Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 11-11-2011, 07:40 AM   #9436
fbj913
I ride
fbj913's Avatar
Oddometer: 2,354
Originally Posted by Mercury264 View Post
No need, my GPS is mounted in exactly the same position using a RAM mount.
Ok, no need for you. What if someone wants more options?
fbj913 is offline   Reply With Quote
Old 11-11-2011, 08:03 AM   #9437
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,076
I just put it out there so people know there are other options besides waiting for something like this.
If you want more options, fill yer boots....
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 11-11-2011, 08:35 AM   #9438
fbj913
I ride
fbj913's Avatar
Oddometer: 2,354
Did you post pictures of your ram mount a while back? If so do you remember what page? If not can you? (arent these huge threads lovely. You can find shit.
Old 11-11-2011, 09:43 AM   #9439
Mercury264
Mercury264's Avatar
Oddometer: 22,076
You can search within a thread but as you say, still not easy.
I did post some pics but maybe this one best shows what I did:
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 11-12-2011, 03:42 PM   #9440
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,653
Oil Leak
I have a minor oil leak and luckily it seems to be coming from this plug instead of a gasket.
The service manual defines these as crankcase seal plugs and to replace with new ones if removed. On my next oil change which is coming up shortly I'm going to remove it and put some sealer on it like Permatex and reinstall. Has anyone else noticed an oil leak here?
jimjim is offline   Reply With Quote
Old 11-12-2011, 04:04 PM   #9441
motonut
Old Guy
Oddometer: 62
about that leak
QUOTE=jimjim;17290377]I have a minor oil leak and luckily it seems to be coming from this plug instead of a gasket.
On my next oil change which is coming up shortly I'm going to remove it and put some sealer on it like Permatex and reinstall. Has anyone else noticed an oil leak here?[/QUOTE]
JimJim
Surely you are still in warranty? I wouldn't screw with it for two reasons... one is you are in the warranty period(I'm assuming)... two is that the plug may not be threaded. It does have a recessed-allen head but might it be pressed in?
If you somehow are beyond warranty why not order another plug and then see what you are up against?
The reality is that I'd likely have the same reaction as you if it was happening to mine!
Motonut
motonut is offline   Reply With Quote
Old 11-12-2011, 04:07 PM   #9442
ssevy
Oddometer: 870
oil plug leak
Did you check to see if it was torqued correctly? The only reason I can see that a plug would be replaced is if they come with a hard sealant already applied from Triumph, or some special design feature that was one-use-only. Personally, first I would use some Blue Hylomar sealant on the old one, unless upon removing it I discovered a feature which truly makes it one use only (perhaps partial threading with some kind of softer insert to provide sealing?). By the way, I found Blue Hylomar at Pep Boys (if it is good enough for Rolls Royce jet engine sealing a little crankcase plug should be no big deal).
ssevy is offline   Reply With Quote
Old 11-12-2011, 04:27 PM   #9443
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,653
Yeah I checked the torque, it didn't budge at even a couple more foot pounds over spec.
Old 11-12-2011, 04:42 PM   #9444
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,653
I think a thread sealant like this would be better, Hylomar is for gaskets and flanges.
Old 11-12-2011, 06:58 PM   #9445
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,990
My god I'd be scared to look that close to any of my bikes in fear of what I might find.....
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 11-12-2011, 06:59 PM   #9446
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,162
Finally got one. Picked it up today and put it through its paces. Much easier to ride on dirt/gravel than the girlie. No bottoming on landings.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 11-12-2011, 07:06 PM   #9447
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,653
Whatever........I had just wiped the oil off, after a couple hundred miles it is dripping off the engine guard.
Old 11-12-2011, 07:28 PM   #9448
Xcountry-Rider
Oddometer: 912
Congrats shes lovely!!!
Xcountry-Rider is offline   Reply With Quote
Old 11-12-2011, 09:22 PM   #9449
Ducken
Ducken's Avatar
Oddometer: 107
No bottoming on landings?
Full Monte, if that was a joke, cool...if not, some Heidenau K60's in short order might extend your lifespan...And by the way, some think that the 140 rear is a better choice for off roading, I've tried both, and prefer the 150 for both off and on road use. Ken
Ducken is offline   Reply With Quote
Old 11-12-2011, 09:29 PM   #9450
southwade
ΜΟΛΩΝ ΛΑΒΕ
southwade's Avatar
Oddometer: 1,745
+1, I'm really liking these bikes... I need to go test riding soon...
i haz z1000!
southwade is offline   Reply With Quote
Times are GMT -7.   It's 07:41 PM.
