Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-12-2012, 01:04 AM   #11581
Windy Rider
Pussy Power
Windy Rider's Avatar
Oddometer: 378
Originally Posted by Adv Grifter View Post
Good move! Center stand makes fixing flats child's play. But, FYI, you can do it without the center stand ... and no need to lay bike on its side. Much better to find a big rock, stump, or whatever ... lean bike over onto side stand and wedge rock up under skid plate.
Move rock fore or aft to raise either front or back wheel off the ground. Put bike in gear, if rear, secure front tire. Bit of a struggle solo but can be done even with a heavy bike. Go slow, be careful. It works.
That is very good news that the rim did not dent! I was wondering about the strength of those wheels.
Here's how it's done
Or like this
2011 Triumph Tiger 800xc
Windy Rider is offline   Reply With Quote
Old 03-12-2012, 01:32 AM   #11582
Seb1234
Oddometer: 20
Originally Posted by Ronin1 View Post
Who makes that seat?
Jim
A local dealer. It mades it with you trying every adjustment so that it perfectly fits.
http://www.selle-moto.com/sellerie-concept-selle-moto/
Regards
Seb1234 is offline   Reply With Quote
Old 03-12-2012, 02:07 AM   #11583
the_babaji
the_babaji's Avatar
Oddometer: 289
Regards
I must say, those are some pretty nice looking designs!
the_babaji is offline   Reply With Quote
Old 03-12-2012, 03:23 AM   #11584
Seb1234
Oddometer: 20
Thank you :)
Old 03-12-2012, 07:15 AM   #11585
KildareMan
KildareMan's Avatar
Oddometer: 683
Originally Posted by motonut View Post
There are several threads on another forum about mounting the Stebel Nautilus to Tiger 800s.
Here's one: http://www.tiger800.co.uk/index.php/topic,3191.0.html
I have a Stebel Nautilus on my R80RT that I intend to remove before I sell it(wanna buy an airhead?) but after looking over my Tiger Roadie, I am not at all sure of how that project will proceed. I may let that sucker fly in the great wide open. Maybe buy another one and mount them like Motolights on the front brake calipers! Would sure nuff make noise!
Pretty much the 1st modification I made was to fit the Nautilus a year ago. Full details on Tiger800.co.uk look in "How To"
Basically I split the compressor from the sounder. Compressor can live under the tail rack or as I have sideways against the cross member just before the tail rack. As I don't have the ABS I mounted the sounder under the Tank/Seat securing bridge. I have suitable small internal diameter hose and fittings. Power from my Eastern Beaver fuse block, via the Eastern Beaver horn loom.
For those with ABS you can fit the sounder at the front. Works perfectly so long as you hose is suitable small internal diameter. No delay whats-so-ever.
Initial compressor placement. Now against the seat lock cross member.
KildareMan is offline   Reply With Quote
Old 03-12-2012, 07:41 AM   #11586
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,262
Finally got the Tigger out of winter hibernation on Saturday (truth be told, given the winter we have had/are having, I needn't have bothered...) and I have to say, goddam it's a great bike Did a ride up to Maine yesterday, roads were nothing special but it was so nice to be out riding the Tigger.
I also fitted the new Scorpion can I've had for a while now. I did struggle a bit with the connector pipe - it's a bigger diameter than stock and in the end I had to take out the braid type stuff from the header pipe to make it fit.
It sounds lovely now - throttle response seems to be better, more crisp. I've tried it with the baffle in and out. In it's a tad to quiet and out it's a tad too loud so I may have to drill some holes in the baffle to waken it up a little.
One thing I did notice was the popping on the overrun that I don't recall getting with the stock can - anything to be concerned about ? To me that indicates a lean condition and I really don't like it to be too lean.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-12-2012, 07:48 AM   #11587
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,752
I think you're right about it being too lean. I ran the stock can map with my Arrow for awhile and it popped a lot like that. I installed the correct map and the popping went away and IMO runs a lot better although fuel mileage suffers.
jimjim is offline   Reply With Quote
Old 03-12-2012, 07:55 AM   #11588
Mercury264
Mercury264's Avatar
Oddometer: 22,262
I think the Arrow requires a new tune but the Scorpion was designed from get go to be used with the stock map (which is what I have installed) - that's my understanding at least. As I say, throttle response appears to be much crisper, the only thing is the popping. It's not bad to be honest (the popping on my Husky is much worse and it runs just fine), I was just curious more than anything.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-12-2012, 08:11 AM   #11589
the_babaji
the_babaji's Avatar
Oddometer: 289
How much more does it pop, than the stock bike with original can?
Old 03-12-2012, 08:20 AM   #11590
Mercury264
Mercury264's Avatar
Oddometer: 22,262
Hard to say since it's been a while (Dec) since I rode the bike. It really doesn't pop too much, it was just something I noticed.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-12-2012, 08:44 AM   #11591
marloweluke
The Flying Dutchman
marloweluke's Avatar
Oddometer: 149
Rocks are almost always available where I am, but not everywhere else. Also I didn't want the extra weight of a center stand so I opted for the Enduro Star Trail stand. You can find it in the Vendor's section. Small and lightweight, portable.
http://www.advrider.com/forums/showthread.php?t=538235
WITHOUT RISK........THERE IS NO ADVENTURE
marloweluke is offline   Reply With Quote
Old 03-12-2012, 09:03 AM   #11592
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,853
Originally Posted by refokus View Post
Hey Swimmer, where did you pick up the power for the montana? Also, the mount you have, do you have some details? Material, etc.....?
Looks nice, I need to mount my Montana as well. Been putting this off for a while.
I have Montana wired to my http://www.fuzeblocks.com/ that I pulled off my versys before trading it in. I just used some ~.060" aluminum for the mount. I had planned and drawn it to use ~.100" but hte .060" I had was close to the right overall dimensions. It works OK but a little thicker would be better.
I was going to have someone else make this and anodize it but unless I get about 20 made it's just to expensive. So I just made it myself and painted it.
swimmer is offline   Reply With Quote
Old 03-12-2012, 09:33 AM   #11593
KildareMan
KildareMan's Avatar
Oddometer: 683
I added 3 extra rows and a 12mm hole in the end plate. Extra rows are the way to go though.
Old 03-12-2012, 09:40 AM   #11594
Mercury264
Mercury264's Avatar
Oddometer: 22,262
I was hoping you'd chime in.....
So, did you have to remove that braid stuff as well ? I could not figure out how to get the connector in there without removing the braid stuff.
And, do you have the popping ?
Cheers
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-12-2012, 09:41 AM   #11595
marloweluke
The Flying Dutchman
Oddometer: 149
First Ride
I also had my first ride of the year. A nice warm spell this Saturday, so I insured the bike for the day. Cloudy but dry skies. I was eager to try the new caribou cases and Madstad windscreen I put on over the winter. The screen is great, I will try to raise it another 1/2", but otherwise it is perfect; no turbulence, no noise, loverly. No more weight gaining mods for me, future mods will be to reduce weight, such as aftermarket exhaust and lithium battery. I woke up to fresh snow this morning, so the timing was good. Summer is coming...
Still looking for after market exhaust that don't get too hot to burn a passenger. the LV carbon seems to be an option, anybody else out there have some recommendations?
Times are GMT -7.   It's 11:12 AM.
