-2011, 08:42 AM   #7631
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,335
Yes
I'll stick with my triple thanks...
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 08-03-2011, 08:43 AM   #7632
cug
Oddometer: 5,031
Yes.
R1200R/RS LC Forum
Old 08-03-2011, 09:09 AM   #7633
TAMPAJIM
Oddometer: 495
Yes
__________
Jim
Old 08-03-2011, 09:38 AM   #7634
TAMPAJIM
Oddometer: 495
The charcoal canister is a possible culprit for stalling from stream crossings but not for the majority of the T800 stalling cases reported.. In the BMW case, it was sucking in enough water to somehow shut the engine down but I don't think it was filling the canister. You could shut the motor off, let the water drain out of the hose and it would restart but sometimes run a little ragged. Never happened to me because I re-routed the vent hose away from the rear tire and didn't cross streams, but I did see it happen to others while riding in the rain at highway speeds..
The tube-in-the-water test sounds good, but work the throttle as if riding
__________
Jim
Old 08-03-2011, 09:40 AM   #7635
TAMPAJIM
Oddometer: 495
I agree.
__________
Jim
Times are GMT -7.   It's 03:18 PM.
