Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 09-14-2011, 12:23 AM   #8431
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,102
Now you have it apart, just paint over the fuel icon with black paint.
Should turn it into a dull yellow glow.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 09-14-2011, 01:01 AM   #8432
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,895
Or a neat circle of paint on the inside of the glass/plastic cover.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 09-14-2011, 04:35 AM   #8433
motonut
Old Guy
Oddometer: 62
an option for you to try...
Originally Posted by av_mech View Post
Yes, the lights bother me. They are, in my opinion, too bright. I notice that they actually affect my night vision. I was only seeking a solution to make something a little better. I really enjoy modifying my bikes so they are set up exactly the way I want. I like wrenching and coming up with fixes for issues big and small.
I looked at the wiring diagrams as well. There's not really a clear definition of what the inputs are to the gauge cluster other than to trace out the circuit. I'd clip a wire if I knew which one to clip. However, the low fuel light would be a function of the fuel level input. The processor in the gauge cluster would take that info and use it for the level display, miles to empty, and light. I obviously don't want to lose all that. Just the light, which I don't think is easily possible.
I reckon I could disable the high beam by clipping the wire that goes into pin 13 on the cluster connector. I may just try that. I can always splice it back together if things go horribly awry.
Av_Mech,
I can recommend applying (not tape) but an appropriately sized 'disc' of window tint film. The film is available in multiple strengths... think dark, darker, really dark and dang near black. I have done this with a number of offensive indicator lights, mostly coffeemakers and the like. You can still see the lamp illuminated but at a brilliance of your choosing.
Two downsides, maybe, depending on your talents and budget: One is the cost; hate to spend fifteen bucks to make a 3/8" circular overlay. Two is the actual mechanics of making the little bugger. Not that diffucult, but finesse is in order.
Think about it.
Motonut
motonut is offline   Reply With Quote
Old 09-14-2011, 04:37 AM   #8434
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,767
Or window tint film inside the lens over the tach face.
jimjim is offline   Reply With Quote
Old 09-14-2011, 04:57 AM   #8435
KildareMan
KildareMan's Avatar
Oddometer: 692
Has anybody cracked into the gauge cluster yet? I'd like to disable the idiot gas light cause I'm not an idiot and I can read the gas gauge and trip meter. That thing is bright and annoying at night. I just took a quick peek at it and I didn't see how it comes apart. Removing it from the bike doesn't look hard, but getting to the guts may be a different story.
ECU to instruments is CANBUS. Good luck
KildareMan is offline   Reply With Quote
Old 09-14-2011, 06:21 AM   #8436
av_mech
Risk Taker
av_mech's Avatar
Oddometer: 1,144
I wasn't going to mess with any of the ecu inputs. And if I was going to cut the headlight wire it appears to be a single discrete input into the cluster. The circuit card would only be looking for voltage or no voltage to turn the bright indicator on. The fuel light is much more difficult to solve electronically.
But, these other guys have offered some great possible solutions that don't involve electronic changes. Im interested to hear others. I'll be investigating them on Friday night. Tonight is date night.
2011 Triumph 800 XC
2007 Honda CRF 250X
1994 Kawasaki KLX 650R
THE ADVENTURES OF TYSON AND HOBBES
THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear!
av_mech is offline   Reply With Quote
Old 09-14-2011, 07:00 AM   #8437
Daytonacharlie
2 Wheeled Backpacker
Daytonacharlie's Avatar
Oddometer: 233
Yeah but.... tape on a 12,000 dollar motorcycle? Not mine.
This is the inside. I had one of the back too but photobucket has been giving me fits the past 24 hours.
I could see where a carefully painted circle of black paint on, if accessible, the inside face of the panel above where the LED illuminates. If that wasn't enough then both sides, keeping inside the lines of course
I see you live in Boise. Was up that way a few years back... fell in love with Moose Drool on tap! Have one for me mate!
1996 Triumph Daytona 1200
Daytonacharlie is offline   Reply With Quote
Old 09-14-2011, 08:57 AM   #8438
L.B.S.
Oddometer: 1,469
Still a paint, but a translucent type of tinting paint.
-Tamiya TS-71 Smoke (there are other part Tamiya part #'s for different materials/characteristics ie: TS-19 and TS-31 Smoke etc., polycarbonate/plastic/whatever. Best to ask a model shop or someone who knows about this stuff)
-VHT "Nightshade" Usually found in larger auto part stores for tinting plastic tail lights on cars. Don't know if it's still made or available any more.
I used the Tamiya to tint my Honda CBR windscreen and front running light lens. Worked well. The more you spray, the darker it goes. Light coat, light tint.
HTH
L.B.S. is offline   Reply With Quote
Old 09-14-2011, 08:58 AM   #8439
bross
Where we riding to?
bross's Avatar
Oddometer: 4,700
Why not just a tiny dab of dark colored maybe black silicone on top of the LEDs? I must admit I have the same beef with several LEDs in our house. The damn tv and coffee maker LEDs could function well as aircraft landing lights! If I don't cover the coffee maker led it shines right in my eyes when trying to sleep, and that's 50 fricking feet away! The led on the tv I fixed with a small bit of electrical tape which you can't see, so sometimes the cheap way does work.
Have you looked at TuneECU? Maybe there's a setting you can tweak? I'd check but we're on road.
bross screwed with this post 09-14-2011 at 09:10 AM
Old 09-14-2011, 09:30 AM   #8440
booth99
Oddometer: 13
New here. Picked up my 2012 XC ABS on Sept 2nd. Loving it!!
booth99 is offline   Reply With Quote
Old 09-14-2011, 09:39 AM   #8441
ElNorto
Oddometer: 39
Originally Posted by motonut View Post
Av_Mech,
Think about it.
Motonut
Go to a hobby shop and pick up a piece of appropriately sized brass tube. Sharpen the end to make a circle cutter and start cutting disks.I use a counter sink to sharpen the inside edge of the tube but you could use a file on the outside edge. I'd think any dark colored plastic adhesive backed film would work.
ElNorto is offline   Reply With Quote
Old 09-14-2011, 10:35 AM   #8442
fbj913
I ride
fbj913's Avatar
Oddometer: 2,396
Missouri? Engles had the same color on the show room when I was in there not to long ago. I see maybe a hint of what could be a Missouri plate on your Jetta. If so hit me up and lets ride!!!
fbj913 is offline   Reply With Quote
Old 09-14-2011, 12:01 PM   #8443
booth99
Oddometer: 13
Spokane, WA
Old 09-14-2011, 12:50 PM   #8444
fbj913
I ride
fbj913's Avatar
Oddometer: 2,396
Spokane, WA
Damn the Luck. Well if your ever down this way call me anyway . Nice bike BTW. I wish they had that color when I bought mine!
Old 09-14-2011, 05:02 PM   #8445
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 498
I wish orange would have been offered on the road version.
'08 Suzuki DR650
'15 Yamaha FZ 07
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Times are GMT -7.   It's 05:44 AM.
