Old 10-26-2011, 10:49 AM   #9211
jphish
Oddometer: 596
Actually...I'm wrong on that. 99's were 885's but FI - not carbs. OOPs
jphish is offline   Reply With Quote
Old 10-26-2011, 11:11 AM   #9212
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,381
Originally Posted by jphish View Post
Yeah - "Steamers" 885's, 92 - 98. "Girlies" 955 FI, (tho 99 models were 885's & carbed) 99 - 06. "Roadies 1050's, 07 - current. But doubt this tiger will see another year with the 800 & 1200's out. Just an uneducated / fact free guess. For additional info - see 'tigertriple.com' It's a dedicated tigger site. PS: 800's are refered to as"Beakers" on that site - just fyi
All good stuff!
The Steamers didn't come to the USA until 1995. I had a '95 Steamer.
Also had a '99 Girlie ... yes, it was an 885 but much different motor than original Steamer 885 motor ... and it was F.I. Not Carbs!.
Mine ran flawlessly. The 885 F.I. version was derived from the Speed Triple and it was only in production two years ... 1999 and 2000. For 2001 Triumph brought out the 955i.
I agree ... the 1050 Tiger is finished. This will hurt the resale of my current 1050 which I may sell to finance a new 800 XC. Motorcycle Merry-Go-Round!
Old 10-26-2011, 11:50 AM   #9213
ThomasVolomitz
Not so Gnarly
ThomasVolomitz's Avatar
Oddometer: 3,977
need knobbies
lowside mudslide
Doo Done
ThomasVolomitz is online now   Reply With Quote
Old 10-26-2011, 11:56 AM   #9214
CA Stu
CA Stu's Avatar
Oddometer: 42,614
There's no law against having two Tigers, you know....
CA Stu is offline   Reply With Quote
Old 10-26-2011, 12:18 PM   #9215
ZZ4Blazer
Oddometer: 94
Not in cali...but sure to be illegal in ohio soon enough....
"homesick for a place Ive never been"
'13 Triumph Tiger Explorer 1200
08 Yamaha WR450F - woods/adventure monster in the making
ZZ4Blazer is offline   Reply With Quote
Old 10-26-2011, 12:36 PM   #9216
fbj913
fbj913's Avatar
Oddometer: 1,842
ABS Switch
Im not sure how well this would work and I know it was mentioned a while back... can someone figure out how to run a by pass switch to the abs fuse, or circuit, or what ever the hell its called. I did a ton of off road riding this last weekend and it was a pain in the ass to turn that thing off all the time. It sure would be nice just to have a switch to flick on the move!!! Im not worried about turning it back on on the move just off... Who wants to be the test rat?
Ride 365 LLC
Braaaap!
fbj913 is offline   Reply With Quote
Old 10-26-2011, 12:49 PM   #9217
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 8,133
Send a message via ICQ to Yossarian™ Send a message via MSN to Yossarian™ Send a message via Yahoo to Yossarian™ Send a message via Skype™ to Yossarian™
It should be simple enough to replace the ABS fuse with a set of leads that circuit to a fuse and switch that can be placed in a convenient location. Can't promise I will get to it soon but probably will tinker with it in the off months of winter.
Old 10-26-2011, 01:21 PM   #9218
fbj913
fbj913's Avatar
Oddometer: 1,842
SAWEEET!
Ride 365 LLC
Braaaap!
Old 10-26-2011, 02:18 PM   #9219
fbj913
fbj913's Avatar
Oddometer: 1,842
Stock Handlebar Dimensions
Does anyone know the stock handlebar dimensions?
Ride 365 LLC
Braaaap!
Old 10-26-2011, 03:03 PM   #9220
ThomasVolomitz
Not so Gnarly
Oddometer: 3,977
When I lowsided in the mud today a couple things happened. Firstly, my ego was severely bruised. My shift lever was bent and difficult to shift. The kickstand switch that controls the starting had mud and the bike wouldn't run when I kicked it into gear. I cleaned mud out and it still wouldn't run, so I took a rock and tapped on it, then it was OK. Also the ABS was off after the drop for about 10 miles, then it came back on. Just thought I'd share.
Next time we hit the dirt I will take one of the DR's. The Tiger, with the stock tires is great on gravel and fire roads, but mud is a different story. I need knobbies and crash bars before trying it again.
Doo Done
Old 10-26-2011, 03:06 PM   #9221
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,255
Just FYI, if you kill the bike with the kill switch (instead of the key), then ABS stays off.
I've been learning to leave my XC running instead of turning it off all the time. If I did that with my 450EXC, then it would boil over.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 10-26-2011, 03:31 PM   #9222
jphish
Oddometer: 596
Good point on kill switch / ABS. I just found that somewhere (Canadian video on GS / XC comparison?) in the last week. Also - Touratech makes a sidestand guard - not sure it keeps mud out - but does protect from rock damage.
Old 10-26-2011, 03:51 PM   #9223
halfast3
Oddometer: 24
Jim Davis at Eastern Beaver in Japan has a loom for V-Stroms which does just that. I had one on my Wee.
http://easternbeaver.com/Main/Bike_S...tml#absadaptor
halfast3 is offline   Reply With Quote
Old 10-26-2011, 04:11 PM   #9224
levain
STILL Jim Williams
levain's Avatar
Oddometer: 5,953
That's one smart dude. I bet if we bug him enough, he'd do it for the XC. I bought his heated grip thingamabob. Couldn't ask for a better made solution to switched aftermarket heated grips.
Click Here!
2012 Triumph Tiger 800 XC
1971 Lambretta DL
levain is offline   Reply With Quote
Old 10-27-2011, 03:32 AM   #9225
KildareMan
KildareMan's Avatar
Oddometer: 505
I've removed my side stand switch from it's original position. It's still in circuit, although not used, and safely out of the way, ziptied up near the top end of the gear linkage rod.
KildareMan is offline   Reply With Quote
Times are GMT -7.   It's 05:54 AM.
