Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 02-02-2012, 06:19 AM   #10771
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by yossarian™ View Post
ouch. Sorry to hear that.
Did the chain break, or did it come off the rear?
x 2 ???
fbj913 is offline   Reply With Quote
Old 02-02-2012, 06:23 AM   #10772
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by fullmonte View Post
No remap yet, as I've only ridden it once since the install. I'm still not sure what I'm going to do because I don't want to lose any mpg, and the bike runs great with the Leo. As you can see the pipe looks stock, especially now since I removed the Leo Vince stickers/emblems, sorry no pics. It weighs quite a bit less too. Also, the quiet insert tip is a smaller diameter than the stock can, which leads me to conclude that maybe it doesn't need to be be remapped.
LV with quiet insert.
Just an FYI. I ride with a guy that runs this same pipe, I have stock. We are out of gas at pretty much the same exact time. I think he has a remap of some sort. I'm a little faster than he is and I enjoy twisting the right hand in the lose stuff. On long gravel/ offroad rides I have even taken a little more gas than he does. So, I would say gas mileage does not change at all.
Old 02-02-2012, 06:34 AM   #10773
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,310
Originally Posted by ElNorto View Post
I installed one last year with the original map. Its seemed slightly lean on cold start with the DB killer in place but OK when warmed up. I tried it without the DB killer for a few weeks and you could feel it was lean even after coming up to temp. Too loud for me so I replaced the DB killer.
Since getting the remap for the stalling issue (mine never stalled BTW) the bike seems to run fine. If I do decide to play with the map I'll get a Teclusion so I can play with it rather than have the Arrow map installed.
Good to know. I plan on leaving the DB killer in place. Why not just buy a cable and download maps from Tune ECU? I have one but haven't played with it yet.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 02-02-2012, 06:37 AM   #10774
fullmonte
fullmonte's Avatar
Oddometer: 5,310
Thanks for the feedback on mpg fbj. Would you mind asking your riding buddy what map he's running?
Old 02-02-2012, 06:52 AM   #10775
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
He's a mechanic at the local shop and what it sounds like is its the Arrow map. I cant ever get a straight answer from him. Sometimes I don't wonder if they fool around with the computer and do a little self mapping. I will ask again.
Old 02-02-2012, 07:21 AM   #10776
spewler
Not (w)reckless
Oddometer: 108
It came off the rear...I rode it the 30 miles home, so I have nearly-new synthetic oil all over the place! I'll take some pictures throughout the repair process so you all can see the before and after.
2011 Triumph Tiger 800 XC (25,000 miles)
2001 Aprilia Futura (127,000+ miles)
spewler is offline   Reply With Quote
Old 02-02-2012, 07:31 AM   #10777
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Keeping your chain tight it critical! So is carrying JB weld with you at all times! I can't believe you rode it home. That would freak me out!
Old 02-02-2012, 07:56 AM   #10778
bross
Where we riding to?
bross's Avatar
Oddometer: 4,552
And the best way to prematurely wear out your sprockets and counter shaft bearing. Chains need slack for a reason, main one being that the longest a chain will ever be is when the rear axle, swing arm pivot and counter shaft are all in alignment. At that point you still want a bit of slack in the chain. Typical is 1" to 1 1/2". With my DR I can lay on the seat and compress the rear enough to get all 3 aligned, then I just grab the chain and check it.
Our son did the exact same thing on his KTM dirt bike, but on those full race dirt bikes you need to run the chain VERY loose because of the long suspension travel. It was a fine line between "just right" and "too loose". He had it a bit too loose one day and was ripping down a gravel road at full speed, simply backed off and the chain whipped forward and pulled the clutch slave cylinder out of the case, along with a piece of the case. $2800 mistake. KTM sell a $35 case guard that protects against this type of thing but do you think they'd install it at the factory, nope.
bross screwed with this post 02-02-2012 at 08:08 AM
Old 02-02-2012, 08:29 AM   #10779
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
He just told me he is running the Arrow tune.
Old 02-02-2012, 08:59 AM   #10780
spewler
Not (w)reckless
Oddometer: 108
Chain was about right, maybe slightly looser than the 1-1.5" I usually keep it. I suspect the little bracket with the rubber stopper that keeps the centerstand from hitting the swingarm when retracted might have played a part in the chain derailing. I think that is one of the few poorly designed parts on the 800XC (the bars in the fuel filler hole and airbox access being a couple of other questionable designs).
Old 02-02-2012, 12:44 PM   #10781
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Then take it do the dealer and tell them to replace it. That would be a warranty claim.
But I dont see how that could happen...
Old 02-02-2012, 01:13 PM   #10782
spewler
Not (w)reckless
Oddometer: 108
Already talked to them...they're not going to warranty it based on my "suspicion." I have no proof that bracket caused my chain to derail...could've been a rock that got between the sprocket and chain...
Old 02-02-2012, 02:00 PM   #10783
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
do you have to take the Triumph skid plate off to change the oil and oil filter?
Old 02-02-2012, 02:07 PM   #10784
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,671
No.
Old 02-02-2012, 02:19 PM   #10785
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by Yossarian™ View Post
No.
Sweet. I guess Sam Adams and I are doing that tonight...
Times are GMT -7.   It's 02:58 PM.
