Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-06-2012, 03:01 PM   #11491
tiefflieger
tiefflieger's Avatar
Oddometer: 300
Tiger 800 Chef Ramsay Edition
Managed to snag me a very limited Chef Ramsay Edition Tiger!
Comes with built-in cutting board and only available in white to represent "Chef Ramsay's pure, angelic, and motivating way with words" to quote the sales brochure.
Then I decided, I wasn't going to cook much while riding anyways, so I bolted this thing to it:
More better!
tiefflieger is offline   Reply With Quote
Old 03-07-2012, 12:09 AM   #11492
navillus
Oddometer: 14
Torque settings for tiger 800 triple clamp
Laid my Tiger 800 down yesterday Very slowly on some dirt . Bars seem to have shifted, I cannot believe they are bent due to the very low speed. I believe they shifted in the top triple clamp. Does anyone know the official torque settings for the triple clamp as I want to try and loosen and straighten. Thanks guys/girls.
Tiger 800 ABS, 94 GPZ 900, 83 KZ 750, 92 CBR 600, 73 RD 350, KR-1S 250, 85 DTR-125, 89 Honda 50
navillus is offline   Reply With Quote
Old 03-07-2012, 04:14 AM   #11493
KildareMan
KildareMan's Avatar
Oddometer: 684
Page 1.43 of service manual.
Handlebar clamp riser to top yoke - 10mm bolt - 35Nm
Handlebar upper clamp to lower clamp - 8mm bolt - 26Nm - Lubricate threads with engine oil
KildareMan is offline   Reply With Quote
Old 03-07-2012, 06:14 AM   #11494
fbj913
I ride
fbj913's Avatar
Oddometer: 2,366
Bike won't start. Dropping it off at the dealer today. Stay tuned...
fbj913 is offline   Reply With Quote
Old 03-07-2012, 06:17 AM   #11495
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,691
Won't turn over?
Turns over but won't fire?
Old 03-07-2012, 06:41 AM   #11496
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,268
Bummer.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-07-2012, 06:42 AM   #11497
fbj913
I ride
fbj913's Avatar
Oddometer: 2,366
Originally Posted by Yossarian™ View Post
Won't turn over?
Won't turn over but will bump start.
Old 03-07-2012, 06:47 AM   #11498
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,691
Battery must have enough juice to run the fuel pump and fire the injectors.
My money is on the starter or starter circuit.
Old 03-07-2012, 07:10 AM   #11499
fbj913
I ride
fbj913's Avatar
Oddometer: 2,366
We shall see.
Old 03-07-2012, 09:40 AM   #11500
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,765
Probably your clutch safety.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 03-07-2012, 10:39 AM   #11501
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
You are correct, fork tubes are most likely "tweaked" a bit in the triple clamps. A common occurrence in a fall. Nothing is bent. Does the 800 Tiger have rubber mounted handlebars? If so, then the bars could also be "Tweaked".
The quick and easy fix for the fork tubes is to simply tap front tire on a post or rock gently. Ride bike. Oh, you went the wrong way and now it's worse? Tap the other way. Eventually you will get it straight. Ride to verify. Nothing is bent. Tap tap tap.
The Official way to solve this is to slightly loosen all triple clamp bolts, elevate front wheel. Give the bars a sharp back and forth shake. Re-torque. Never over tighten triple clamp bolts ... you can CRUSH fork tubes.
Old 03-07-2012, 10:48 AM   #11502
Mercury264
Mercury264's Avatar
Oddometer: 22,268
--mark
Or sidestand switch
When mine went TU, I think I had the same symptoms (on mine a rock hit the switch plunger preventing it from moving out enough when the sidestand was up and so the bike thought it was still down and wouldn't start).
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-07-2012, 10:52 AM   #11503
fbj913
I ride
fbj913's Avatar
Oddometer: 2,366
Originally Posted by Mercury264 View Post
Or sidestand switch
The bike wouldn't run if it thought the stand was down.
Old 03-07-2012, 10:57 AM   #11504
Mercury264
Mercury264's Avatar
Oddometer: 22,268
I think you're right - so, scratch sidestand switch as the culprit.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-07-2012, 01:08 PM   #11505
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
Did you check any fuses?
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Times are GMT -7.   It's 01:42 PM.
