Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-02-2012, 10:00 AM   #11401
Simon Smith
Simon Smith's Avatar
Oddometer: 192
Originally Posted by blacktiger View Post
You can change the reading into all sorts of stuff such as L/100kms, M/USgallon, M/IMPgallon etc. just go into settings. Maybe those that are reading more than they get ARE on IMP gallons.
I have fiddled with that in the past, but forgot you could choose between imp and US, But is it possible that some US owners have it set on imperial without knowing? Could it default back to imperial when a new tune is loaded as that would explain the change from 40mpg to 50mpg (or at least according to the knackered calculator on my desk it would)
'11 Triumph Tiger 800XC,
Simon Smith is offline   Reply With Quote
Old 03-02-2012, 10:03 AM   #11402
shadygrady
Oddometer: 59
So I called and they really do not have a number for the map. They said it is the most recent map released by Triumph for the 800. You will need to visit a dealer and have them connect up your bike to know if you have the most recent. I know there are some members with dealer tools or other devices that may be able to determine the map in place, not sure if you are one who can do that? Sorry I can't be more specific.
I would recommend buying a ODB cable (less than $20 on ebay) and use the TuneECU (free) program. It is an invaluable tool to have IMO! Just load TuneECU on a laptop and hook up the cable to your bike and presto, all the map info you need. You can find all the latest maps here for download.
shadygrady is offline   Reply With Quote
Old 03-02-2012, 10:04 AM   #11403
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,967
thanks for checking. I have the tune ecu software I was just wondering if the latest code on the tune ecu site matched yours. I think the most recent release was in January.
swimmer is offline   Reply With Quote
Old 03-02-2012, 10:19 AM   #11404
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,723
I am currently at tune 20629; I performed that via TuneECU in September 2011, and the TuneECU site shows that as still the current tune for an XC with ABS and standard silencer.
Old 03-02-2012, 10:35 AM   #11405
shadygrady
Oddometer: 59
I recently loaded the latest tuneECU map for the Arrow Exhaust and in the process I saved the current map from my bike (20629). To get to the point, my dealer as of Feb 2012 said that the last map I had on the bike (20629) was still the most current that they have in their system.
Old 03-02-2012, 10:39 AM   #11406
Jblk9695
AKA-Crazy Old Man
Jblk9695's Avatar
Oddometer: 260
Modified Arrow baffle with 42 holes, I'm thinking about adding a few more just for the hell of it
And the end hole is .8" by just grinding some material off the end.
And my tune is 20631 which I belive is the current one for the Arrow.
Jerry
69 going on 25 and Retired or 483 in dog years
Jblk9695 screwed with this post 03-02-2012 at 11:36 AM
Jblk9695 is offline   Reply With Quote
Old 03-02-2012, 11:39 AM   #11407
Jblk9695
AKA-Crazy Old Man
Jblk9695's Avatar
Oddometer: 260
So while I had the baffle out look what happened
It got more holes for a total of 54
Don't know what it sounds like yet but I imagine it will sound good.
Jerry
Old 03-02-2012, 11:40 AM   #11408
shadygrady
Oddometer: 59
Good idea with the baffle jblk! According to tuneECU, that is the latest tune for the arrow for non-ABS bikes.
I just sent out some parts (handlebars, triple trees, hand rails, risers, etc..) to get powder coated gunmetal black I'm sending out the pipes/header to get ceramic coated this weekend. Need opinions...Do I go black or brushed steel like the Leo pipe? That Leo pipe can also get coated black. My tiger is orange.
shadygrady screwed with this post 03-02-2012 at 12:21 PM
Old 03-02-2012, 11:50 AM   #11409
Jblk9695
AKA-Crazy Old Man
Jblk9695's Avatar
Oddometer: 260
I think the brushed steel would look great with the pipe on the Leo. Post some pics which ever way you go and an idea of how much it costs.
Jerry
Old 03-02-2012, 11:53 AM   #11410
TAMPAJIM
Oddometer: 494
By Jove, you got it. Mine has been reading high calculated mpg ever since it's 6k service. (latest tune was installed)
Dealer said they would reload tune but it didn't help
After reading this, I went and checked and lo, the thing was set at imperial gallons.
Now it's back to normal
__________
Jim
TAMPAJIM is offline   Reply With Quote
Old 03-02-2012, 12:32 PM   #11411
gallowaystx
gallowaystx's Avatar
Oddometer: 135
Now i'll have to go and check mine!
gallowaystx is offline   Reply With Quote
Old 03-02-2012, 12:34 PM   #11412
gallowaystx
Oddometer: 135
Jerry
I would love to know how you got the baffle out - is it easy enough? And it would be great if you could post a video of what it sounds like after the mod. I have an arrow pipe, I love the sound but would like it just a little bit louder.
Old 03-02-2012, 01:02 PM   #11413
andoulli
CAJUN
andoulli's Avatar
Oddometer: 2,114
Of curse now I had to go out and check mine and it was set to US MPG. The other choices are liters/kilometer, kilometers/liter, and MPG which I assume is Imperial.
andoulli is offline   Reply With Quote
Old 03-02-2012, 01:30 PM   #11414
Jblk9695
AKA-Crazy Old Man
Jblk9695's Avatar
Oddometer: 260
Getting the baffle out is easy, just stuff a paper towel in the hole so when you drop the retaining screw it doesn't fall into the muffler. I just stick a piece of steel rod into the baffle and wiggle it around while pulling, you can also use a broom stick or wooden dowel to wiggle it out. And when doing the holes use a 3/8 or 10mm dia end mill preferably carbide center cutting, I used a 5 flute cause I had one. I suppose you could use a drill bit but be careful and clamp the baffle down securely or it may ride up when the drill breaks through and whack the crap out of you.
I'll try and get a video this weekend.
Jerry
Old 03-02-2012, 02:29 PM   #11415
Jblk9695
AKA-Crazy Old Man
Jblk9695's Avatar
Oddometer: 260
Being retired has its benefits
Shot the video and not so sure I didn't put to many holes in the baffle proof will be in going for a ride and see how it sounds with my helmet on.
http://www.youtube.com/watch?list=UU...yer_detailpage
See what ya think.
Jerry
Times are GMT -7.   It's 03:38 PM.
